Everything posted by subie94
so when you coming up? let me know a couple days in advance,so i'll know if i'm free.. i guess once you come up here an i snap off acouple pics...it'll get folks to stop whining about the lact of pics..
reason that i was hoping was cause there's a set of four mounted tires for free in my local paper.size is 205/74/14's (M&S) and they're mounted on early 90s ford ranger wheels.. i found out that rangers used a larger pattern(114,i believe) and where legacy is 100mm.would it be feasible to use them by elongate the holes or should i just put tires on my wheels? http://rds.yahoo.com/_ylt=A0oGkjhdYyhF6SEBsc9XNyoA;_ylu=X3oDMTE3M282bmw4BGNvbG8DdwRsA1dTMQRwb3MDNgRzZWMDc3IEdnRpZANZUzk4XzExNw--/SIG=11ogn32mi/EXP=1160361181/**http%3a//wheeltool.com/info/5bolt.html
so how far did you get-http://www.ultimatesubaru.org/photos/showphoto.php?photo=13095&size=big&cat=500&ppuser=679 tires look awesome
1st off...welcome aboard you may or may not need to mod the bezel,it all depends on the aftermarket radio you get.here's the one i had (can't remember where i got that storage compartment) as far as gaps.if you get a decent install kit,there shouldn't be any. on the removal of the stock radio-1st remove cup holder,then remove the trim bezel around the radio(2 up top and i think after taking out the ash tray you'll see one in the back) there's a total of 6 screws that hold the radio in(4 that you'll see right off cause there right up front and 2 towards the back,1 on either side of radio) this might help.with the radio removal an center console removal(partly)
that vid was awesome well done..
Soob Noob 4x4 Questions
subie94 replied to brianbarber's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you can try going on to a dirt road and push the button an gas it. you'll know your in 2wd when jst the front tires spin in the dirt.hit button again and repeat. if i remember correctly,there is a light on the instrument panel that tells you when your in 4wd mode..(bulb could be burnt out) BTW-welcome aboard -
bruceyWV-i see you evened it out..looks good. fnlyfnd-i think it looks awesome.that's one of the many mods i want to get around to..
well after picking up a set of fiamm air horns..i decided that for simplicity,i'm gonna exchange them for a set of fiamm am-80.(high an low freq) the am-80s are basic plug an play *great,now i can't decide* (maybe i'm being lasy an not wanna do any wiring...) after putting in the new horns,i'll have to try and record it on vid w/sound(of course)
how'd you run it to the filter box? any pics?
anyone ever have their ignition switch become loose inside the column.? this has happened to my 94 legacy and after taking the two plastic pieces off the column,it looked to me that a special tool was required to tighten it..does anyone know if this is true or am i looking at it all wrong?(maybe i need to look again) btw-it does wiggle to bad but it's noticable. any ideas or suggestions?
that sounds like a good idea.
hey,i was gonna say that... i'd go with what dave said,check wiring first.i had a bad wire on the front pass side corner light.i thought it was bulb related so i tried a new one an still no work.(though it'd come on if i hit a bump or that corner of hood) found the cut wire and a few mins later it worked perfect. so yah,i'd make sure no wires are damaged 1st
