8
Those diagrams should give you an idea of how things are layed out. The pin numbering may be different, but it'll give you an idea on where to look. Just pull the connector off the coolant temp sensor, the ECU will see that as a fault, and turn the fans on. If they don't both turn on, you've got a wiring issue somewhere from the ECU to the fans. First check that the signal is being sent from the ECU to both fan relays. Once you've determined that, and swapped relays between the two fans, to make sure the relays are good.....then you'll need to trace your wiring after the relay.
The rear springs on the 90-91 were tapered. The ride height issues between the 90-91's and the 92-94's are mainly an issue when going to kyb struts. I'm not sure why, but it's usually when people go from the stock struts to kyb, the front raises. But that's a mute point since you picked up the 95's. You should remove the a/s computer. That will disable everything. It's under the seat. Look at figure 67-3 http://www.surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location06.jpg
Hey Dave, Unfortunately, we don't get the twin turbo models in the states. So I'm not sure how much good we'll be. Try clearing the codes, pull the EGI/TCU fuse for 30 min. Drive the car, and then check the codes again, once the light goes on and you have problems. May want to also post over on www.bbs.legacycentral.org
The filter is in the engine bay right next to the driver's side strut tower. Fuel pump is in the tank. The connector to unplug the pump is under the passenger rear seat. There's usually black foam over it. You can unplug this connector, and try and start the car to relieve the pressure, or just leave it sit overnight.
I've got a very slow leak from the driver's side axle stub of the rear diff. I've looked through the FSM, and have the procedure on changing the seal, but was wondering if anyone had any suggestions or tips. I know the LSD stubs are different then the normal stubs, and I think need a puller. So like I said....any suggestions would be helpful. TIA.
