Everything posted by Turbone
Does someone have a driveline to measure?
Ummm, the only one I have is currently still on the car and its not exactly nice enough out for me to be crawling under to measure :-\ I can check my parts book and see what it has tho... Edit*...No, it didnt show lengths :-\ But most of them were the same length for the 4EAT.
- The One Behind the Wheel! (Pics of Us!)
- XT steering wheel in an RX
I've got one in my shed...... But I'll wait to see what yours looks like first :-p- XT steering wheel in an RX
Pretty sure they are the same.- Pin in Axel STUCK!!
Do you believe me now?- This is probably a stupid question but...
I believe he's talking about the fan belts. And it still has A/C if theres 2 belts. Theres a 6 point stud that sticks out just above the water pump. This will loosen the tenshioner for the A/C belt. The other belt is adjusted by moving the alternator.- Pin in Axel STUCK!!
Ok, if you want to get technical. The manual says from 3/16 - 5/32, or 5mm - 6mm.- Anyone interested in my project?
You see the pics I posted in your thread? The guy that owns that (might have sold it by now) had several GT's in his yard. I took a pic of a green one he had that was in ok shape. He said he wanted to sell it all. He had tons of cars, old Rovers...you name it - he had it. I'll see if I can find that pic. Maybe some day I'll get a GT- Rattle Can Paint Job
If I remember right (which isnt often) this took me about 10 cans. There is no clear coat on it, yet.- Pin in Axel STUCK!!
What size punch are you using? It should be a 3/16th punch. Anything smaller and it will spread the roll pin open and may damage it so it hangs up inside the axle.- help im new and i need little off road tires!
Wat?- everybodys favorite past time... diagnosing ea82 starting problems
3 things I can think of from the start are: 1. Check the rotor, the screw may have fallen out. 2. If the rotor checks out fine, check the timing belts. 3. Undoubtedly, the MAF needs cleaning.- removing ea82T head
But its a PITA to try and twist it out of there, isnt it? Its alot quicker to jack the engine up a little to make the job easier.- Turbo wagon with a hidden secret-
No idea, but I bought my PAP replacement for $10.50- Turbo wagon with a hidden secret-
Yup, looks just like the one on my first SVX.- Subaru Select Monitor
Nope, his is different. Sorry :-\- Subaru Select Monitor
Got a pic of it? I might know someone who has one and might be able to help. But I need to know if its the same thing.- removing ea82T head
Be a good idea to remove the turbo, it has water and oil lines connected to the head that need removed. That bracket can be a pita, soak the bolts with PB Blaster first.- Hello and help wanted
You missed that part :-p- Just bought an 88 GL Hatch with RX EA82T
The Sedan is normally a 4dr, this car is called a 3dr so it wont get mixed up with the earlier EA81 Hatchback. They did have a 3dr, on demand 4wd with a turbo, so I'm not sure if this is a swap. Dont see to many of them, but they are out there. Theres a idle/air screw on the back of the throttle body, adjustable from the top. It may have a black rubber plug in it, but most times its gone. Might want to check the timing on it also. Theres a green test connector that needs to be plugged in to check timing. It could either be in the engine bay by the drivers side strut tower/windshield wiper or under the steering column next to the ECU.- Hello and help wanted
Take one of the other nuts off the back of the light, I think theres 5 on each one. Is the rubber gasket the one on the door, or the one that surrounds the door jamb? Should be able to find a good one down here in a wrecking yard.- Well I Sold It.....
Did you ever get pug nuts? I posted in the playground saying I had some and never got a reply if you were going to come get them.- New Member, More cars than I can count..
Welcome to the USMB. Looks like you will fit right in with the rest of us addicts - XT steering wheel in an RX
