Everything posted by lmdew
need part help please
lmdew replied to rob777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf its a sedan I have the complete assembly for you. $35+ shipping. I'm in CO. Thought you were looking for the tail light which I have but looks like you might be needing the front fender marker.
seating torque converter
lmdew replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1/4" Drive with a 6 point socket, slip a box end wrench over the ratchet handle for extra leverage. When all four bolts are out slide the TC back about a 1/4". Once the engine is out wire the TC back through the starter hole in the trans to keep it engaged. Reverse when you install.
Stub axle fell out, what to do
lmdew replied to DishMan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the front differential for Gear Lube with the Dip Stick on the Passenger Side! If there is none, I'd stop and call the shop that did the work as they must have drained the gear lube. With the car up on jacks, you will not get a correct reading unles you level the car. The Snap ring should hold the stub shaft in, but I've seen them come out. I'd get a new snap ring from Subaru and then reinstall the shaft if the gear lube checks out OK.
Cam/Timing question
lmdew replied to landofopus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake the old belt and cut it. Wrap it around the cam & crank gears and have them overlap in the middle. Pull it tight and then clamp the belt together with a vise grips. You can rotate the cam gear backwards to the timing mark, no problem.
Help ! 2.5 - 2.2 swap, runs poorly on aceleration
lmdew replied to pmichaud's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the swaps I've done, I Bolt the canister up front as well and hook the vac lines up as they were on the 2.2 car. Battery and Alternator good? Hope you get it going!
95 Legacy EGR
lmdew replied to mountaingoatgruff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs far as I know the 95 with automatic transmissions have the EGR. The 95 with the manual transmisson does not!
How To Remove The Crankshaft Sprocket?
lmdew replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA little rust on the shaft/gear will lock it up tight. Start with letting it soak with PB Blaster. Yes, you do not want to pry on the teeth but you can get behind and gently pry it forward. If you get it to move even a little, that's enough to work it back and forth to let the PB Blaster break down the rust. I will slide off. Some of the gears had threaded holes so you could pull them off. Yes, change the o-ring and lock tight the oil pump cover screws.
'97 Impreza runs rough, sputters out
lmdew replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the side timing covers and check the cam gear marks, if they both do not line up the timing has jumped. It hard to see, but if you pull the cam sensor and look down the hole you can just see the mark on the crank gear if the timing is correct all three marks should be line up. My 98 OBS was running rough, finally threw a code for mis-fire on 1&3. I checked many things, but it was the timing that was the cause of the problem. Autozone or any auto parts place will read the codes for free. You can get code readers for $90 or less these days which is cheaper than the tow for some folks.
97 outback tranny really need help
lmdew replied to subaruguru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTC is not in the last 1/4". If it's all the way engaged, you should pull it forward about an1/8" or so when you install the bolts into the flex plate. Don't start it this way, it will trash the trans! Sorry, but as far a I know you have to drop it back out to fix this. You may be able to get it in the last notch by unbolting it and sliding it back to the end of the studs, that should give you enough room to work it in IF YOUR LUCKY
Lost power steering, serpentine belt and pulleys all OK - could pump have sheared?
lmdew replied to welly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are easy to change. If you can draw all of the fluid out of the tank it makes a cleaner job, otherwise use lots of rags. Pull the belt - you've done that Crack the front line bolt a little There are 3 12mm bolts you can get to through the holes in the pulley, remove them. Remove the bolt on the rear bracket if you have one Remove the bolt from the front line Remove the clamps from the rear hose and pull off the pump If you are getting a used pump: Replace the o-ring between the pump and the tank (access the bolts from the tank) Clean the tank while you have it off Install the pump in reverse order Fill to the correct level Run the car and turn the wheel stop to stop to bleed any air out.
running on 3 cylinders
lmdew replied to mattejb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrop a used 2.2 from a 95 auto in there for < $500 and you'll save that much in gas! What's going to happen when the car dies and you have no transportation? Walking into a dealer in need is no way to get the best deal.
hey guys. anyone have an alternator?
lmdew replied to EA82Loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$40 shipped. I need to know if you have the round or square field plug.
a stupid question for one of the gurus?
lmdew replied to Bserk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe its a viscous coupling in the transmission. Strickly mechanical, it either works or it not. Nothing you can do but replace it if it fails.
OBW struts on Legacy sedan?
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost of the lift comes from the 1 1/2 or so in height the bottom spring seat is raised. You could use the stock sedan springs with the outback struts.
Bad alternator?
lmdew replied to newsoobdude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to try a used alt, I have several. $45 shipped.
93 Impreza not starting
lmdew replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnplug the fuel pump under the seat, crank the car for 20 seconds or so to release some of the fuel pressure. You will need a 5/16" tee fitting, about 6" of fuel line. Go on the engine side of the fuel filter in the engine compartment and tee in the fuel pressure gauge. Hook up the fuel pump connector and crank the car over. You should see fuel pressure rise as the system pressurizes. I don't have the exact PSI but anything over 30 should be good.
1998 impreza outback sport
lmdew replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll but the SVX and STI wheels will fit, as they are 5x100 mm. I have a radiator, I'm in CO. Larry
lmdew replied to Dangerdave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny CEL or codes in the computer. It could be most anything. Check for Spark Check fuel pressure Can you hear the pump run, you don't drop the tank the pump is pulled from the top access cover, Under the back seat or in the trunk.
Excessive wear on throw out bearing tube
lmdew replied to mtnman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen this before, I smooth them out as much as possible and put a light coat of grease on the shaft. Most of the rattle was most likely from the TOB and Fork not being held together with the spring pins.
98 OBS running rough 2.2 5sp
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep I replaced both of them. Thanks Larry
Oil Pump Cover Plate Screws backing out
I've done a few Timing belts and I've started making it part of the process to pull the oil pump and lock tight the screws, change the crank seal and Oil pump o-ring. The last 2 I've done 3 of the screws were backed out over a 1/8". I think once the threads have been cleaned and the screws put in with lock tight it should be a finial fix. Has anyone seen the problem repeat?
Cruise Control Fixed
My Cruise stopped working a while ago. Today I was checking it out and the clutch switch was not being activated because the little rubber bumper on the brake box was missing. The hole for the bumper lined up with the switch pin so it was not closing the switch. 98 Impreza OBS but I suspect others are the same.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt was off a tooth on both cams, so I suspect the crank jumped a tooth. New Belt and It's running Great. Thanks for the feedback. Larry
fuel smell and surging idle issue
lmdew replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to be safe, I'd pull the fuel pump access cover in the trunk or behind the rear seat in a wagon and make sure the fuel lines are not leaking.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCompression test 160 all the way around. 6200' here in Colorado Springs. I pulled the outside timing covers looks like its a tooth off. I will come apart Sat.
