8
Hello
Legacy777 replied to ShaneFK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I don't know if haynes or chiltons has anything. Shoot me a pm, I've got something that might help. As for the subs.....I think they have an amp built in. Personally, I'd just scrap them, and add an external amp and sub. At this point, you're probably going to be better off getting an aftermarket deck that has rca outputs. -
To be quite honest, without knowing the high side pressure, it's hard to say whether it's the switch or the fact the system is generating too much pressure. My nissan pickup cycles on and off too frequently. When I checked the low side pressure, things looked ok, but the high side was too high. I'm pretty sure it's overcharged. I'm planning to just evacuate everything, clean the system out, put the specified amount of oil back in, and recharge the system. Personally, I'd just take it to a shop that will give you an ac system diagnosis for a specified amount of money. Most shops will do that. I had mine looked over for like 30 bucks or something. Other option is to buy the manifold gauges, which is about 100 bucks. Then, if you want to do the work yourself, you need a vacuum pump as well.
The first gen legacies had non-interference engines, so you should be good to go by just slapping a new t-belt on. Only other things I'd look at are the oil seals, possibly replacing the water pump, and resealing the oil pump (depending on when the last time they were done). You may want to check the timing belt tensioner as well. See if it's leaking or anything out of the normal. The belt's failure could possible be due to the tensioner not providing enough force to keep the belt tight.
Big thing with brakes is what type of environment do you plan to use the car in.....that will help you in determining how much you want to spend. My personal advice, for a street driven car that you just want some extra braking capability, put better pads on. It's relatively inexpensive, and can really improve stopping capability over stock pads. Here's the spreadsheet I did that jamal was talking about. http://www.main.experiencetherave.com:8080/subaru/techinfo/brakemath.xls
I don't know for sure whether the 96 has an electronic or cable driven speedo. But check around the area where the front differential dipstick is. On the cable driven speedos, there's a base piece that fails, and causes the speedo not to work. The VSS2, which gives you your speed in the dash and to the ECU is typically driven from the front differential.
Thanks Ed. I think the only thing I would probably do different is use PAG oil instead of esther. I've had one compressor go out on me. I don't know if it was just coincidence.......and the compressor I have in now is knocking. I don't know if it's due to the fact esther oil doesn't lubricate as well as PAG oil, or the fact that the guy who pulled a vacuum on the system, didn't do it long enough. I might just be having bad luck with used compressors. I've got my own set of gauges and vacuum pump, so I know it'll be done right the next time. I'm probably going to swap out the compressor when I do my motor swap some time this summer. That or when the current compressor craps out, I'll swap it out.
What model subaru do you have? All the "newer" subarus either have a distributeless or coil on plug ignition system. For the distributeless ignitions you can use the MSD Dis 2 ignition system. For the coil on plug ignitions, you really can't do anything. The rev limiter option is there, however you can't increase the rev limit because the ECU has its own rev limiter. You'd have to bypass it first.
