Everything posted by lmdew
Transmission Locked up after an Engine Installation
I'm out in CA and a co-worker had pulled his engine for some head work. He got the engine and new clutch back in and it runs fine but the transmission is locked up tight. We pulled the back top cover and verified the linkage was moving and put it in neutral. If you spin the input shaft or front diff stub axles everything moves fine. If you hold the stub axles and try to sping the input shaft it's locked up tight. 93 Legacy, 5 sp 153K on it. He said it went together fine and only had to pull it together when it got to the alignment pins. If he would have damage something on the engine installation, I would think it would have been the input shaft but it is not loose and it does turn if you let the stub shafts turn. Any thoughts? Very strange! Thanks, Larry
steering rod joint play and other misteries
lmdew replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, you do not need a special tool. You will see the locking tab washer on the inner side. It's very easy to bend it out so the v locking dent is out of the way. Then just un screw it. I've been able to save and reuse the washer. Sometimes the little tang, breaks off. If so get the new locking washer.
replacing door handle
lmdew replied to 99legwag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a pain, there's the spring clip for the lock and 2 10 mm nuts. The aft nut is the one that's tough to get. Roll down the window Pull the door panel Pull the switch out of the door so you can roll the window up and down while you work without the panel in the way Pull the plastic back at least half way Disconnect the control and lock rods and move them out of the way Remove the Lock Spring Clip Remove the two 10 mm nuts Pull the handle out.
94 svx no start, no check engine light?
lmdew replied to K9WAGON's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXECU are pretty good. I'd start by checking all of the battery connections, grounds and fuses!
97 Outback Now 2.5 DOCH Strange Temp rise and Drop.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Trans is fine, no torque bind. I replaced the Shifter and both the front and rear dirve shafts. I'm flushing the trans today. The FWD does work, when you put a good fuse in it. It needed the normal things: - Brakes front and rear - Rear Struts - Power Steering Pump - held on with 1 bolt bracket to engine It will be a nice Subaru again!
1999 Subaru Legacy Error codes
lmdew replied to corygoose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo the 2 problems are not related. Get the new code.
I picked up a 97 Outback Limited, Auto. The front drive shaft U-joint had failed. It bent the shift linkage so it would not start in Park, but did in neutral. PO thought the Trans was shot, but I think it just has a bad case of torque bind as the FWD fuse does not bring on the light and it looks like the rear tires are scrubbed pretty good. See update at the end:
97 outback auto to 5spd swap
lmdew replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can check things with your volt meter. When there is no ground open switch you should see 5 volts coming out of the ecu. When you have a ground, switch closed, the voltage drops to 0. So if you have identified the correct wire coming out of the ecu, then you can run it out to the NPS and to ground. When I did this, I found a wire from the TCU harness that was not being used that went to the engine bay and tied to the NPS through the connectors.
1999 legacy EJ22 poor acceleration at start
lmdew replied to william.ford's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck www.brighterideas.com If you checked the voltage with no load your meter could lie to you!
Power steering boots
lmdew replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hit the yard and pull the newer plastic style of boot. It works great. Jack the car Center punch the outter Tie rod nut and tie rod for alignment. Unscrew the outter tie rod - you don't have to take it off just sping the shaft. Take a coat hanger or welding rod and put it up against the nut, which you just backed off a 1/4 turn and then bend the other end over the shaft. Now you know were to put the nut after the boot replacement. Pull the boot clamps, remove the old boot and clean things up as good as you can. Put new grease in the inner tie rod pivot Install the new boot Put the nut back on in the same position Screw the outter tie rod back on and then tighten the nut so the punch marks line back up. Install the outter boot clamp. That's it. Sometimes I drop the exhaust for better access to the inner boot area.
lmdew replied to william.ford's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX14.4 volts is good. Sounds like you covered the electrical items, but since its random and intermittent I'd still be looking for electrical problems. This did not happen before the engine work correct? Sure all of the vaccum lines are good?
lmdew replied to william.ford's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is the output voltage of the alt? I'd double check the Alternator connections and make sure all of the grounds have been hooked up. Larry
lmdew replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI finally had time to do the search, had to change the date range to all: Here's the thread: http://www.ultimatesubaru.org/forum/showthread.php?t=87100&highlight=neutral
seat opinions needed
lmdew replied to kona's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStay with cloth in TUS. The foam is what breaks down. If the covers are good, you can replace just the foam. Passenger and Drivers side foam can be switched so get a used passenger side and you are all set!
Transmission change and shift linkage differences?
lmdew replied to bigB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it will work. Or you could pull the part off your old trans and put it on the new one. No Linkage needed.
lmdew replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee my previous post. I gave you the link to the other thread that has your fix for the N Sw.
99 SUS to 02 OB sedan H6, Yay or Nay?
lmdew replied to DUBSnSUBS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, all I have to do is look under the hood and the 98 Outback with a 95 2.2 swap looks better than ever! So easy to work on and a great value.
Binding on 97 OB 5mt?
lmdew replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNormal stuff to check first: - Tires Matched - Tire Pressure If all is good, the viscous unit in the trans is the most likely problem
cv axle too stiff
lmdew replied to jim22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou Tube on the Rebuild process would be great!
cv axle too stiff
lmdew replied to jim22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the same thing when I got mine, but they have been great.
2003 2.5 SOCH in a 2002 - Running Rich
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI swapped over to the 2002 intake and all the parts on it. The Short Term and Long Term look much better S 2.5, L -10.4 We'll see what the mileage does and check the plugs once the ECU has adjusted.
bad wheel bearing rear
lmdew replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have everything you need. Shoot me an email if you want a complete rear brake set. Lmdew2@gmail.com
EJ22 fan/ecu Coolant temp sensor
lmdew replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI usually end up using a pliers to push down on the locking release tabs.
02 Impreza Kospeed Radiator?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGreat Radiator. All metal, no plastic tanks. Direct bolt in, super quality and a great price. Highly recommended: http://stores.ebay.com/kospeed2008?_trksid=p4340.l2563
lmdew replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a used hub with a good bearing. What side do you need? Make sure you get the PB Blaster out and start letting it soak. The long bottom bolt can be bad if it rusted to the arm bushings.
