Everything posted by lmdew
95/97 2.2 ECU Code Help
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ECU looks for the switching of 5 volts in neutral, 0 volts when in gear. I'm thinking the 5 volts should be coming from the ECU and when grounded through the neutral sw it's 0 volts. I just don't know why the 5 Volts is not at pin 78.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdated initial post, help is needed! Thanks
dinner can wait - can't get ball joint out!
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX[ ] <> ( ) Sledge Hammer = [ ] A-Arm at the ball joint = <> BFH = ( ) Holding the sledge against the a-arm helps keep the force of the hammer you are swinging in the A-Arm tapper. It will pop out most of the time.
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut a sledge on one side, beat the other with a BFH as well. The force will be maximized in the tapper. A jack on the bottom of the stud doesn't hurt.
Is there anyplace on line to download manuals for free?
lmdew replied to RBGERSON's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDisconnect the Battery Open the center counsel cover, remove the two screws that hold the parking brake handle in. Remove the Parking Brake handle Remove the Shifter Panel Cover, two screws at the rear Remove the Ash Tray and the two screws under the front lip of the ash tray slide. Open the Cup holder, Remove the 2 screws, pull the cup holder out. The radio trim panel is now free, move it out of the way The radio is held in with 6 screws, 4 you will see on the front metal brackets, the other 2 are in the middle at the back of each side bracket. Use a magnet to keep track of the screws. The radio/CD is now ready to be pulled forward. Remove the plugs. Put it back in reverse order.
ABS help, please
lmdew replied to DeSubiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a good one, $75 plus shipping, about $40. Lmdew@hotmail.com
Rear wheel Bearings..
lmdew replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt would be interesting if someone froze the bearing and heated the hub to 250 or so. Lots of interference parts are put together this way and it should make it a slip fit. Then you would only have to press in the hub.
lmdew replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart now with weekly applications of PB Blaster and the bolts might come out. It's great when I get to work on a Colorado Car, instead of the rust belt stuff. Life is good!
96 Legacy Won't Start
lmdew replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the Check Engine Light on? If so get the code and post or search this form. That's the best way to do it. The computer wants to help fix your problem.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, I've driven the car about 150 miles, on and off over 15 times. I've cleared the codes 2x now. I'll keep on doing it and see what happens. Legacy777 swap page is good, but yes its for OBDI not OBDII. The search continues. Thanks for the ideas!
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, the 95 engine complete with manifold and sensors went into the 99. The 97 engine, complete with manifold and sensors went into the 95. The 97 block does not have the EGR port machined and the Manifold has the EGR blanked off.
2001 Legacy Outback Tan Leather Seats
The complete car is in the yard. It was rolled. Colorado Springs, CO. SOHC 2.5, 5sp, 177K Power Seats are nice!!!
Update: 1) I grounded pin 50 of the ECU (B84) so the ECU now is in the manual transmission mode. There was no wire in the connector at pin 50 so I installed one and put it to ground at the ECU mounting bracket. 2) The ECU is now looking for the neutral sw, which should be pin 78 of the ECU (B84) with 5.0+- 0.5 volts in neutral. I back probed the connector at ping 78 and there is 0 volts. I thought this voltage would be coming from the ECU. HELP with 2) if you have info. Thanks, Larry ______________________________________________________________________ To make a long story short, I put a 97 Impreza 2.2 standard (Engine and Trans) into a 95 Legacy Auto. It runs great but the CEL comes on with P0403 and P1702. I tried the 97 ECU but the car would not start. Anyone figured out how to fool the ECU to thinking the EGR is still there? ECU wiring details would be great, I don't have them. Thanks, in advance!
Need Rear Brake Shields 98 Obw
lmdew replied to blaze's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a nice rust free set in my local you pull it yard. I could send the plates or the complete rear hub, 140K on the car. Shipping might be a little coming from CO 80919 but way less than 109. Lmdew@hotmail.com
1998 Forester wont stay running
lmdew replied to rguyver's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd check to make sure you have the proper fuel pressure, and then check the cam and crank sensor mounting bolts to make sure they are tight and the plugs are good. Double check all the engine wire harness connections and pins in the plugs.
Denver Members, 93 Impreza Sedan Door Cards
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, door panel.
If you see a good set of tan, manual window 93 Impreza Sedan Door Cards in one of the Denver You-pull it yards please let me know. Thanks, Larry Lmdew@hotmail.com
Stripped/Broken Cross Member nut , now what?
lmdew replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThese are very easy to cross thread and once that is done its hard to repair the damage. Drilling first up from the bottom with a 1/4 drill centered in the mount hole, will provide the center for the hole saw as you drill down to remove the old nut and then put in a new one.
Help - 2.2 inplace of a 2.5 accessory belt issues
lmdew replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNever had this problem, make sure the belts are in the correct groves, it's easy to move them over a notch. Is the tensioner on correctly? It should all bolt up without a problem. I've done 6 of theses and never had this problem. Make sure you are using the same year AC Bracket and Tensioner as they are different across some years.
Light grinding noise at right rear wheel
lmdew replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the Rear Diff for lube, does it change when you are in a turn one way or the other, if so its most likely a wheel bearing.
P0303 Cyl#3 misfire HELP!
lmdew replied to pdeltoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can always drop a 95 2.2 into it. Larry
lmdew replied to pdeltoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMark if you want to try the coolant temp sensor I have the one that came off the same engine as the injectors. Larry
Aftermarket Cruise Control???
lmdew replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year, I may have a Subaru cc, that will fit.
97 Outback Engine removal?
lmdew replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the radiator or have it cleaned by a shop.
Nashville, TN to Colorado
Anyone up for a Spring Break Road Trip. Looking for someone to drive a 98 OBS to CO for me. Middle of March to the second week of April would be the time frame for the trip. 5 speed, must have insurance and a good reference or two.
