Everything posted by Qman
2WD fuel tank in 4WD hatch?
It should fit with a true 4" kit. Only way to be sure is... ...to do it.
Summer meets Winter!
Very nice Glenn. I am jealous as mine is broken right now.
Looking for The best..
Very professional of both of you. Your points are the basics of it as well. That was where my long-winded post was trying to go. I believe that would be similar to PK's response as well.
Cheap and inexpensive are contradicitions of terms. Cheap will never remain inexpensive. I have built my own design. I have ran PK/BYB lifts and I have also co-built and designed my own transfercase/solid rear axle lift. I have some experience to back my opinions. Scrap, you know the ease of building your own is slightly misquoted. Who built your strut extensions and why? Building your own lift is easy for everything but the strut extensions. These have to be correct or the camber will be off and you'll eat tires and front axles. Even my first lift had some camber issues. It did however last for almost 5 yrs without being altered or modified. PK/BYB, this is the design that migrated across the big pond from Australia. It has been in use for about 20yrs now. Minor modifications have been made over the yrs but it is essentially the same kit that has to be nearing one million miles travelled(combined of course). AA, the new kids on the block, deserve credit for perseverance for sure. Their lifts have gone through some changes in the short time they have been here. They have listened to input, both positive and negative, and made changes accordingly. They have jumped in with both feet on a lot of Subaru accessories. But, they are finding what most people already knew. It is a very limited market which they saturated far too quickly. When are you cutting it off again? SJR, has taken an entirely different approach to lifts. Same basic theory but a new twist to things. He uses cast aluminum instead of square tube steel or aluminum block. Still too new for evaluation of longevity but they seem to be holding up. Why am I doing this you ask? Let me tell you why. If you sit back and listen to everyone carrying on about who is better and so on you'll never make a decision. All 3 are west coast manufactured. All three will stand behind their products. All three will sell you something that will work. You will have to do your own research and come to your own conclusions on this one. It is your money btw and needs to be a decision you are comfortable with.
Reiters Pit March 18 NorthWest Washington Near Monroe
NIce pics. Just so everyone knows, it was me who broke Turbones axle. I was driving and doing some crawly stuff. It didn't takle much to snap it as I think it was fatigued already. Finished the "hobbit trail" in 3 wheel drive. BTW, Rob, come over and we'll see what I got left in the pile.
Cant get engine mounts to line up! (EA82T)
Loosen the bolt on the upper trans mount(dog bone).
what else?? 1.8-2.2
The engine I used was supposed to be from a '96 OBW. Dual port and all. I can't answer the question on the head. Use your intake and wiring. Swap over the injectors from the 2.2 into your intake manifold. Make sure to loosen the dog bone mount when you reinstalled the new engine. It will drop right in. If you have access to the 2.2 exhaust use it all. The mid and exhaust pipes are smaller diameter on the 1.8. Good luck.
Bolt lengths for 2" lift 83 and 86 wagons
Might find it neccessary to utilize jackstands, spanners and sockets for this one!
heading through WA this week
Say hi for me as well. Graveyard and social events don't mix well.
Bleeding MC...
If I thought you to be an expert I would not have replied. Brakes are a very sensitive repair. Make a mistake and someone can get hurt or worse. It should be a requirement to bleed at the wheels as well. Any time you open a brake line it should be bled at the wheels.
Bleeding MC...
If I thought you were an expert at this I wouldn't have posted. Basic bleeding procedures should be know if you are replacing the hydraulic parts in your brake system. If you make mistakes with it people can be hurt or even worst.
Toughening the weak stock front suspension - EA81 / MY
Many people have come to me asking the same question. I have given them all the same answer. As the car sits right now you know what is going to bend/break. Once you start "beefing" things up you know do not know where the break/bending points will be. Much easier to carry a couple of radius rods and to replace them on the trail then to try and carry an entire front end. When I moved the front end forward 2 1/2" on my Brat I had to stretch the rods. I sleeved them and when I hit something hard enough to bend something it moved the rod pocket instead of bending the rod. Much more work involved in that repair. If you can not drive through obstacles without hammering it maybe you should find different places to go. We drive through heavily rocked trails and don't seem to have the damage you have from sand and mud.
4X4 swapmeet, Puyallup fairgrounds this coming weekend
Not much for the average Subaru owner. There are vendor and private party booths with new and used parts for sale. Occasionally there will be a set of jump seats for sale. Usually a good price on winches and batteries and other offroad supplies.
Bleeding MC...
Power bleeder= air or electricity powered.
Bleeding MC...
You'll need 4 hoses to do it on the bench or a power bleeder on the car.
Attn 4x4 Welder
Clean out you inbox(PM's). Need to know when your coming over.
79 1600 lift?
And blow up axles like cheap balloons!
How to properly reset a rear torsion bar on ea81?
You may have a bad torsion bar Matt. Considerring that your wagon shouldn't have had the bar reclocked. Pull one from PaP. BTW, did you get the Legacy home OK?
who makes the 5speed swap crosmemeberS
There is a bit more to it. I can have them made. Give me a day and I'll let you know the price. It is a direct bolt in and you use the 5sp mounts and all. Works great!
how much did you shave your heads
I personally have built two EA81's in the lsat couple of years. Both run 1600 pistons, webers, large Delta cams and one was shaved .015 and the other .020. I have had no issues with either. Both generate good power and torque through out the power band.
Anyone seen the new SubieSport?
First and foremost you should know that they use a subscription company to do their initial subscription and renewals. So before you beat up Ryan and the rest of the folks at SubieSport contact them letting them know that you have not received your magazine and your subscription info. Maybe they can solve the problem for you. Keep in mind that yelling at them probably will not bring the results you al want.
The best line from pge 23, "does your mother know..." Did they come out or did you just send them pics and words? They have agreed to cover the Hatch Patrol on an outing in the spring or summer. Definitely pays to be local.
How many of you are heading to Ken's this weekend?
You could probably do both if you REALLY wanted to see us. For a guy who has prided himself on being a smartass for as long as I've known him this is quite a contradiction. J/K
:lol: http://www.ultimatesubaru.org/forum/showthread.php?t=53505
Flywheel
EA81's had different sized flywheels for 2 and 4 wheel drive. EA82 did not. Only difference will be the pressure plates.
