Everything posted by TomRhere
Picture Request: Stock Height Loyale with 185/70-14 or 195/70-14
185/70-14 = 24.19" 195/70-14 = 24.74" Here's a pic of a 195/65-14 23.98" on my '88 Wagon. These tires are 7" across tread. Lots of room for a larger tire. Don't have close-up of front, but do have whole Wagon pic.
Hot-Rodding a Brat in two stages - Suggestions?
Just pretend it's not yours and you just stole it. Get out there and beat the snot out of it. You'll be surprised at how well it will like that. I've ran a few of my EA81's up to 60 mph in 3rd, that's spinning things pretty good. Keep oil in them, and keep coolant level good, and these little engines will run a long time. Good solid lower end in them. Yes, there's been a few what threw a rod, but that is as rare as hen's teeth.
1991 Extended Range loyale Wagon - additional fuel TANKS
Yeah, it's a 15.9 gallon tank in the EA82 bodied vehicles. Being yours is SPFI and Manual trans, you should be getting 32+ MPG. Anything under say 28 MPG is cause to start looking for the reason(s). There is a few things to throw gas mileage off, so one must do some investigating. Brakes dragging, wheel bearing(s) not quite right on fitment, exhaust restrictions, CTS (coolant temp sensor) faulty, cam timing, disty timing, tire pressure, front-end alignment, yada, yada, yada
Hood bowed from stiff hinges
Straightened a few hoods by cutting a length of structural lumber to fit between the lip of where the fender bolts on under the hood. Place it forward of the bend and use your body weight to to push the bend out by hand. If the support section of the hood is kinked any, you will have to resort to rougher methods, then do as JesZek says with the reinforcement.
all the way from WA .................... australia
Welcome to the Board!! Got a few Members on here from that (rather large) Island I so want to go to......
Just a quick Aloha!
Good to hear from you!!!
86 BRAT custom headlight integration
http://jdmfsm.info/Auto/Japan/Subaru/--Old%20Models--/ That link will get you to a downloadable FSM for the '83 Models. The Electrical Section is missing some pages, but the headlight wiring is there.
- Emergency parts kit ideas for a long roadtrip in a GL
1975subaru
Rust? Hell,,, that an everyday driver here in Michigan
- Looking for a manual for 1989 -1991 Xt6 Engines
- 94 Loyale Coolant Leak
Upgrading 87 Brat Headlamps
I found them on the "HELP" rack at the parts store. Actually had to stop at a few stores to get enough of them. Don't have the part number, but the ones with the 3/8" nut insert are the ones you want.
TomRHere's '88 GL 4WD Wagon
Seems that way... Getting tired of all of it.
spfi / ea81 distributor drilling
Fairly sure I kept the same orientation when I converted a carbed EA82 disty over to use in an EA81 engine.
- 8 replies
- orientation
- placement
- timing
- dizzy
Tagged with:
Don't know why. Not in the mood to tear into it. I installed a resealed EA82 oil-pump. The ER27 oil-pump uses a different shaped Mickey Mouse seal, didn't have one of those. Oil pressure was near 50 on the gauge at start up, dropped as engine warmed up. #2 exhaust is making the most noise, with the rest of them on that side making some noise. The #1-#3 side is making noise also.
Seems the upper end on both sides aren't getting any oil. That's it,,,, I'm done................. Someone needs to show-up here with two car-haulers/pick-up trucks, maybe a 3rd truck. And take all of this away. More serious than a heart-attack on this. It will all go to the local scraper guy if no one shows here.
OK. Fast forward about 1 hour. Battery was getting low, so decided to hook up the charger for a bit and have a beer. AaaaaaaaaaaaaaHhhhhhhhhhhh! Got's no beer here........ Quick trip to store took care of that issue. Get back here, put beer in fridge, head out here to garage. Beer in hand of course. Turned the key and she fired right up. WTH?? Maybe she knew I didn't have a celebratory beer at hand. Don't know.. Let her run for awhile, checking coolant temp, and for any signs of leaks anywhere. All good. Sounded good, nice and smooth idle. Got the timing set proper. Let her run a bit more...... Holy Crap,,,, what is that noise from??????? Severe noise from disty-side valve cover. More than I remember TOD sounding like. Question is; Why? Investigation follows. After it cools down that is.
Yesterday, I got engine in and all hooked up minus radiator/hoses and Y-pipe. Got out here earlier this AM, and got all of that squared away. Been trying for the last hour or so to get it started. No joy there. Wants to, just won't fire off and run. Going over everything now. Got spark, T-Belt timing is good, disty timing appears to be good, have fuel to Throttle-body. So I'm currently "In Search Of" the issue. Reading prior posts in here to see if there's a related issue. Thinking there was at one point. More later......
New owner (and aspiring home mechanic) of a 1989 DL wagon
Welcome to the Board. Myself, I would pull the rear drums off for inspection of things. Making sure that the adjuster is free and able to do it's thing. Lot's of people don't do the proper backing-up/braking needed for the self-adjusters to do what they were intended for.
Rebuilding ea81 - which bearings/rings to buy?
EA81-EA82-ER27 share the same main/rod bearings. Same rods and piston rings also.
Brat Build!
Really hated to read about it being wrecked. But glad that you weren't hurt. Possible replacement for you, http://www.ultimatesubaru.org/forum/topic/159173-rolling-shell-82-brat/
Okay..... Fast-forward a couple months...................... Engine is totally re-assembled and ready to drop back down where it belongs. Should have it fired up late tomorrow.
Turbo to non turbo engine
MPFI and SPFI heads are different. So you would need to swap them between engines, use the SPFI cams though, as Turbo cams don't work so well without the Turbo.
Ea82 oil pump question?
Faces "out" as you're looking at the backside of the pump. Faces "in" would be towards the pump, away from you
never thought of it that way Jono.
