ATTN Legacy777 - fwd to awd swap- Important note for all who've looked at this thread
Legacy777 replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I would think the torque converters are the same. As for electrical, I believe the only thing different on the AWD's is the duty c solenoid. So you should just verify that the pins for that sensor is there. I'd have to look at things more closely, to be absolutely sure, but you should be able to d/l the tcu i/o from my server.
93 Legacy fuel leak
Legacy777 replied to gen1lover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, the access panels are in the trunk in the front.
Feels like I'm swaying in the wind
Legacy777 replied to deiscient's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your suspension components are all ok, then I'd suspect the tires themself. If they have softer sidewalls, the car may sway slightly and not feel as planted. Also, if your struts are still original, they are probably shot, and in need of replacing. That will go a long ways to improve the ride/handling/feel of the car. I'd recommend KYB GR2's.
Idle Speed Motor
Legacy777 replied to jsciccarelli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwelcome
Oil Pressure, yes or no
Legacy777 replied to swelebny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXput a little vasoline in the hole and on the o-ring. That should help keep it from moving. That or everything needs to be relatively dry/clean and the o-ring should stay put.
Need Manual Tranny 91 Leg LS
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to do the swap, I'd suggest finding a cheap first gen legacy to swap all the stuff over from. It'll be much cheaper to buy the whole car then to get all the parts piece-meal.
Idle Speed Motor
Legacy777 replied to jsciccarelli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe idle motor is on top of the throttle body. It may just need to be cleaned. It's possible the plunger is getting stuck and causing the check engine light. Or that the electrical connections are not good. You may want to post in the meet & greet forum to see if there's anyone around that can give you a recommendation on a mechanic. You may also want to try the regional forums on NASIOC, http://forums.nasioc.com/forums . There's bound to be some other impreza owners near you that can recommend a mechanic.
Legacy777 replied to swelebny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may still have oil flow, but low pressure. If you're getting some pressure at idle, and "normal" pressure at higher rpms to fill the lifters, and the lifters don't leak....I wouldn't necessarily say they are going to make noise. If the sender is working correctly, what I'd lean towards is the o-ring between the block & oil pump not being aligned/installed properly during the oil pump work. I'd recommend pulling the oil pump back off and checking things.
92 legacy needs a new muffler
Legacy777 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMRT is a speed shop in Australia. They sell performance parts for subarus. I've got one of there mufflers I was running on my car when it was normally aspirated. I've got a different exhaust on there now that I swapped in a turbo engine.
Legacy Production Numbers from Subaru USA
Legacy777 replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXahh ok.
Camber/ Allignment Question?
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah....that's why I have my camber set at -1 deg all the way around....because of the way I drive Plus it improves handling.
05 outback 2.5L - pcv valve quirk?
Legacy777 replied to bergman05's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're always going to have a little bit of oil residue and stuff in the PCV system....there's just no way around it. You could put in a separate oil catch can, but unless you have a turbo'd engine, I wouldn't really worry about it.
Legacy777 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad you're not closer. I'd give ya the MRT muffler I have for free!
Legacy777 replied to swelebny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible some gunk got stuck in the oil pressure switch. Let's hope that's what happened, or that it's bad, because the oil light comes on when oil pressure is in the single digits. If the engine was run that long with that low of oil pressure....bad things are sure to happen.
Legacy777 replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHonestly.....Sometimes I think the subaru community has better knowledge then subaru does themself I've already given my piece on the numbers not being accurate, so I'm not going to bother.... But they once again give incorrect information. There were most definitely first gen legacies 1990-1994 that were built in the USA. I owned one and stole parts for my swap from it. You can email Subaru again if you'd like, but I think it's a futile battle.
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA longer bolt won't really do anything. You could get an additional camber bolt and put it in the bottom bolt spot. here's another camber bolt that will work http://z1auto.com/prodmore.asp?model=wrx&cat=handling&prodid=223
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou "should" have a camber bolt. Did it get replaced with a non-camber bolt?
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOur cars have a camber bolt already. It's the top bolt holding the bottom part of the strut to the spindle. They either don't know this, or they're trying to screw you. Either way, camber bolts don't cost $100!! If they have maxed out the stock camber bolt, and still can't get it aligned, then it sounds like you got something bent underneath. Personally, I'd go somewhere else.
Howling MT trans.
Legacy777 replied to fiddler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, you've probably damaged the viscous coupling on the center diff. Whether you have metal chunks floating around is unknown. Get four IDENTICAL size and make tires on that car.
Throttle Body Warning!
Legacy777 replied to qjoshh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeafoam is O2 sensor safe.....and is an extremely good product/cleaner.
finding vss wire in 2005 Subaru Forester
Legacy777 replied to flatoutcars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to ask your local subaru dealership if they have a wiring diagram they could copy for you. I believe you're out of the USA, but you may be able to d/l the info you need from here http://techinfo.subaru.com
loooose shifter
The bushings may be an issue, but your specific issue is the centering spring is not there. You can see it in this pic http://www.main.experiencetherave.com:8080/subaru/images/jointcustom/DCP_4183.JPG I believe there is a thread in the reviews forum on www.bbs.legacycentral.org that is titled "(correct part #) appreciation thread" I don't recall the part #, but it's in the thread.
New member with a question
Legacy777 replied to Soobeenoobee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried Subaru?
'95 Legacy Sedan .... swap 5spd tranny?
Legacy777 replied to FlyB0y's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should work. You'll want to verify that the final drive ratio is the same. Also, are you getting the 91 legacy as a donor car, or just getting the transmission. There's a bit of little stuff that you'll need, so it'd be a good idea to get a donor car, or have a good junkyard near by.
SD Shop, bad door locks
Legacy777 replied to wyosub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....not sure what's up with the locks. You may want to post in the meet & greet forum as well.
