174
Everything posted by lmdew
1999 outback
lmdew replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, 96-99 will interchange. Check out the Colorado Springs Craigslist - rust free CO Car $1400. Larry -
I always go the other way 2.5 to 2.2. Never had a problem. Make sure all of you connections are good if you have not done that already. I'd you have a problem before the swap? Could be a cam or crank sensor is cutting out a higher RPM. Does it make a difference if you are under load or just in neutral?
Contact djmark7. I just sent him springs and top hats and he has new struts that he can not use as his strut towers were rusted out. djmark7 USMB is life! Members 181 posts NW New Jersey Sent 22 August 2013 - 10:01 PM welp spent money for naught rear strut tower rusted away from body, terminal looking for another one now, all i can spend is 1500, few and far between avail for that price
If you need a TPS I have several. When you crank and it doesn't start does it have spark? You may have a cam or crank sensor going out. An oil leak at the back of the engine is most likely coming from the breather plate. The RTV fails when the screws loosen. Also make sure you PVC valve is working.
NOx passed, but I'll double check the EGR is opening. The old DOHC engine the HG were completely gone, dumping coolant into the oil. When I filled the radiator to get the car home, when I started it water shot out the radiator cap about 15 feet into the air. First time I ever saw that. I'm guessing the OP over heated it for a long time. I'll check the O2 sensor and see if the plugs look rich. I do have a spare CAT I could put in if I need to. Thanks, Larry
It runs great. I pulled a trailer to Denver and back to get a frig. No CEL. A friend took it up to Denver for a relative and it failed emissions. I did tap into the IAC hose for the EGR pipe as the head could not be drilled. 95 2.2 with 155K on the engine and 320K on the car. HC GPM 1.0038 - Limit 1.2000 Passed CO GPM 41.6271 - Limit 15.0000 Failed CO2 392.0529 NOx GPM 1.0090 - Limit 2.0000 Passed Could the EGR Bypass be causing this? Thanks, Larry
Those are in the center counsel area. You might just have something stuck in the retract reel. If its done, just grab a used one and install it. The window is most likely just the switch. Easy enough.
- 6 replies
- 1
- Seatbelts
- retraction
(and 2 more)
Tagged with:
The starter gear moves out less than a 1/2". I'd turn the engine over by hand and if it's free and feels normal you should be able to push start it, go forward not backwards. If the starter was dragging down the engine RPM it may have died at idle. The read main seal almost never leaks but the breather cover almost always leaks and should be resealed. If you have the plastic plate, get the metal plate.
EGR Question
lmdew replied to vladvv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Not sure what year and engine you have but I have plenty of intakes with all of the stuff on them. If it mounts to the intake I most likely have it. -
Pulled the Daughters 99 Impreza trans, the quill shaft has significant wear. I spent some time and sanded down the ridges and it's smooth now but the throwout bearing has more play than it should. Looking for a sleeve repair. Anyone have any feed back on this repair/kit? http://sumoparts.3dcartstores.com/TSK1-Transmission-Sleeve-Kit-for-SUBARU-Impreza-1993-2011-18-22-25-Non-turbo-Replaces-30502AA051_p_15.html#
