28
Everything posted by Turbone
The coil might be toast. Do you have a extra? Just about any 80's coil will get you by till you can find the correct one.
Hit and Run Today! (EA82 Fender?)
Turbone replied to Keiji22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm going to be replacing both fenders on mine soon. The drivers side isnt that bad, just a few dings. -
Anyone in South Florida want a GL10 with a bad 3AT?
Turbone replied to daeron's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is pretty bad where I come from :-p But seriously, maybe one of the members north of you can keep their eyes open for something? SC, VA and around that area. -
88 rx turbo blown headgasket?
Turbone replied to evilsqwerl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
??????? Wrong thread? -
USMD =Ulitmate Subaru Moter Buid
Turbone replied to thermalsurfing1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you need to listen to the people at Delta. They have more experience building EA81's then you think. -
If its drinkinig coolant, you might have bad intake gaskets. Or it really is a bad HG. But definitely find out if the rad is cooling correctly and replace the t-stat. -
No need to pull it out. Let it run for a little bit then shut it down. Feel the top and bottom of the rad. If its cold on the bottom and hot on top, the rad is clogged. My RX is doing the same thing (but not overheating). Granted its only 17deg out, but even when its above freezing it takes forever to warm up. I have a pretty new dual core rad and I suspect the t-stat might be stuck open. -
The solenoids for the 4wd are vacuum actuated. Check the lines to make sure they arent broke/cracked or disconnected.+ *Edit*...Is this a Full Time AT?
Does it overheat while idling, or on the road? Overheat at idle is from a bad waterpump. Overheat while on the road is a bad radiator. Or, it could be a bad thermostat. This is where you need to start first, use a OEM replacement. Tiny bubbles in the rad doesnt necessarily mean its a bad HG, but being a EA82T its possible -
Buy a can of any type spray lube that has a straw with it. Mine did the same thing the other morning and I used a spray bottle with hot water. But once I got it thawed out, I sprayed into the lock mechanism with PB Blaster. Works like a champ right now, but a better lube should be used for long term.
Ahhhh! Flashbacks Thats crazy, even the dog is whacked
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
Take 2 of these...<> <>... and call me in the morning.
Does someone have a driveline to measure?
Turbone replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ummm, the only one I have is currently still on the car and its not exactly nice enough out for me to be crawling under to measure :-\ I can check my parts book and see what it has tho... Edit*...No, it didnt show lengths :-\ But most of them were the same length for the 4EAT. -
When you said "Behind the wheel", I thought you meant that literally :-p This is me....out of the car
- 420 replies
- 1
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
XT steering wheel in an RX
Turbone replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got one in my shed...... But I'll wait to see what yours looks like first :-p -
Pretty sure they are the same. -
Do you believe me now?
This is probably a stupid question but...
Turbone replied to offroadsubie1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I believe he's talking about the fan belts. And it still has A/C if theres 2 belts. Theres a 6 point stud that sticks out just above the water pump. This will loosen the tenshioner for the A/C belt. The other belt is adjusted by moving the alternator. -
Ok, if you want to get technical. The manual says from 3/16 - 5/32, or 5mm - 6mm.
Anyone interested in my project?
Turbone replied to my69opelgt's topic in Non Soob Cars and Bikes Discussion
You see the pics I posted in your thread? The guy that owns that (might have sold it by now) had several GT's in his yard. I took a pic of a green one he had that was in ok shape. He said he wanted to sell it all. He had tons of cars, old Rovers...you name it - he had it. I'll see if I can find that pic. Maybe some day I'll get a GT -
If I remember right (which isnt often) this took me about 10 cans. There is no clear coat on it, yet.
