Everything posted by Turbone
My new 1986 XT won't start, help?
They wont see it. In a XT theres room between the bumper and radiator for the gas can to fit. With the hood closed, theres nothing to see.
AARRRGH!! SO Frustrated... No Spark!!
Check all the fuses in the cab. A couple of those are for the ign relays.
EA82T woes, need help
^^Correct. I was talking about the the other end, where the MAF is connected. Alot of times this clamp is loosened to get the airbox off so the airfilter can be replaced.
If he hasnt messed with the timing, theres a good chance the hose clamp is loose on the airbox. I would check them all to be sure.
Did he mess with the timing?
FOUND! stolen subaru wagon, spokane (not mine!)
Well, heres another one you need to be on the lookout for in Spokane. A 92 SVX Pearlie. http://www.subaru-svx.net/forum/showthread.php?t=48699
The truth of the EA82T and intercoolers
The 12lbs of boost, fall on your face cut :-\ If you had a problem with a OEM t-stat, a aftermarket one might fail even quicker.
I dont think theres a rev limiter, just the fuel cut. And I have a OEM t-stat ready to go in, the current OEM is just over a year old.
I have taken mine to 7.5K numerous times. Not often, but I know I can if needed. http://s286.photobucket.com/albums/ll95/Turbone/My%20RX/?action=view¤t=81048580.flv And with the WRX IC, hood scoop, 2 row rad and spider intake, my engine runs very cold. It has to idle for 15min to get up to 180deg. When I get on the road, it drops to 145deg and stays there.
Evans Creek run pics 1/09
Looks like you got out of there just in time. Not good to be stuck up there after dark. I had to dig myself out once. The snow was very deep and soft if you got of the hard, compact stuff.
getting an XT turbo - affraid !
Spider intake with WRX IC and recirc valve. Still need to hook the recirc valve up. Seeing how yours is a XT, application will be different. You may have to go with a front mount or a smaller unit placed off to the side.
Yes, it will lower temps. Since installing a WRX IC and hood scoop on my RX, temps have dropped dramatically. Which is always good on a EA82T.
99% of EA82T heads have cracks between the valves, so dont be surprised or panic. Its only catastrophic if the crack goes into the exhaust port where the water jacket is. Installing a IC is a good idea, but a oil cooler isnt mandatory. What is the average temp there? I imagine it does not get real hot, unless your close to the some of the thermal activity around there.
A few of us down south were jonesing for mud/snow and seeing how Rieter was questionable, we decided to hit EC. I had to stay on the main roads because once I aired down a front axle started making sounds of eminent failure:-\
Reiter Pit Run Jan 17
Looks like we can still get to the main pit area. We will have to see what/where we can go when we get there I guess. I think theres still some stuff to do from there.
May have a problem guys. Main road to Reiter is closed. http://www.nw-wheelers.com/forum/showthread.php?t=34605 Theres a different way to get in, but I have no clue if we can make it or not. I'll keep a eye on that Forums thread to keep things updated.
Uncle Scotty! one cocktail please
I'm finding that results depend on the tranny condition/mileage. Mt RX is running Scotty's fairly well for several thousand miles now. But I tried it in my XT6 and had not so great results. I tried some Pennzoil HypoyC and it was even worse. I swapped to a Amsoil 80-90w and everything is peachy now.
Was that with me, or without?
Coming to seattle...
I should be making it to Zaps. If the 2 of you eastern boys dont make it to Rieters, the tranny can come back with me or Ken. And I may have my kids with me, so a tavern/pub/brewery isnt going to work for me.
need date of wcss11 meet
I drove to the Dragon and back last year in a 89 XT. Just a tad over 6000mi and by myself. Made a stop on SD to see Chef Tim and Wife, then headed south. The only problem I had was when I left, my air suspension didnt air up for 30mi. It would have been a looooong trip without that working :-\
Alright, I'll jump in with a tentative appearance.
CV Joint Broke (All fixed! Next Project)
I think that axle is a replacement (used) he got from somebody. The one on the bottom is the new one (wrong axle).
5-speed d/r search
How do you test drive it if the car isnt running? Does that mean you wont sell any drivetrain parts off it? Btw, the PAP in Tacoma sells trannies for $50.50 with a $9.50 core charge. You pull of course.
- The One Behind the Wheel! (Pics of Us!)
How to hotwire an '85
The easiest/ghetto way is to take a pair of channel locks and pull of the chrome ring around the lock set. The whole unit will come out now and you will be able to unlock the steering as well. Otherwise, just get the number of the inside of the passenger door lock and get a new key made. I also suggest everyone that owns a EA82 car to have a fuel cutoff switch installed
