Everything posted by Turbone
You probably haven't seen an EA81 cross-member like this before!
Mmmmm, eye candy :-p But you know I would prefer mine PC'd black
Wanted: 84 Hatch driver's side (second, not door) window
I might have one, I'll need to dig deep for it tho. And that should have a EA82 in it.
New BRAT seats... can you guess from what?
Darn close, the RX seat has vinyl and cloth. These sit a tad higher in the front, but I figure with the multiple adjustments on the drivers seat, it should be ok. Me sitting a little higher isnt that big a deal
Finally got the passenger seat in. It probably took about 3-4hrs total work to swap rails :-\ I plan on doing it differently on the drivers seat.
87 Rx
Go over to the Retrofit Forum and look around - do a search. Lots of info about the car and mods you can do. Welcome to the Board.
I didnt check the years, but there were a couple of them in the Arlington PAP.
Meh, not that big a deal. Thats what power tools are for. Sawsall, angle grinder, drill. And yes.......I happen to have a fire extinguisher close by Caboob, I will have seats that will feel mucho better than STi seats You know how it is with old guys and bad backs, you're half way there.
Seat interchange for 99 Impreza
Turbone replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put Legacy LS seat in my 95 Imp, direct bolt up. The passenger seat is a little tight tho, it doesnt like sliding.
Just bought 87 Subaru RX
Welcome to the USMB, and to the frustrating and sometimes rewarding world of the Subaru RX I run Premium in mine, but only because of the mods. Normally in stock form, you can run Regular. If you have a real low octane where your at, and you're running regular right now, this may be why you're hearing the ticking. But not being able to hear the sound in person, its hard to tell. The 88 owners manual will work fine, all RX coupes are the same. The oil leaks are common. Most likely from the front crank seal and front cam seals. Its a straight forward job. Do you know if the timing belts have been replaced? Normally they need replacing before 60K, but I have heard (in rare cases) of them going further. The engine is a non-interference engine, so if they do break, no harm will be done. But I always keep a spare set in the back. Seeing how you're in AZ, I would go thru the entire cooling system. Check/replace all the hoses that are dried out or cracked/weak. Check the radiator, if it looks like theres any junk floating around, flush and keep a eye on the temps. This is the major common problem with this engine. Its very sensitive to heat. The most common result is head gasket failure. For more info, search for threads/posts under my S/N or go to the retrofit forum. And pay no heed to GD :-p
I hope to get it on a dyno before WCSS11. Butt dyno tells me 130whp. I had 100 before the turbo upgrade. And its a CCR block with less than 20K on it now. I would have to drop alot more $ into it to get more and thats not going to happen. I know when its time to quit. But I would love to get another one and do a full EJ swap like Russ is doing.
I've been running 12lbs of boost for a year now, with no EMS. Stock injectors. Stock fuel pump. TD04 and TMIC. It runs cool as a ice maker when the fans are hooked up.
Lol Yeah, I know the back lever is for the seat back tilt. I looked underneath and all, moving the lever around. Still couldnt figure it out, nothing was moving. I'm in the process of cutting/drilling the rails off now, because they arent bolted to the seat frame. Stupid pop rivets and spot welds. Its turning out to be quite a job :-\ And this is the just passenger seat
Front Disc Caliper for Subaru 1994 Loyale 4wd Waggon
Done
electric turbocharger
If your thinking of throwing your money away, I could put it to better use
Thanks for the info, its nice to be reminded of what was going on back then. But also, the cars in any Rally are never stock. They have all kinds of engine/drivetrain/suspension mods, which enable them to fly thru the air at 130mph Does anyone know how many years they used the EA82T in the Factory Rally cars?
Anybody seen or heard from Skip?
He usually makes us all envious by posting pics of his awesome camp setup
My 2.5RS Coupe
Turbone replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm a little surprised at how much the wheels on a car will get peoples attention. Before I had my gold ADR's on I would get the occasional glance or wave from another subie owner. Now I get looks from lots of people. They really set the car off. I even had some guy in a lowered Honda sitting at a light give me a nod when I drove by :-p
Will this work for a stint?
Oh, snap :-\ Check the wiring, something could be unplugged. Kinda like what happened to me today
mpfi looking for pics of this engine
Ohhhh, looky......a MPFI without turbo :-p
Its pretty normal for the oil pressure to read zero at idle. Its even mentioned in the owners manual. Good job, Niku
Hope its nothing serious? Give him our best wishes whatever it may be.
Ok, seeing how I was in a PAP today I took a look at some of the Mazda Protege's they had in the yard. They all looked ok, but I continued on. In the last row of imports there was a Mazda MX3. The seats were in ok condition, dirty and the drivers bolster had a couple holes in it. But my RX seat is worse. So I grabbed them, got em both for $35. Theres all kinds of adjustments for the drivers seat. Seat height in the front. Side bolsters move in and out. Lower lumbar support. And a lever on the side I have no clue what it does yet. I'll get some nice seat covers for them after they are cleaned. But I need to figure out how to get EA82 rails on them first.
My 2.5RS Coupe
Turbone replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice! So theres hope for the set of WRX wheels I have after all :-p
Help - dropped a tool into TC bung hole (Legacy 2.2)
Turbone replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou find all kinds of wierd things in used cars. On the end of the hose is a magnet, found it in my Brat a few years ago. I was told its for cows. Sometimes they ingest metal out in the fields and the best way to get it out is to have them swallow a magnet. It all comes out the other end. So, what happened to you, happened to me once. I had a rare stroke of genius and made this. It works like a charm. If I can find the other magnets, I can ship you one. You may want to try and go thru where the starter mounts up, its a bigger hole.
