Everything posted by Turbone
Whose got the Wickedest Ea82
Oh, I guess its time for a update
Turbo question
That sounds pretty ghetto to me :-\ Probably wouldnt last very long.
Wcss 11
I'm not even going to touch that one Hi Amanda More pics!
good aftermarket turbo for rx?
Heres the best info you can find on the subject. http://www.ultimatesubaru.org/forum/showthread.php?t=88249&highlight=TD04+turbo
$@%&# EA82 Crank Pulley!!
You are not getting it tight enough. I've had the same problem. Lock up the engine, use locktite and herf on that sucker.
1986 XT Turbo Blown head gasket (help)
This will not end well. And with that, I'm done.
The engine in your XT is a EA82T. If you do a search you will find that they are very temperamental and sensitive to cooling issues. A rebuilt is also pretty expensive. Up to $2k, but you get a worry free engine (if your cooling system is 115%) Another option is to swap a EJ22 in it. Theres lots of info here related to that in the Retrofitting Forum.
You might be looking for a new engine. Or at least a major tear-down. Never use crap like that in a Subaru, it gums up the whole works. You need to ask questions before doing something you are not sure about. Thats why we are here, to help. We have a few members in your area, I think one of them is a qualified mechanic (Hondasucks).
If we knew your location, someone close by might be able to stop in and take a look at it. If it was a HG, it would overheat and smoke. You need to pinpoint the leak before digging into the HG's.
Wcss 11
I look forward to it all year. I (and friends) work hard getting my cars ready for the Show. Maybe if we pick 2 locations, North and South, and alternate every year things would be easier to organize? Thurston ORV Park for the North. Hood River for the South.
Power drain 83 Coupe One More Time Might have found it
How about replacing both those alternator wires. Dont think it should be that hard to do.
She has one, I sent her 2.
turbo upgrade to ea82t...
Wont find much in this forum, you need to look in Retrofitting. http://www.ultimatesubaru.org/forum/showthread.php?t=88249&highlight=TD04
Just bought a '84 Subaru GL - Pics Inside =)
It was sometimes called a passing light. Its in the center of the grill and behind a motorized door with the Subaru emblem. Came on 82's. http://www.indysworld.com/80s/general/literature/brochures/1980-colors.jpg
Spark plug intake clearance?
Sounds like the damage has already been done, by whoever installed the plugs before. The only cause for this issue is the plug was cross threaded, like you suspected. You will need to replace the plug anyway after breaking it, so get it out anyway you can. Then you will need a helicoil to repair the threads.
Subaru XT Broken timing belt.
http://www.ultimatesubaru.org/forum/showthread.php?t=50768
ea82 turbo verses ea82
I guess I'm a dying breed, even for old school Subaru's :-\ If you want a reliable EA82T, make sure its a low mileage engine. Then go through it all and replace every rubber part on it. Replace every maintenance item with new parts. Make sure the cooling system is 100%. If you want a fun/fast EA82T, get a rebuilt engine (preferably CCR). Then do some mild mods to it. Cold air intake and IC. Get new exhaust - 2.5 or 3in works. TD04 turbo. High output ignition. DO NOT go over 12lbs of boost. Expect to do bi-monthly maintenance on it, to at least keep on top of things. I had a 86 T-Wagon that my Wife drove. Only did t-belts, coil and normal maintenance and it was a great car. If you have money, time and persistence/patience, it can be a great car. It took me a while to get to that point, but I'm glad I stuck with it. I'm pretty stubborn too
Driveshaft U Joint 88 GL-10 4WD wagon
So if you were a shop owner, would you do something like this and allow the car owner to take it out on the road for a extended trip? M45, glad your safely back on the road again. Good luck with your trip.
Thats something you might undertake. I would not, nor would I give advice of that nature to someone else making a long trip.+ M45, glad your getting it done right before leaving. Piece of mind on a 3000mi trip can make a huge difference.
I dont think that would last all the way to the East Coast.
I long for the boost love
Oh sure.....blame it on me :-p
Mainly the part that needs the u-joint replaced. If your pressed for time, take it all in. If your tight on money, tell them to only do the front one. I added 3 locations that might be local to you. Also, in order to run it in fwd, the shaft from the tranny needs to be removed (it has the bad u-joint). How would he plug the tranny to keep all the fluid from draining?
That bottom pic gives me flashbacks (SVX) You need to find a Driveshaft Shop. A place that specifically works on them only, doing shortening/lengthening/balancing etc. These u-joints are staked and need to be pressed out and then replaced with serviceable u-joints. While they have your shaft (watch it) have them take a look to see if its out of balance. This might be why you are having problems. http://www.superpages.com/bp/Albany-CA/United-Drive-Line-Service-L0122740956.htm http://maps.google.com/maps?hl=en&client=firefox-a&ei=5If2Sf7-MaLYswOFwMirBg&ie=UTF-8&q=driveline+services+san+francisco&fb=1&split=1&gl=us&cid=11389700472915689778&li=lmd&z=14&t=m http://maps.google.com/maps?hl=en&client=firefox-a&ei=0Yj2SfSMJqb2iwPay6HGBw&ie=UTF-8&q=driveline+services+san+francisco&fb=1&split=1&gl=us&dtab=1&cid=14887908516033780497&li=lmd&z=14&t=m
I have clips and probably a clutch fork. If this keeps going, that car is going to be part mine :-p
new wheels needed... EA82 wag what offset?
Its photogenic, meaning it takes good pics. In person it has lots of dings and rock chips. Hope to get that fixed this year.
