8
Just to add, here's pics from my timing belt job. http://www.main.experiencetherave.com:8080/subaru/images/timingbelt That should give you an idea of what needs to be removed. Also, if you have a visible leak, it's probably the sealent between the pump and block. The ultra grey silicone is the correct silicone to use.
I've run both the subaru sti short shifter, and the kartboy. I liked the feel of the kartboy unit better. the kartboy short shifter however has a lower height then the stock shifter and sti short shifter. There are other short shifters as well, like the cobb double adjustable one, and a few others. I have however since gone back to a stock wrx shift linkage/lever setup with kartboy front and rear bushings. The bushings alone make a HUGE difference in how the lever feels. My suggestion would be to get the bushings first, and see how you like the feel. If you still want more of a shorter throw, get one of the short throw shifters, and still use the kartboy bushings. Here's some pics of the shifter linkage and kartboy bushings http://www.main.experiencetherave.com:8080/subaru/images/kartboybushings/
The thing about it is, unless they know exactly where the leak is coming from, ie low pressure or high pressure side of the oil pump, you really can't say whether it's a big deal to leave the leak go. If it's on the low pressure side of the pump, yeah it's probably not too bad. However if the o-ring that seals the high pressure side of the pump to the block is worn, and you're getting high pressure oil mixing with the low pressure, and then leaking, you would want to fix that sooner then later. The reason the labor is so expensive, is because they essentially have to remove the timing belt and all that stuff. Here's some pics of my timing belt/oil pump job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt
Sounds like a vacuum leak, and more then likely would be intake gasket. Pull the plugs, and see if you have one plug that looks different from the others. If so, then the leak is more then likely at that cylinder. With the engine running, try spraying starter fluid around the intake gasket at that cylinder and see if rpms rise. If they do, you confirmed your problem.
Gillman south is on 59s. CV axles really aren't too bad to change, with air tools and everything going well, you can get them done in an hour or so. www.cvaxles.com is a good place to get axles. However a local parts store might be just as easy. I really don't know about the clutch, I'd have to see it/drive it to try and diagnose further. Shoot me a pm, and we can discuss when's a good time to try and meet up.
Russ, Where in Houston are you? I'm in the galleria area, if you wanted we could try and meet up, and I can take a look at it. How does the clutch feel when the grinding happens? It sounds like the clutch just isn't engaging enough to get into gear. The way the clutch fork is designed, it's held in place by clips, and over time these clips can come undone, and the clutch fork is not capable of applying enough stroke to fully engage the clutch. BTW....which subaru dealer did you talk to......they're all pretty lousy in Houston IMO.
If you have a manual tranny, just leave the pipes open. It won't hurt anything. If you really want to, you can get some rubber caps to put over the pipes, but you don't need to. I put some caps over them when I did my MT swap. The caps stayed on there for a couple weeks....but came off.....no biggy. Also, the crack you mentioned. It's actually a pretty common failure point for these radiators, and pretty much in that exact same spot.
