Everything posted by subie94
some folks that have done the swap have been about 1/2" higher then a outback. as far as you not finding shocks...the strut is basicly the shock with a spring in one.
don't have a 98/99 legacy but i do have a 94 gt that has what i think your talking about.. is the grey area,the part your talking about(or close to it) might be like a air dam there's been acouple of times that i've scraped it..along with my oil pan. as far as something being wrong..you could look at the springs to make sure you don't have a busted one like i had.because one spring broke,it affected the rest...and now i believe i need all four replaced(which is a good reason to do the strut swap)
Hmmm,wrong wagon for the parts i need..(need stuff from a legacy outback)
i find it too cool to see a forester getting pitched sideways in a corner.. back tire(s) smoking too..
it was about a 10-15 degree grade and made it up about 2.5 feet..(i guessed cuz i didn't have a tape measure) i know it's nothing special,but just wanted to show my first attempt at flexing my stock leg. (probably should have pushed more cuz my tires didn't even slip):-\
i haven't found out personally,but i believe that if you use the outback springs..then you need of course to use the strut tops(part that attaches to body).now doing this will rquire you to drill new holes(for back struts i think) you can get out of that by just useing the legacy springs and tops.granted you lose a small bit of height an stiffness that you'd get from OB struts but then you don't have to take the chance of messing up the drilling new holes. don't take this as me trying to talk you out of doing the strut swap,just thought i'd let you know. also,no you don't really have to replace the wheels..it'll give you extra money for buying taller tires.
http://www.ozified.com/pricing1.htm if you can pick up a part time job and put some aside each payday..you'll be liting properly in no time.
i'd have to agree with Qman.. normally coil over kits allow you to go from stock height and drop it acouple inches..not usually raising it. i'd just wait and get a proper lift for your loyale..(i'm still waiting to do my lift)
i noticed a difference shortly after she was done spewing smoking.. alot better acceleration and i'm hoping for better gas mileage. what experience did all those that did a upper engine cleaning have? (i know weird question) BTW-though i didn't use seafoam,i did use GMs upper engine cleaner. *edit*-not sure why i put this here,i suppose i could of put it in off topic..(but i am talking about my 94 leg)
when doing a compression check,you don't want the engine to start..you just hook up and bump the engine. i had a head gasket completely go and the engine just gushed out oil an coolant.
you think your a slacker...i' on my 8th soob.most have passed away due to accidents.sold 1 and stupidly traded one in for a dodge. zap-great collection you have.
looked like fun.. awesome that you handled it yourself..i know myself wouldn't be able to :-p can't wait to see it sitting on all four..
Speakers
subie94 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
as far as the "not fitting" part,i believe they mean depth cause.i found out that the window hits the magnet of the speaker in the front pass door..(need to cut out a spacer for it)
