Everything posted by Turbone
JDM engine hacked
No, not enough reason. But when it grenades on you in a few hundred miles, then it will be. I really hope it doesnt, but you all know the bad luck I've had with used EA82T's :-\
Pulley + other stuff
Its a XT6. The belt tensioner is totally different than the EA stuff. The bolt that holds the pulley needs to be loosened, then you can start backing the adjusting nut out.
Donor link ???
Arf arf And thanks for donating.
2nd round
The idle problem could be 2 things. The IAC or the temp sensor. The IAC is a silver cylinder thats hooked up to the intake inlet hose and manifold. This can be cleaned, but has to be removed and disassembled. The temp sensor is real close to the thermostat housing and gets corroded easily. The wires also have a tendency to harden up and get brittle. Most of us have cut the wires back and made a new connection to the sensor. And if you havent already registered, you need to at - http://subaruxt.com/forum/index.php
Mirror Glass
To answer your question.....I dont think its possible :-\
09 Thread. Let's see your CURRENT lifted Soob.
Nothing has changed for 09 on mine. 86 Hatchback 8in lift Subframes for front and rear diffs and divorced Nissan t-case 4.11 gear ratio front and rear, rear is welded 5spd D/R tranny, runs in RWD EA82 DOJ's on rear axles 30x11.50x15 Super Swampers Dual shocks in front, Ranchos in rear Hyd EA81 engine with Weber carb Cherry Bomb muffler Custom front and rear bumpers Warn 6000lb winch mounted to front bumper Aircraft running lights on top Driving lights mounted in back Cobra 40LTD CB Probably some stuff I'm missing
Donor link ???
http://www.ultimatesubaru.org/forum/showthread.php?t=14367
How to get rid of that tapping noise???
Start by reading these threads. http://www.ultimatesubaru.org/forum/showthread.php?t=94276&highlight=tick+death http://www.ultimatesubaru.org/forum/showthread.php?t=87748&highlight=tick+death http://www.ultimatesubaru.org/forum/showthread.php?t=87315&highlight=tick+death http://www.ultimatesubaru.org/forum/showthread.php?t=83795&highlight=tick+death There is 3 pages of info on this one problem.
Mirror Glass
Why bother screwing around with new glass? There tons of whole mirrors in the wrecking yards. I probably have several in a box.
Any information on Dragon Run this year.
For which group? You need to be more specific (and post in the correct forum). The XT/XT6/SVX group is set to go in June 26th-27th. http://subaruxt.com/forum/viewtopic.php?f=1&t=10207&sid=a10d8fa35ad6890caeafd1724ced6fba As far as I know, theres no other Old School meet going to the Dragon. There is a New Gen meet that usually goes, but I have no clue about that. Look it up on Nasioc if your interested in that. Theres also local groups that go.
New (To me) XT6
Welcome to the Board! There is a dedicated site for the XT (or Alcyone) fans. Its http://subaruxt.com/forum/viewforum.php?f=1&sid=230f82ae140967de3052a23bb0d3c6ef It does sound like the alternator is having issues tho. If you have a meter, I would check the output on it. Oh yeah, when you register there, make sure you post pics
Newbie...need help.
As far as I know, alot of different years/models will work. But to get a definitive answer, post in the New Gen forum.
Bigger R15 exhaust housing on 88+ XT4 turbo ?
That might be a EU spec turbo. One of the guys from the other side (of the pond) will probably chime in to confirm.
weld rear diff
It would probably be cheaper and easier to go with a straight axle and install a electric locker in that. Gee, I wonder who did that? (No, it wasnt me)
EA82 Front Caliper Removal
Are you talking about the e-brake cable? If so, you need to pull the lever back a little bit so you have some slack and then use a pair of pliers and pull the end off the lever.
1989 subaru gl 10 vent visor?
You need a complete window frame to install a vent visor. How do you expect to attach it?
weld rear diff
And dont forget, the gas tank is right above your head And you will need about 6-7 cans of brake cleaner too.
Early 90's small Pickups; Who made good ones and who made junk
I had a 92 Mazda 2600i 4x4 ext cab. It was all import, no Ford in it. And it was the most reliable rig I've ever owned. I bought it with around 112k on it and had to replace the OEM clutch at around 160k. I had a CV go bad on the drivers side front axle (its a 2 piece job), but other than that, it was a great runner. It even made a couple of trips up to Evans Crk with the HP and had no problems on the hard stuff. I traded it when it was about to hit 200k, straight across, for my Hatch. I still miss that truck :-\
Solid Axle Wagon...
Oh god, its got a Saturn 1.9 in it Thanks god for gearing
3AT blow out.
Have you tried to pinpoint the leak exactly? The only place in the area you claim are the filler tube for the front diff. That does not take AT fluid, only gear oil. The tranny dipstick is on the other side. Theres a vac line that runs from that side that goes up to the intake, but its not supposed to have any fluid in it. I suggest you check the cooler lines the run from the drivers side of the tranny to the radiator.
Camo paint job
I know a guy that did that to his 83 GL Wagon. He used fern leaves and it turned out really nice. He even thru in some little bunnies
- bolting a tire together...
Wcss 11
Absolutely Even have a kiddie pool for guys like me And one muddy hill I couldnt quite make it up.
Camo paint job
I've been wanting to repaint my Hatch in the new digi camo, in urban color scheme.
5 lug facts..a picture book (56k..go play)
Hey Kaz, can you re-host the pics? I've been re-directing people here and they need pics.
