My first T-Belt
Legacy777 replied to beezer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats. Yeah the belt can be a little tricky to get on some times. The camshaft seals can be a pain too. Once you've got the technique down, it's pretty easy though.
DADs 98 outback project
Legacy777 replied to PeterD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah those cylinders look pretty good for 180k.
Legacy Turbo ECU Identification
Legacy777 replied to greggearhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the ECU This is the TCU
AWD not disengaging to FWD
Legacy777 replied to bobbyboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the key in the ON position, I would test that you have 12v on one side of the connector for the FWD fuse. If you do have 12v there, I'd suspect something wrong with the duty c solenoid. If you don't have 12v there, you may want to check some fuses. Regardless, if he drove it until there was clunking, he may have done irrepairable damage to the AWD system.
Impreza 2.0 Turbo hesitating!!!
Legacy777 replied to slasherkill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo your problems/hesitation started after you added the intake OR the BOV? Have you tried going back to stock and see if that fixes your problems?
Best deal on new 2.2 TB pulleys
Legacy777 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll have to get the pullies at a dealer. www.subarugenuineparts.com has beat out 1stsubaru & subaruparts for prices
'92 Legacy, need torque number
Legacy777 replied to beezer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThese pics may help. http://www.main.experiencetherave.com:8080/subaru/images/reardiff/ I seem to recall that one or two of the bolts go through into the housing of the diff, and may need some silicone sealant on them, howver I may be completely off base.
94 liberty problem
Legacy777 replied to smile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the car run ok when warm? I'd agree it sort of sounds like a coolant temp sensor.
Knock sensor deterioration
Legacy777 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt was like the early-mid 90's when things changed
Steering issues
Legacy777 replied to Happyhighguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to jack up the front end, put your hands on the struts and other suspension components and try and move them, see if anything is loose
EJ22 Turbo ?'s
ej22t motors came in the 91-94 turbo legacies. Stock hp was 165 with around 180 ft-lbs of torque.
EJ22T Carbon in Turbo
Legacy777 replied to vick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it's possible that you can have an oil seal leakage. I'm not sure the type of oil seal that's in there though.
Legacy777 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitto on the old style replacement. But yeah, if it's cracked, you should replace it.
rebuilt 2.5 1 & 2 cylinder problems
Legacy777 replied to sportsfan1026's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd suggest pulling the codes. You could be searching a completely different system then where the actual problem is.
Clutch Kit question w/ part # (ATTN: Subie gal)
Legacy777 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe PDM kits for the n/a's have been out there and working pretty well for people.
OK for the geeks out there OBD reader
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can use the instructions on my site for the codes. You can use this as a scan tool for OBD1 on the first gen legacies http://www.graphics.cornell.edu/~v/bcbfscan/
Legacy777 replied to vick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe carbon would only be on the turbine side. Just run some sea foam through. I wouldn't really worry about it though. Turbine temps get pretty high and cook stuff off.
Noisy Fan
Legacy777 replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can remove the fan and clean the junk out of there. You need to remove the glove box and it should be like 3 screws holding the fan in the blower housing.
94 Legacy Auto Trannie Swap....Help/Advice Needed
Legacy777 replied to jetboy12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have the model number? It should be TZ or TY something.
stink
Legacy777 replied to wyosub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBe wary....if they set up camp....they could've chewed through other stuff, and wires....which could cause you lots of problems....not to mention....there's probably dead mice in there....
GT Legacy 93 - Acceleration, Pulley & Turbo
Legacy777 replied to sandoz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend checking out www.rslibertyclub.org/forums and www.bbs.legacycentral.org
2006 legacy 2.5i special edition
Legacy777 replied to amcomins's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmay want to also check out www.legacygt.com/forums
blown rear strut and shot strut mount 90 legacy 2wd sedan
Legacy777 replied to rednotch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're probably going to have to go to the dealer, or try and find one from a junkyard. The rear strut mounts from any 90 & 91 legacy sedan or wagon & AWD or FWD will work.
Low town mileage & How to inspect fuel injectors on '92 Legacy
Legacy777 replied to ronrhodes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're only driving a mile or two, you're going to get considerable less mileage then what the "standard" city mpg is. I drive about 1-2 miles to work every day in my nissan truck, and the mileage is absolutely horrible, yet if I drive on the highway, I get great mileage. I really doubt anything is wrong with your car. At most, I'd recommend you change your thermostat....and/or possibly the coolant temp sensor. I just really can't see anything being wrong with your injectors.
Looking for a good intake
Legacy777 replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend keeping your stock intake. Just remove the resonator in the fender.
