Everything posted by pearlm30
MY 98 forester with auto trans. I got this loud grinding noise only when engine reaches its operating temp(after driving 40 mins with 80F outside temp, AC off). The noise is present when I rev the engine rpm up in P and N, also present in D when drive around town. When I got home and ready to pop the hood(with the engine running ) to see where the grinding noise came from, the car no longer making noise:confused::confused: All the fluids are full and clean except power steering ATF( its dirty but no leaks). So what are the possibilities? Oil pump? Pulleys? Front diff? Trans? The car drives good without any warning lights on Please help
I read about something like that, but the installation of the spark plug antifouler was at O2 sensor location. Not in the spark plug well. But again, I never hear of antifouler before this and I am open for any suggestion and advice:lol:. Maybe the antifouler is used by old style engine with carb engines???
Thanks for everyones suggestion!!! Got the antifouler out:banana:using screw extractor #5 I got from Harbor Freight. Came out easier than I thought:lol:. The thread seems to be OK. I didnt see any sign of cross threaded spark plug hole. I will get new NGK plugs and see what happen once I finish install the trans. So what can make a spark plug foul? Leaking injector, worn piston ring/oil control ring?:confused: Any suggestion?
Got the 96 OBW manual(bad trans) as a project car 1 week ago( have not hear how the engine run since I got it ). While getting ready to buy the clutch kit, I look thru the engine bay and this is what I see. Look like the spark plug crossed threaded at one time and who ever did this just put in some kind of adaptor to let the spark plug seat(instead of repair it properly with helicoil) :mad:And when I remove the spark plug boot, the end of the boot is all burned out My questions 1)Do I need a cylinder head? 2)I dont know if I can remove it, it seems in the well pretty tight. Any tip or trick to remove it? 3)Any advice? Thanks a lot!!!
I had a similar experience with a MY 93 impreza. I dont remember the details since it was more than 5 or 6 years ago. Anyway, the impreza was installed with after market remote entry/start system. But it was not done right, the wiring shorted out and it kept blowing a fuse(I forgot which one) Check the wiring by the left kick panel and all your relative fuse. Good luck
