Everything posted by lmdew
Yikes ! 2003 something big happened
lmdew replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStay Healthy out there USMB!
2006 Forester Headlight H1 - LED?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOrdered some standare Hella's. Please let me know how you like them down the road. Thanks, Larrry
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust turn on the Headlights to disable DRL?
The little Day Time headlight bulb H1. Anyone find a good LED replacement? Thanks
Gas Filler neck tube advice
lmdew replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGreat job. Glad you got it done.
96 impreza 2.2 water pump replacement help
lmdew replied to Bigsky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep lots of info out there. Easy to do, just take your time. Check out you tube has many videos that show timing belt replacement. Since you have to drain the coolant anyway, may as well pull the radiator and fans. More room to work.
caliper stuck?
lmdew replied to mdub71's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you get a jack under the front to jack and spin the wheels by hand?
still hunting the front end shake and lost as to where to go.
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you feel it in the lower Driver's seat? Rear Brake rotor.
lmdew replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI take a 1" step drill and drill a series of holes in the plastic guard so the rocks, dirt... can drop out. Others leave it off completely.
lmdew replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLove CO, never see rust like that.
Broken exhaust flange
lmdew replied to StephenA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey have the wrong bolts in the flange. There is a stepped bolt that allows some spring movement and flex. The step flange of the bolt bottom on the front flange.
Electrical problem
lmdew replied to vaidas1230's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRecheck your connection that you made and anything disconnected. Pretty sure it's a maintenance induced fault. Recheck the fuses as well.
Rust fix on hood needed!
lmdew replied to cspurli2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com Find a good used Subaru hood. It will most likely be less than having it painted over and over again.
2006 forester hood latch
lmdew replied to smartin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you got it!
05 LL Bean Outback - Not charging
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the feedback.
What do you think? Bad Alternator? https://fortcollins.craigslist.org/cto/d/fort-collins-2005-subaru-outback-ll/7090829632.html I've been thinking of a H6 for a long time.
abs light on after brake fluid leak
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaintenance History should always be reviewed/considered. Glad you found it.
lmdew replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI always get the clamp off. Take a small screwdriver and work in into the hose. Start the WD-40 spray as I work the screwdriver all the way around the hose. That helps a bunch. It will still be a bugger.
lmdew replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe big hose going to the tank will be fine. You may need a new clamp on it. Use some WD-40 or something like it to lube the hose before you pull the old fill tube off and when you put the new one in. It can be a bugger.
1992 Legacy MT speedometer issue
lmdew replied to heymulderitsme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you cleared the codes?
97 outback start die, repeat
lmdew replied to alykat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Subaru ones are usually pretty good. It's the aftermarket ones I always pull out.
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the newer 2001 has the sensor inside the hub. The tone ring is on the end of the half shaft so you shouldn't have damaged it. You may have snagged the harness coming down the strut. I'd start there.
lmdew replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour best option is to remove the plastic cover and do a good inspection. I may have a good rust free CO tube for you. The ones I have just have the single 1/2 dia tube coming off the top. PM your email and I can send you a pic.
lmdew replied to alykat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe IAC hose is not connected to the airbox. I've had shops to this more than once. Easy fix, the 1" dia black IAC air hose is thick/stiff but it can be bent enough to get it back on the nipple without removing the upper half of the air filter box.
lmdew replied to alykat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1+ disconnected IAC hose, the 1" dia. one going to the air filter box. Had the air filter cover been removed before this started?
