28
Everything posted by Turbone
Bucky92's Immortal Rocky, in scale.
Turbone replied to crazyhorse001's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wheres the mirrors? And I didnt know she had a JDM XT6? :-p Looks just like the real one -
difficulty in mating 4sp-ea81
Turbone replied to 970subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I keep the pressure plate bolts a little loose. That way if it starts to fight me the clutch will move to help get it lined up with the bearing. The bolts can be tightend thru the starter hole. Also put some bearing grease on the tip of the tranny shaft. -
So...yeah...My engine is screwed!!!
Turbone replied to 4WDFrenzy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Patrick, that sounds just like Psyko's engine in his XT-T. It went south last week sometime. But yours does sound a tad worse :-p It certainly sounds like a spun bearing, on both engines. -
Its hard for me to tell because of the lighting and angles and the differences are subtle. The 80 to 84 wagon wheel types would not work on Subaru's from 85 up. Thats the way it is here in the US.
Wheels look nice, but were not designed to fit your car. You might have a problem with the front brake caliper hitting the wheel, if you have vented rotors.
Smokey Point PAP update
Turbone replied to Caboobaroo's topic in Meet n' Greet. Your USMB Welcome Center
Should be on the road shortly, Briggs is on his way. Depending traffic we should be up ther about 10:30-11. I'll give you a call on the way up Chris. -
Mine has a hot wire MAF. Its all in how you prep the filter. Dont have to drown the thing in solution and dont do frequent cleanings.
Update? Pics? Russ is getting a new bike in less than 2 weeks. We should get a cruise together. You Russ Austin Noah Me Wonder who else on the board locally has a bike?
I have a K&N in my RX. I have gained at least 100hp from it and have had no problems with my MAF in the 15K its been on. 50% of what I just said is true
need window seals -84gl hardtop
Turbone replied to mike mcneil's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good luck trying to find a good set, they are more than uber rare. I did find something that was close to matching from JCWhitney and got a sample from them. But never did order any. I think the 68/69 Camero has the same type of strip. -
Frank, I might have a compressor and a rear shock. I'll see what I can find today. -
Wont be alone, got 2 other grunts, I mean guys coming too. Going to be Wed or Thurs, fairly early. -
I'm back! (got a new-old Subaru!)
Turbone replied to Ratty2Austin's topic in Historic Subaru Forum: 50's thru 70's
Wow Austin, that thing looks sweet And welcome back :-p I do hope you keep it stock.... -
I guess mine wont work... -
Ed, from looking at the pic, it says Kart Boy in the bar code.
I suggest a search here on the EA82T engine. Depending upon the maintenace of the used engine, you could be in for alot of headaches. Besides that, the swap issues would be mainly the wiring. You will need the complete engine harness and ECU. The knock sensor unit, engine x-member. Theres been alot of discussion of it here.
I might be making a trip up there sometime this week. I will take a look at that wagon for ya.
