176
Everything posted by lmdew
Inner Tierod boot just pulls off. Clamp at one end, the inner side slides over a grove in the rack housing. I believe the inner tie rod connection unscrews, but there is a locking tab there you have to take care of. You might find a good used rack cheaper than the tie rod new. The outter tie rod to hub connection can be seperated with a pickle fork or by holding a sledge on one side and hitting the other side with a large hammer, after you pulled the nut of course.
Clean it and see where the oil is leaking from. Slight oil leaks at the head gasket are unlikely to catch fire, they don't leak that much and oil doesn't burn well. Other sources of leaks: Valve cover gaskets, Cam rear cover on the passenger side Power Steering Pump Cam and Crank shaft seals up front Rear Air/Oil Seperator Plate. With the exception of the last one, all can be done with the engine in the car at not much costs.
The car had this code when I got it. I cleared the code, P0400 EGR and it was gone for about 100 miles. A shop had put a new EGR Valve on it before I got it. I checked all the vacuum lines, and changed the following off another 2.5 manifold I had: EGR Valve EGR Solenoid EGR Transducer (round part above and forward of the EGR volve. I also blew out the lines and checked for leaks. I drove it about 30 miles with the D-Check (green connector) hooked up and it passed the check. Three days later (200 miles) , the code is back :>( What to check next? PS I sold this car, but want to fix this problem for the new owner. I thought I had it fixed. Thanks Larry
I've never had a problem on the 2.2 engine. I start at the crank pulley, put it around the Tensioner and over to the Drivers side cam and around the water pump. Then the other side goes on. The cam gear can be rotated slightly to tighten the belt, and then I roll the toothed idler gear in position on the belt and install the bolt. Double check all the timing marks, shift the tensioner over and tighten the bolts and pull the tensioner pin. Double check the timing marks again and turn it over by hand 2X.
I put them in first with a PVC coupling then install the pump being careful of the seal of course. The Passenger cam, I use a small straight slot to go under the lip of the seal and behind it. Sideways pressure usually moves it out. If they are stuck, sometimes driving one side in will move the other out. Last resort, I drill a small hole and thread a drywall or sheet metal screw in the pull it out.
The Evap can will bolt right in. Does it have the same EGR configuration? If not that could be your CEL as well. Check the belt on the PS pump, a slipping belt will cause the symptoms you have as well. The Transmission code could be read by a trans shop or Subaru. You can pull them but its a pain. Search the USMB for the process.
Cheapo replacements. I've done this a couple of times and it works well. Hit the junkyard and get two round head lights low beam and the plugs and about 6" of wiring. Remove the Outback Headlights. Remove the Plastic Grill Remove the Glass foglight lense, they will just pull off from the center of the broken lense. Wear leather gloves. Remove the pivots and screw holding the mount on the reflector Take a dremel tool and cut out the back center of the plastic reflector Take the Low beam and put it in with the connectors on the same line as the mount holes Mark the low beam locating tabs and remove material for those to set into. Silcone seal the new bulbe in The grill can be heated to about 250 to soften the plastic and then put it right over the new bulb. Electrical connections can be made from the used wiring and the old bulb. Cutt the Subaru bulb off the socket. You will see two pins there, use some connectors and solder the low beam wires + & - to the Subaru socket. This makes them a plug and play. Put it all back together. New Low Beams are $8.00
I'm looking for the small coolant hoses for a 95 2.2 that go from the coolant manifold to the Throttle Body, Throttle Body to the IAC and IAC back to the Coolant Manifold. I can't pull them up on 1st Subaru Parts or Rock Auto. Looked under Cooling, Engine .... Thanks Using straight hose works but the bends are not the best.
I wait for the sale and get the NGK for $1.99. On another board here is what one fellow who has tried them in an Outback had to say: Every time I fill up I check the MPG and I am still only seeing the same averages I saw before putting the plugs in. I've had the car since 2003 and the best MPG I ever got BEFORE putting in the plugs was 27 MPG, so anything over that would make me happy. Overall I'm not even getting the estimated 23 MPG that Subaru claims I should have with combination local/highway driving. Only once, on a long trip that was all highway, where I was primarily going down from the mountains into the flatlands did I get 31MPG, but ANYONE would have done better on that leg of my trip. The rest of the trip my MPG was a disappointment even though it was ALL highway. As far as I'm concerned I wasted my money on these plugs.
The hole in the trans housing is the perfect size for a helicoil. Just tap it for a helicoil and you can use a bolt for the bottom as well. I've done this a couple of times. You can do it with the engine and trans installed as you have good access from the bottom of the car. I used the same thread pattern as the engine/trans mount bolts.
Check the front differential for Gear Lube with the Dip Stick on the Passenger Side! If there is none, I'd stop and call the shop that did the work as they must have drained the gear lube. With the car up on jacks, you will not get a correct reading unles you level the car. The Snap ring should hold the stub shaft in, but I've seen them come out. I'd get a new snap ring from Subaru and then reinstall the shaft if the gear lube checks out OK.
