Everything posted by Turbone
I Have a working Digi dash!!!
Hey, thats just ONE car. You shouldnt be complaining :-p
what i do when i am not working on the car...
They look like they are for a ATV? Maybe double up on each corner :-p
Weird Stuff - door gap
Not uncommon at all. I let my old 84 Turbo Coupe sit most of the Summer once. Got the tranny fixed and in the process found several nest in various places. Including the inside of both rear view mirrors. But I missed one. It was in between the door jamb and front fender. I opened the door and sat down to get into the glove box. I got hit 3 times before I could run away.
Cel - 88 gl spfi
http://www.indysworld.com/80s/general/USRM/mick-usrm/electrical/ecucodes.html
Rockauto NEW CV axle for .03 cents
That sucks for me :-\
The doctor is back
You mean your bored Ed and I were getting lonely here, glad to see you back.
My new project
Whoa there....you cant put a 4.11 rear diff in a car that has a 3.9 tranny. You would need a divorced transfer case to do that. You can take a 3.7 diff and put the unit in a 3.9 case, theres a write up for it in the USRM. And if you crank the suspension all the way up, you will be putting alot of stress on the (front) axles. Do a mild lift so you can get some bigger tires, install a Weber and have fun.
Phewwww
Turbone replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHah......tempting, if it didnt have a bad rod knock.
QUESTIONS for T-case subarus with stock suspension(other than a lift)
Ah, right. I was using the final gear ratios on the tranny & t-case. Thanks Mick......I preferred my first ratio tho.
I have questions on swapping a japanese spec sti motor into my 97 legacy outback wago
This is the forum you want. http://forums.nasioc.com/forums/forumdisplay.php?s=&daysprune=1&f=87
Phewwww
Turbone replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm? Get a hold of me. Normally, I remove hoods. But these are not light and theres just enough room to get it out. I might take it off to get the engine/tranny back in, as I'm thinking of doing it in one shot.
Phewwww
Turbone replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCome over tomorrow and help me pull the tranny!
Phewwww
I tell ya, pulling a EG33 is like passing a kidney stone I still need to pull the tranny and get the other engine/tranny prepped. New belts/tensioners, etc. Then hopefully my sale doesnt fall thru this month :-\ If I ever mention wanting another SVX project, I want anyone close by to hit me upside the head
You cant do a t-case without lifting, there just isnt enough room. What do you break the most: Axles What is your final Crawl Ratio: Nissan t-case @ 4.37 x 3.9 Tranny x 4.11 Diffs = 70:1 (I think) EA81 or EA82: EA81 What size tires: 30x11.50x15 Amount of lift: Aprrox 8in Locked/open/LSD: Locked
rear brakes 1994 loyale
Posting in the Wanted Forum for rear disc's or drums might get better results.
Wcss 11
Uhhh, guess you havent camped out much? Heat some water on the camp stove and use a washcloth. Its only a couple days.
WTF, coolant leak back of intake (with pic) HELP PLEASE!!
That little hose can be removed without lifting the intake. It takes a pair of longnosed pliers tho, preferably with a angle. The hose only has a spring clamp on the end under the intake. The other end is easy. The turbo gets cooled from the rad, true. But the line comes from the water inlet on the thermostat housing.
Pathetic request for shop pics
This is after I got my metal canopy. This is what it looked like before I got it. And it still lokks like that underneath
Spark Plugs
NGK Iridium's in my RX and regular NGK's in the rest. Have had no issues with any of them.
Will these wheels fit?
It depends. After doing some measuring of the wheels in question and a set of EA82 alloys (Yes, I have a pair of them), there is a 1in difference of the inside diameter. The wheel offset is totally different also, altho I dont know if this would make a difference or not. Offset for the old alloys is 3.5in and the EA82 alloy is 5.25in. So, depending on how you feel grinding a 1/2in off your calipers will decide whether you want the wheels bad enough. Not many have done it, but I havent done a search about it either.
Nope, they will not clear the front brake calipers.
84 gl wagon and 90 loyale interchange??
Its possible the rear brakes might interchange, I'm not 100% sure on that tho. Also, the rear axles might work in a pinch. They will be a little shorter than the Loyale.
Euro ? Spec EA82 cams .
I bet Delta Cam could make you a set of these. You have all the specs for it, just give them a email and see what they say. jonneyblaze69 @ aol . com
finally pics of the xt
Well for one thing, DL's dont come with a turbo. I know you have looked in your engine bay, does his look like yours? :-p With a base model XT, 2wd 5spd, he better get over 30+MPG.
Broke the wiring harness connector CTS...
Turbone replied to Baronpilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you find one in the wrecking yard, I would cut the wires. It will be much easier to work on at home. Pretty sure you need to come in from open end and use a small jewelers screwdriver if you have one. Once you figure out where the catch is, it goes faster.
