Urabus-84HBDR
Everything posted by Urabus-84HBDR
  1. possibly meet somewhere in the middle and go for a cruise... what do you got to wheel down there? working on my axles agian today. but shea ready thatswhatshesaid- maybe get ahold of him today.
  2. Yes the cups are what breaking ovaling kind of, and cracked in two/three places. the bearings are gone too after this usually. well like first post says, ive swapped out the welded diff for the one you gave with the car... So i could run 4wd w/out throwing the stub in when needed... Mite put it back in, (welded diff.) Bought two new axles from napa- too much. first they gave me the wrong axles, they were too long. weird. got the right ones and they slid right in. I forgot that they were the hybrid axles... occured to me yesterday when i was reading GDs post about how to do that... Oops, im retarded. So, i have extras ea82 axles laying around, going to swap the cups out. Both ends right? or just the outside one? not real clear on that. The trail i was on isnt that gnarly either, they are just overextending and popping, felt it everytime theyve broke... Would cranking up the torsion bar bring my diff up so the axle stubs on the diff are higher then the stubs on the hub/brakes? Would my handling be any different?
  3. My ea81 wagon keeps breaking rear axles... been researching and found that GD posted a thread that he swaps on the ea82 cups onto the outer?, brake/tire side of the ea81 axles, so when they are extended all the way it dont snap. Going to try this, think the axles that were with the car when i bought it were this way.... hmm. also that if my torsion bar is bad/not cranked up all the way would make a difference. Going to try messing with that, have an extra torsion bar, myabe just swap it out... Thanks for reading, pleasr reply with any info/exp you have on this subject. Have welded diff but took it out to see if that was the problem, not it. If i fix it i mite put the welded diff back in. Do I swap both ends of the cups or just the brake/tire side? THanks again. Setup is ea81, 1982 gl waon, 6'', 6 lug, 28'' s.s. on 14 chevy rims, 5sp mt d/r, rear disc, front kyb gr2, factory brush guard/winch mount.
  4. Just got new struts. kyb gr2. finally got here... going to go put them on! How hard is it to make a srping compressor? goin to just do that instead of renting one... Got new exhaust gaskets to put on, the pass side blew out the other day, havnt drove her since put the bumper on. Going to sandblast and paint it too. Been driving the 88 gl10, think its getting ready to take a poo. . .:-\ getting weak. -twitch- ive had this bumper for years. just found something cool enough to put it on.
  5. Got the camber fixed on the wagon... Already wore out a brand new set of cooper discoverers. Strut blocks from monstaru, made by Bill. Very nice blocks. Drilled my front hubs to 6 lug, now have 4 and 6 lug hubs, pugs/chevy/yota rim options. Swampers coming soon. Front brush guard off stock ea71/81? its the one with a winch mount! Going to swap out the rear diff for e reg diff, not a welded one. Put up a pic this afternoon. Waiting for my brother to finish building my hi comp ea81!!
  6. what shop did you take them to? DG machine is in Auburn, highly recommend them, they work with delta qutie a bit too... Right down the street. If your heads are too cracked hit the jy for a donor car thats wrecked in the rear or something obvious besides motor failure. I have 100k on a j/y motor, car was wrecked in the rear... Almost time to go thru it. Taking the motor out is the best option, if you have the time and space/tools to do the job. need a few special tools, or can get around them, clutch aignment, hoist/stand, clean area. Watch the studs when you torque the heads down, seen people strip out those, not what you want. Good luck.
  7. Well... Got a new to me soob. monstarus 83 gl wagon. Done a few small things and some that were needed. Oil/filter change, halogen blue headlights. Had a rear bumper, big steel plate with hitch. going to take the ends off the stock bumper and put on the corners. the exhaust was hanging down and had a huge glass pack on it, got two new ones 25'' cherry bombs, and cut up the other exhaust and what i had around to make duals... sounds good, breathes real good, maybe too much? just got new front rotors and pads, going to do today. working on a different roof rack. Looking for tires coming up. Pics coming up when i get the tires and rims on, and when my motor comes! Soon. Shes in good hands Brian...
  8. ill be there with my hatch... maybe the gl10 too. ya boy! cant wiat. but havta. see you all soon!
  9. already have NEW pistons, my brothers doing all the work as hes a machinist at a well known shop... and its free, except for parts. new everything basically, water, oil pump, seal kit, completely re did heads, looking for aftermarket rockers? know of any... talking with delta about cams. hopefully abotu a month or so and she'll be running. pics soon, i need to build or find rear strut extensions for the shocks or something, and the steering shaft. thats it..... any ideas for the build would be cool, i have an 02 ej20t in my 90 legacy wagon, but dont want to put a turbo in a lifted hatch... idk
  10. the car ran ok, had some issues- the problem wasnt the intake, well partially. the motor pretty much self destructed... threw a rod out the top of the block... (think ive said this). there were problems on the previous motor in it- power steering pump bracket loose and the mount was all messed up, the p/s lines wore a hole where they rubbed each other for so long, (fixed).
  11. in conclusion my car already had the XT motor in the car. previous owner did the swap before had the car. glad I grabbed an XT motor, used an 85 RX sedan intake thats in the pullnsave. good car out there. it runs way better, no lifter tick at all!!!!!! pulls smoothly thru all gears, and is likely the best soob motor ive heard, and not cause its mine... pics soon.
  12. thats the norm on ea82Ts from what ive seen on mine and my couple soob buds have... IHI VF7. they make a rebuild kit for it, bushings all that. i believe. they around if you look in the right places... as in the previous post turbos are good to have lying around.
  13. well you should give me a call... i can get the complete oil pump kit, mickey mouse o-ring and one other single o-ring. i think the pump just mounts directly onto the block, no gasket there... could be wrong. also i definately have a clutch alignment tool you could borrow- as long as i get it back. give a call man.... im willing to help just have to let me know when and where.
  14. dude give me a call later tonite, 5 ish. i should be done with my friends hatch and will look at yours if you dont care... wouldnt hurt. and yes i ahve changed many axles/cvs. roger 509 671 3439
  15. Sorry for the double post. Yes this XT motor is going into my GL10, More specifics- My car is a 1988 GL10 Turbo Sedan, Full Time AWD with Diff Lock. The Donor- 1986 XT Turbo. Not all XTs had the spyder intakes, didnt that style intake only come in 87? or ?? So I couldnt take my stuff off my intake with hole in the bottom and put it on the XT intake? I know the MAF sensors are different- well the Hotwire vs. Flapper deal... Audiofile- Where did you find the h.p ratings? and what do you suppose makes the h.p rating different if they are the same motors? the cams? Im all sorts of lost... someone who knows please set us straight. thanx
  16. So the Vortex is just another name for the XT, kinda like the Liberty and Legacy? Same car basically, but minor differences. I 'believe' the pistons are different. (Im going to take pics tonite of the two and post them tomorrow.) On my freinds GL10 Turbo Sedan (85/6) when we rebuilt it, the pistons were a solid dish on the top surface, as with another friends 86 Turbo Wagon. The pistons sitting in the XT motor in my house (yes in my house) are not solid dish all the way around. There are two groves opposite from each other. Also the intake off the XT motor is NOT a spyder intake. It had a regular one like the stock intake like my 88 Sedans. (I dont have a wagon.) Also I CANT use the intake off of my motor because when I threw the rod it popped a hole in the intake too... AH! I have a spyder intake but thats it, no fuel rail or electrical. Working on a deal for two of them... The cam towers are the exact same huh? Im going to have my brother take one of each (marked which is which) into work and measure the duartion and give me definite answer there... Sorry so lenghty, but Im confused... HAHA. Thanks for the replies.
  17. I know some of you know the answer to this question. just havent been able to get any hard evidence or facts... - What is the DIFFERENCE between an XT EA82T and a regular GL10 EA82T motor? I thought that the cam profiles are different, not a big concern there. What about the pistons? The dish in the top of the pistons are there, but has two indentations on the side of the dish. Are all turbo pistons like this? - What is a Vortex motor? Ive read and read but it just talks about them not how to I.D. the motor. - So I pulled my motor out of the GL10 and pulled an XT motor form the yard here. The donor car is 86 XT, had four wheel discs, turbo exhaust manifold. I know for sure its a Turbo block, the heads are dual port on top. The car/motor did not have a spyder intake on it. Whats the diffeence of the intakes? can i swap my wiring over to the XT intake and blot it on the 'good' motor? Im sure I will have more questions soon. Thanks for reading and all input is appreciated. Roger
  18. ok. well another question and hopefully an answer. -The difference between our motor (GL10T/EA82T) and the (XT/EA82T) the XT motor is the exact same... or are the cams different? thats what i thought made the only difference. -Also, the motor out of the XT didnt originally have a spyder intake on it, thus the electrical is same than that of a regular intake? the only difference in the electrical would be the one that had/has a spyder intake on it... Caboobaroo -Could you clear the first line up of the post you made? -The intake that is/was on my car is bad, the rod punched a hole in it too.... sad day. What would you benefit by running the carbd crank pulley rather than ours that has the rubber membrane in it.? Did you change the pistons out on the SPFI block then? The heads would also need swapped right? I have everything but an intake and seals right now... but looking to make the intake swap happen. Sorry for such a long post. Roger
  19. Well sadly the motor in my 88 GL10T sedan finally went on me. I havent pulled the motor yet, thats tonite. Think I blew a rod out the top of the block. Been watching this XT at the picknpull, snagged the front seats, rear discs, and the motor out of it. This 'car' is an 86 (mid year) XT turbo car. The intake I took off it was similiar to mine. Didnt take it. My questions are- The XT was anautomatic to remove the torque converter, the trans was gone. The XT was turbo, as is mine. So is there anything else to look for when I throw this block together? My car is a manual, should be no problem.? Im using my intake off the orig motor, likely going to switch to serpentine belt pulleys, need the crank, ps pump, alt, and water pump, thats it right? Is the EA82T externally balanced or internally- the crank pulleys are different to a turbo and n/a. ? Thanks for reading any and all suggestions/comments are appreciated. oh ya Ill take pics tonite of the bad motor... Roger
  20. i see this car around all the time... i drive a red 88 gl10 sedan, FT AWD Turbo. Its a little rough running right now, but... id like to go mob the soobs all around too! sounds fun. give a call sometime soon.
  21. I will be down in South Lake for the summer, it would be nice to meet some locals and go riding and wheeling. I am planning on driving my 88 sedan down... what do u think? Got to tell someone- I got on with the hotshot crew in Tahoe! YAY!!!!!:cool:
  22. anyone in and around spokane/cda should get together sometime soon. there are more soob freaks out here in the pnw than we know... 509 671 3439 ROGER- if you need help with anything let me know, and if anyone knows of a local ea82T block that is GOOD let me know, I need it ASAP.
  23. this is kinda funny. were the cars driving anywhere or just sitting.? we have had a convention the last few days up on the S. Hill. but were all sedans and coupes, two gl-10s, and 2 DLs. hit us up were around town all the time.
  24. let me ask moy brother later today, he is an auto machinist. he will know for sure. we are building my hi comp ea81 (10:1) and we are going to knurl my ea71 pistons before re-assembling the motor. hope this helps you a little.
  25. one question for all who have made their own lift kit... why extend the struts up? where they sit stock is likely the best place for them, your not going to be rubbing your tires on the spring...? no angles, just add the extension to the bottom.. maybe im wrong here but sometimes simple is better.
