8
AC charge
Legacy777 replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The expansion valve is basically an orifice. When you're low on refrigerent, it has to cut pressure quite a bit to maintain a cool temperature. The larger the pressure cut, the more noise you're going to get. Add some refrigerent and it should go away. I'm going to try and add some to my truck tonight. -
AC charge
That's sort of loaded question, because in order to properly explain it I have to explain the entire ac system Anyway, here's a quick and dirty of the parts in your ac system, and how they work. The following is the order in which the refrigerent & oil go in. Compressor Condensor Receiver/drier Expansion Valve Evaporator The refrigerent is in gas form, and goes through the compressor, its pressure increases as well as its temperature. The refrigerent then goes through the condensor where it loses heat, and condenses into a liquid. The reciever is more or less a filter, and contains dessicant to help remove moisture. Next you have the expansion valve. The valve cuts the pressure & temperature of the refrigerent. The refrigerent also goes from liquid to gas through the valve. The cold refrigerent then goes through the evaporator where the air blows across it to get cold and go into the cabin. Then the process repeats. there's more theory behind it, but that's the jist of it. Here's a link with a pic http://home.howstuffworks.com/ac2.htm -
AC charge
My expansion valve is hissing at me after my recharge. It probably needs a little more refrigerent. -
AC charge
You guys need to let the refrigerent cans sit there for a little while. Set them in the engine bay where it's hot. It helps get most of the refrigerent out. I just redid my truck on saturday. Pulled a vacuum for about 30-45 min, Let the one can put as much as it could in without the engine running. When it stablized, I turned on the engine, and let it draw the refrigerent out of the can. Like I said, be patient. -
Carl, I believe there is a sport shift on the autos. However I can't really say how they are. I'd recommend just goin and test drive the different models. You're in the Dallas area right? Give Subaru of Dallas a try. Talk to Kevin Heist. He's one of the guys on the texas subaru boards on nasioc. Tell him I told you to see him. He "should" be able to work with you to get a pretty good price.
Atf????
Legacy777 replied to mtbshark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Redline D4 ATF is good stuff. -
You don't need to align anything for TDC. You align the marks on the cams and crank to the marks on the cover and oil pump. Are you sure you're using the correct mark on the crank gear. Don't use the arrrow on the front of the gear. Use the mark on the back of the one tab. Here's pics of my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/ Factory manual scans for the timing belt job http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
The canister purge solenoid can intermittantly mess up, and cause the CEL to be illuminated. I drove across country, my CEL would pop on and off for a state or two. I'd recommend just replacing it. If the solenoid sticks open, it can cause poor idle issues, but other then that, it shouldn't be a big deal You can buy the solenoid online from https://www.subarugenuineparts.com/oe_parts_cat.html part # is 14774AA351
It might be a sticking valve or solenoid. There isn't a filter, just an internal screen. The newer ones got a spin on external filter, however I don't know how effective it is. It's probably just a screen type filter as well. Other then putting some synthetic trans fluid in, not sure what else to suggest.
