lmdew
    172
Everything posted by lmdew
  1. There should be a rubber donut there. Hit any junk yard and pull the steering column and you can pull it out.
  2. I've had good luck bleeding the system, start by removing the old fluid in the master and then fill and bleed until clean fluid comes out the slave.
  3. Check all the connections with the battery Disconnected! Just like you desktop computer, you always remove power before disconnecting and connecting components.
  4. Start with the easy stuff, check the bulbs and sockets for corrosion. If it looks good, you may want to try putting in LED bulbs as they draw less current. If you have a good meter and you can check the amp draw at the fuse or tail lights that will tell you what's going on.
  5. They are dust covers for the strut, to keep grit and grime off the chrome strut so the seal does not wear and leak.
  6. Heat them up with a welding torch or tow the car and see if they don't break free.
  7. Solved. I went up to the son's house with a 96 trans. It had different plugs and a external speed sensor. So much for the free swap. As we looked at the old trans, the pan was dented in pretty good. The fluid that was drained was pretty clean so we dropped the pan. I had had one other Subaru that the trans did not work after someone put on the wrong filter and it was starved for fluid. Once the pad was dropped and cleaned we could see the outline of the screen filter where it hit the pan. We also found a broken solenoid connector, the front one on the aft drivers side. A 100 mile round trip to the You Pull and Pay provided a used solenoid on a Sunday. We put it all back togther and it shifts great. No more Flashing AT Temp Light! Thanks for the feedback
  8. There is an electrical motor up under the drivers side dash that changes the positon of the vent. Sometimes it goes bad but it could be the control panel or a sticky vent flaps as well. Use it as much as possible to keep the system free.
  9. Are you reading voltage under load or with the plug disconnected? See: www.brighterideas.com and click on the training video tab.
  10. Most likely in the pins. You can rebuild them but almost as cheap to get new or good used ones.
  11. I have a good clutch pack for you if you need it. You need to drop the tail shaft to see what's up.
  12. Is the AT Temp light flashing 16 times after you start the car? If so there is a fault in the Trans. The C-Duty is energized to dump pressure from the clutch pack to release the rear wheel drive. If you put the FWD fuse in do you get the light on the dash? Most likely mechanical failure in the tail housing. Search Torque Bind and you will find some post with great pictures.
  13. There are 4 sections to the typical Subaru Exhaust that are bolted together, so yes anyone should be able to hook them up. Y-pipe engine to CAT Cat Pipe, front and rear CAT and the O2 sensors Mid-pipe - Cat to Muffler has a resisnator in it. Muffler The Muffler you can get from the yards. Most of the other are trash as the yards cut out the cats. They cut the Y-pipe and Mid Pipe to get out the cats. I have most of these if you need them. I'm in Colorado.
  14. I doubt the lack of a muffler will cause the O2 sensor reading. Is it the front or rear O2 sensor? Put the system back to normal and see what the codes are. If you have a good scanner or meter you can watch the O2 sensors.
  15. If he jumped the car side of the wiring the switch was out of the picture! But, yes if the switch is in the circuit that could be it.
  16. Can you read the voltage with the lamp installed? www.brighterideas.com had the Load Pro. Sounds like you have a bad connection that will not handle the load, heating up and opening up the circuit. Check the grounds!
  17. Just sitting would not cause anything to change. The spring clips holding the TOB to the fork may have failed and then the adjustment on the TOB to clutch.
  18. I reuse them all the time without any problems or leaks. The fittings are easy to cross thread. I always take the little clamp off the flex lines.
  19. Yep, find a good shop. You can do a lot of MX on your own but it's always nice to have a pro take a look.
  20. If there is a Trans problem, the AT Temp Light will flash 16 times after you start the car. You can have torque bind without any codes. Drive in tight circles on dry pavement. If it chirps or fights going around the corner, you have torque bind. TB could be the C-Duty or the clutch pack. Put the FWD fuse in, do you get the FWD light on the dash? Does that take care of the TB? As far as the miss fire, make sure you have Subaru of NGK plug wires and NGK copper core plugs. Both are recommended here at the USMB. The ABS has codes as well, do a search and you will find the procedure to pull the codes after you have put the fuse in.
  21. The front O2 sensor is necessary for the ECU to properly correct the fuel ratio. If you have a good scanner, you can watch the O2 sensor response and get an idea of the rich or lean condition of the car. The random bucking could be the cam or crank sensor going out, but that should throw a code, so should a mis-fire. Is the CEL working? Have you tried pulling the codes even if the light is not on?
  22. You have a Headgasket leak. Pretty common on the DOHC 2.5. When cool, open the radiator cap, I bet there is little to no coolant. Cheap route, replace with a 95 2.2 with EGR. If it's been overheated for sometime, it's a gamble on just doing the HG as the bottom end may be damaged. Black, oily stuff in the coolant tank = HG failure on the 96-99 DOHC, at least most of the time.
  23. No Cel back on as of now, I"m going to check the setting on the TPS and will run a can of seafoam through it. Thanks
