Tiny sunroof leak
Legacy777 replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd make sure the drains are clear first.....then if you still have issues, look at the seal.
No heat 93 leg
Legacy777 replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad it was an easy fix
Cold weather and slow speedometer
Legacy777 replied to wyosub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe grease in the speedo cable housing gets thicker as it gets cold. That may be a cause. I know when I lived in PA, the cable made noise until it warmed up when it got cold out
help for a 99 outback
Legacy777 replied to indianaoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to look into replacing your coolant temp sensor.
91 Legacy 4 speed auto 2wd ???
Legacy777 replied to mtnman38's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah you need to change the gas tank when going from FWD to AWD. The FWD to AWD part really wasn't that bad. The AT to MT is a little more involved since there's more electrical issues to deal with, but overall it's not too bad. I could've done two AWD & 5MT conversions in the time it took me to work out all the issues with my EJ22T rebuild and swap.
Disable 2006 Baja Factory Alarm?
Legacy777 replied to Jim Padgett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think if you disable the factory alarm, you may lose the remote door opener. Will the remote start not work with the alarm?
Screwy Display - 05 Legacy
Legacy777 replied to hockeylvr93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 05 legacy does have some quirks it seems with the illumination control and radio. The radio and climate control system is all tied together. I've got a friend who has one, and has very similar issues. I'd defintely check out the legacygt forums. I know there are people on there that have gone through the gammit, and may have some ideas. I'd personally try and get subaru to fix things.....I'd probably try and contact them directly, since the dealer doesn't sound too competent.
Map vs. Maf air systems
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the car chassis is MAF based, and you have all the sensors for the MAF system, I would try and get a MAF based ECU.
Need good tech advice on tranny swap
Legacy777 replied to 1Quickgn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should work. It's a public server, not private, so the IP address, and everything else should be fine. Try it again, and if you still can't get to it, let me know.
'05 Legacy Wagon Radio/iPod
Legacy777 replied to justinbeck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to search the board. I think it's been discussed before. If not, I know it has been discussed on www.legacygt.com/forums
No heat 93 leg
Legacy777 replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe plastic stuff on the legacy isn't too bad. Try some of the newer-newer cars. To get the glove box off, there's two screws underneath. It's a piece of cake.
No heat 93 leg
Legacy777 replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom the factory it is does not have a coolant bypass valve like some manufacturers use to control heating.
EJ22 thermostat help
Legacy777 replied to gen1lover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the n/a EJ22's it doesn't really matter since the thermostat is positioned veritcally.
Block heater left on all weekend :/
Legacy777 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust something I want to bring up. These cars have fuel injection....if everything is working properly, they will start! The controls, sensors, etc are there to account for the lower temps and the addition of extra fuel. In very cold temps, they should still start. However in very cold temps where you start running into issues is with the fluids. If you have a proper anti-freeze/water mix, you're safe down to like -50 deg or something crazy....so that's not really an issue in my mind. The oil however will start to thicken up. It shouldn't keep the car from starting, however it can making cranking more difficult, and can hinder lubrication at startup. Synthetic oils do not thicken up as much, and are better for extreme cold temps. The block heater is going to help keep the fluids in the engine warmer then the outside. I question how effective it's going to be on the oil in the oil pan to help cold start and thick oil viscosity. Lastly is the battery, battery performance does decrease when temperature drops, and that in combination with the thicker oil (harder to turn the engine), etc may keep the car from starting properly. I think the big things you should do if you live in really cold climates is get a battery warmer, block heater isn't a bad idea, however I'm not 100% sold on their effectiveness alone. But a block heater and an oil pan warmer would definitely be beneficial. Finally, run synthetic fluids.
No heat 93 leg
Legacy777 replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's no bypass on the heater core. Engine coolant always is circulating. If you remove the glove box, you should be able to see where the cable goes to the box and flapper door. The little end probably broke off.
Why does it do this?
Legacy777 replied to yuyu2222's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour coolant temp sensor is probably not good. As long as the temp isn't insanely cold, like -30 deg, the engine should start fine. I'd suggest replacing the coolant temp sensor. It can be had for around $20 at www.subarugenuineparts.com
Cold in Denver - Car won't start
Legacy777 replied to subdenver's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup....I went down this very same road It'll act up again probably....
Legacy777 replied to indianaoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsportsfan, when they rebuilt your engine, did they replace the sensors with new ones, or reuse the existing? How long on average does it take for you car to warm up in the morning?
1990 Legacy wagon shutting off
Legacy777 replied to GregS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile I'm not sure the knock sensor would cause the car to shut off....it will cause you issues. I'd suggest clearing the codes, drive the car, and see what codes come back. You'll still want to probably replace the knock sensor. As mentioned, they have a new revisions with a different color plug/connector. White is the new color, grey is the old color. The canister purge solenoid can cause some issues, especially around idle speed if it's stuck open.
Nokian WR Specific Question(s)
Legacy777 replied to vtphoto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat does the road hazard plan give you? I've never bought a separate road hazard plan. I'd definitely recommend discount because they're everywhere and will repair a tire if needed for free. Not sure if they still make them, but the yokohama guardex's I had when I was in PA were really good....about on par with the blizzacks.
Cylinder block plug?
Legacy777 replied to wyosub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAutozone baby.....you get three sizes....for like 10 bucks. You can't beat that.....and I tried sears, home depot, lowes, etc. None of them had anything.
Richard Burns tribute on todays episode of Top Gear (link inside)
Legacy777 replied to Kostamojen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease continue any discussion on this topic in the OT thread http://www.ultimatesubaru.org/forum/showthread.php?t=48185 thanks
Legacy777 replied to subdenver's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's your contacts on the starter. Next time it won't start, stick your head outside of the window and listen. You'll more then likely hear clicking. When I had my issues, I thought I didn't hear a clicking noise. It took sticking my head out the window/leaving the door open when I tried to start it to hear the clicking.
Legacy777 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou didn't hurt anything.
legacy impreza clutch interchange?
Legacy777 replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe turbo clutch setup is a "pull" style clutch. The lever arm pulls on the throw out bearing that is attached to the pressure plate, which then pulls on the fingers of the pressure plate, and eliminates the clamping force on the clutch disc....aka disengages the clutch. The n/a clutch setup is a "push" style clutch. The lever arm pushes on the throw out bearing, which pushes on the center part of the pressure plate/fingers, and eliminates the clamping force on the clutch disc....aka disengages the clutch. Here's a blow up diagram of the turbo clutch. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_turbo_clutch_blowup.jpg I don't have the n/a scanned. I'm pretty sure the clutch discs are not interchangable between the pull & push style transmissions. I can double check part #'s, but I doubt they're the same.
