Question about a sway bar in a 92 legacy
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI merged your new thread with your existing one so that anyone with a similar problem will be able to read over the entire diagnosis.
flywheels???
The n/a 2.2 & 2.5 flywheels should be the same.
Speed sensor part number needed
Legacy777 replied to kevin_c's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat car do you have? What year? which speed sensor?
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe was talking about the 91-94 turbo legacy, and yes it only came on the 91 turbo legacy. I have the parts book for the 90-94 legacies, and the vlsd is only listed for the 91 model year.
Speed Sensor 2
Legacy777 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwelcome
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the link is not positioned right, you may have something bent on the A-arm. Or the link just might be bent. If you drive around without the bar connected, just be careful.
Legacy777 replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually.....you really shouldn't drive without a front sway bar.... If you do, you need to be extremely careful.
What's VDC?
Legacy777 replied to Spokane-Pete's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight now it's only available on the higher end 6cyl cars.
What's VDC?
Legacy777 replied to Spokane-Pete's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I believe you can turn it off.
Speed Sensor 2
Legacy777 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can tie into the VSS2 signal at the ECU or TCU. it should be an oscilating 0 to 5v Here's the pin out for the ECU & TCU http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/TCU_I-O_page2.jpg
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm...not sure about the t-70 torx bit thing. You may want to ask somebody on http://www.legacygt.com/forums
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry again. I had things down yesterday evening when you posted.
LSD on a Legacy!?
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXALL of subaru's limited slip differentials use a viscous coupling, and are sealed.
What's VDC?
Legacy777 replied to Spokane-Pete's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVehicle Dynamics Control. It's basically a stability traction control system. It has yaw sensors and other stuff to keep you on your intended path by individually braking certain wheels, or taking power away. With the AWD, and VDC.....you have very similar platform as the higher end audi's. My uncle's A6. You just stomp the gas, and turn the wheel where you want to go. The car will keep you on the intended path. Obviously there are limits to this system though....it won't save you're bacon every time.
2wd - AWD Subaru
Legacy777 replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is NOT a towing fuse. You will still damage the transmission if you put the fuse in and tow it with the rear wheels on the ground.
Timming Configuration For '93 impreza ... HELP!
Legacy777 replied to monkey nuttz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replied to your other thread http://www.ultimatesubaru.org/forum/showthread.php?t=36086 I'm going to close this one, so all comments stay in that one.
cam/crank seals leaking 90 legacy
Legacy777 replied to TheBigJ's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can use a screwdriver and get the seals out very easily. You have to dig into the seal, then use a pivot point on the engine so you can push the end of the screwdriver handle towards the engine, and it will pull the seal out of it's home. I struggled getting the one out. After I figured this out, I got it out and swapped easily. You do need to be careful not to scratch the shaft. I also used this method with the rear main seal. As for install, just use a large socket....I think I used something like a 22 or 21.
VSS Pinout for a Legacy
Legacy777 replied to rupetorun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwelcome
timing config for a 93 impreza help
Legacy777 replied to monkey nuttz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2.2 or 1.8? This is for the legacy. It should be similar for yours http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
1993 Impreza check engine light
Legacy777 replied to normscott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 93's should have the green & black diagnostic connectors like this, but probably won't be in the exact same spot http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg
Trying to diagnose a leaky injector
Legacy777 replied to wae's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you're on the right track. Replace the o-rings and go from there.
Speed Sensor 2
Legacy777 replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe TCU holds the gear in 3rd when trans temps are very low, so the fluid heats up faster. So this is normal during the winter time when temps get really low.
Oil pump flow rate?
Legacy777 replied to kidwired's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you find the thread with the numbers in it? I've been traveling all week, and haven't had time to check the boards.
Legacy777 replied to rupetorun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust tie into the VSS2 at the TCU http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/TCU_I-O_page1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/TCU_I-O_page2.jpg
Oil pump flow rate?
Legacy777 replied to kidwired's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour answer is on the legacycentral bbs in the engine forum.
