Everything posted by lmdew
starter bolt
lmdew replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX17mm If you have a spare 14mm like the rest of the nuts on the engine to trans swap it out.
Rattly hatchback
lmdew replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the bottom trim that covers the latch catch. Mark the current position. Loosen the two bolts. Get a block of wood and a hammer and drive the latch back about an 1/8 to 3/16". Put it all back together. It works great, I've fixed the rattles on two 98 Impreza's that way.
Is there suppost to be play in the CV's?
lmdew replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe CV's should slide in an out to compensate for axle travel. Lots of play in the CV indicates wear. I've only seen one come apart over the years and the outter shell was still intact.
00 Cruise parts work on a 98?
lmdew replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey should as far as I know.
Cruise control & remote starter options for 98 Impreza?
lmdew replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you looking on your Legacy or Impreza I've found them behind the lower kick panel on the Drivers or passenger side, or up and to the left of the steering column.
Over heating Fans Not Blowing
lmdew replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurn on the AC! If they don't come on, check the relays in the engine compartment fuse/relay box. If you jump the power contact with the relay pulled you should power up the fan, one relay for each fan.
Replacing Rear HUb..
Lots of WD40 or other good penatrating oil. Let it soak for a few weeks ahead of time. 17 and 19 mm 6 point 1/2 dirve sockets. Socket for the axle nut Large breaker bars. Rust will fight you all the way. The bottom strut attach bolt that goes to the arm may be rusted tight at any place along the length of the bolt. Use a punch to drive out the axle nut locking punch mark With the car on the ground and brakes set, break the nut loose. Remove the tire Loosen the bottom bolt that holds the knuckle to the arms. Remove the brake caplier and disk Remove the 2 bolts holding the knuckle to the strut Drive the axle out of the hub Replace any bad parts and re-install
tire holder in back of 93 legacy wgn
lmdew replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they are all mostly the same and fit. There are some differences, but I never had one that did not work.
90's Turbo Legacy in SLC Yard
White 90's Turbo sedan gray leather interior in SLC Pull-A-Part (not sure of the name) on Redwood Ave just south of I-80. Body is good, high mileage 220K. Engine is there as is the auto trans. It had brand new front capliers and they are Mine! I don't know why it's in the yard, bad trans most likely.
lmdew replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCompletely different system. It may work, but it would be lots of wiring issues.
lmdew replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlug and play for the cruise control. The computer is behind the drivers side kick panel. I have a keyless door lock unit from Subaru if you want it. $45 shipped. Larry
Paging Joshua P. Peck (NH or SC)
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe paperwork is a mess. The POA the dealer used is only for a title with a lien or lost title. I have the original. The CO DMV won't take the Power of Attorney (POA). The Dealer has changed hands and isn't willing to do much. I may have to go to the Dealers Board in SC to get this straight. If I could get Joshua to get a duplicate title and sign it over to me I could bypass dealing with all the Dealers. HELP The address is: 29 Meredith Drive Nashua, NH 03063 If he has any family there and they have contact Info, please have them contact me. Thanks for the Assistance: Larry Dew Lmdew@hotmail.com 719-268-9750
AC Wiring Help for 98 Impreza Wagon
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot yet, this has moved to the back burner for a few weeks. I did find the same car in a yard today and pulled the evap switch, the control panel and all the relays. When I get back to it, I'll give them a shot one at a time. Thanks for the help. Larry
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's what I was thinking. I pulled the switch, destroyed it getting it out and put in a good one I had. Same results. I have power at the AC Switch both into the switch and out when the main control plug is unplugged. When I plug the main connector back in, the output voltage dropps to 0. I have to get the correct wiring diagram for this car. I have the same diagram you have from the wire codes you've given me and none of the wire colors match the car. Strange! Thanks for taking the time to help on this. Larry
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth Fuses in the AC Relay holder are good. What I think is the AC Relay holder is in the engine compartment, Drivers side in the fuse/relay box. There is a mount for the AC Relay, Fan and Sub Fan. At the front, there are 2 15 amp fuses. Am I in the wrong place?
I purchased Joshua's 98 Impreza wagon (Red). It went through 3 dealers before I got it, and the paperwork is a mess. I need to get a good title. If you know this fellow, please have him contact me. I'll pay him for his time and trouble. Thanks Larry Lmdew@hotmail.com
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe wiring looks original. I guess I'll have to check the years before and after and see if the wire codes changed. There is power at the switch, but not full power coming out of the switch when everything is hooked AC control panel is hook up. Something is diverting power, wiring fun!
I have a 98 Impreza Wagon that the AC will not run on. The following has been checked: - AC Switch light comes on when pressed - Fuses are good, relays are good - Jumping the pressure switch does not turn on the Compressor - The radiator fans do not come on with the AC selected - If the relay contacts for the compressor are jumped the compressor kicks in - There is no power at the coil for the AC relay The relay wires are as follows: Coil: Green-Red stripe and Brown Contacts: Green-Orange stripe and Blue I have several wiring diagrams, but none of them match up. It looks like the coil gets power directly from the switch, so pulling it and checking power there will be my next step. It would be Great to have the correct diagram. Thanks Larry Lmdew@hotmail.com
2002 to 1997 impreza strut compatibility
lmdew replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've put WRX and STI Struts on my 98 OBS and my Daughters 93 Impreza Sedan. Yes you do have camber out of limits unless you get camber bolts or use Subaru Front camber bolts and mod the strut and knuckle. I left mine with the camber out of limits a degree or so and have not had a problem with either car.
Paging Joshua P. Peck, Title HELP
I'm looking for Joshua P. Peck. He use to own a Red 98 Impreza Wagon. I have purchased this car after it went through several Dealers and the Title paperwork needs some help. Originally he was in Nashua, NH and he may have moved to SC. Thanks, Larry Lmdew@hotmail.com
ECU says I need a camshaft sensor
lmdew replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might want to clear the code and see if it comes back. The junk yard will have one for you I'm sure. They don't go bad to often so its worth a shot. You may also want to just pull it out and clean of the end of the sensor. I've seen them full of metal and junk. Takes about 5 minutes.
Replacing rear wheel bearings, now what?
lmdew replied to sgregory's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne easy fix is to purchase low mile WRX hubs. The Nasioc guys are selling them all the time as they upgrade and part out there wrecks.
Door & Fender needed for '99 OBW
lmdew replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a 98 on the Denver Craigslist for 400.
98 Impreza Hatch Rattle
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the nut plate inside must be sealed or held in place with some adhesive. I tried to push it back a few weeks ago. I could only move the plate a 1/16" or so. It took a wood block and a good wack to get it to move (bolts loose while moving it).
99 OB intermitent speedo
lmdew replied to billyfrank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the links don't fix it I have a good used one. Lmdew@hotmail.com
