Everything posted by Turbone
ignition BS....on 87 XT non-turbo
Have you tried changing this yet?
WCSS10 Location and Date Set!
If you go to Google Maps (use Sattelite) and locate the Fairgrounds, look directly east. Theres lots of trails from the looks of it.
Check out what I got yesterday (a new lifted Brat)
Funny looking Wagon, is that chop job? :-p
Turbones an Old Fart!!
I guess that makes me twice as smartrump roast
I would either suspect the coil or the disty. Usually a jumpy tach means the bushing is going bad and the disty shaft is getting sloppy. Zukiru, I dont think your tach is "jumpy". I would say it increases proportionatly when the clutch slips.
I cant remember that far back And I'm a ripe 54yrs old today. Just wish it didnt have to fall on a Monday cause it didnt start out all that great Connie, thanks for the B-Day present (if that was what it was), it came in the mail today :-p
Al 8 spokes
Yeah, Edrach has/had a set that he sent out and had polished up. They look very nice when they are shined up.
Bad coolant leak (And my screwup?)
Better to do it, that way you learn how. Sooner or later you will be doing it. Upgrade, bad turbo, etc. Get some PB Blaster and soak the nuts/bolts. Remove the oil line on top, then the hard water line on the side. Remove all the nuts holding the turbo to DP. Remove the nuts holding turbo to up-pipe. Theres a bracket that holds the turbo to the head, need to disconnect that. Then the whole thing should come out. The return line for the oil should just slide right off, but the water inlet will stay attached. This is where you need to use abusive language :-p It will have a double clamp on it too, so twice the fun!
- Bad coolant leak (And my screwup?)
I'll see what I can find in the manual, but I've always removed the turbo to get to that line :-\- Bad coolant leak (And my screwup?)
It sounds more like the supply or return coolant line for the turbo. The return line is between the turbo and head, and yes its a royal PITA to get to. Best way to check is to fill the system with water and let it run, then use a flashlight to find exactly wheres its coming from.- Now with starting problems!
It could also be a bad connection at the ign connection plug under the dash. Its a pink connector to the right of the steering column and under the dash cover. I've seen these have melted plugs before when the contacts are loose.- Subarina finally meets her twin sister...
Turbone replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly Foresters do that- I've got a 1990 XT6!!!!!! (and- i'm a moron)
Wanna trade?- Post your current wheeler and a story
Do I really have to list all the mods? I havent even been out since the snow melted :-\- caravan from seattle to Wcss #10
Your bringing 5? Did you have to offer them money? I have this problem every year. I was going to bring 3 last year, but one person couldnt make it in time. I have one lined up to drive this year, but if I had more volunteers, I could bring more. Well, I could if the price of gas wasnt so friggin high- caravan from seattle to Wcss #10
I'll be leaving sometime on Fri, not sure what time yet. But it also depends on my "drivers" also. Or even if I'm bringing more than one car- Happy B Day Backwoodsboy (aka Gritsboy)
And.....ahem.......pulling things out were they werent meant to go :-p- i am new to the site and i have some questions
Because fulltime 4wd rocks But only if its made to do that. I get 24mpg on the hiway in my RX.....as long as my foot stays light.- need a little help, 89 XT turbo
All the times that I have had a hot=no start problem, the coil was the culprit.- Happy B Day Backwoodsboy (aka Gritsboy)
Happy B-Day bud, get the most out of it- Speaking of B-Days...Hondasucks too
Happy happy joy joy Its also my youngest boys b-day, he's 14 now- 1986 RX Turbo wont pass emmissions any guesses?
I would try replacing the 02 sensor and if its a 86, it has the flapper style MAF. Not much to clean on that but the door linkage.- Emily's Birthday BBQ & Open House Invite
That would have been a bad thing :-p I want to see lots of pics. The more incriminating, the better- Found a 83 DL wagon, couple questions.
Is this the one you were looking at? If so, the price has come down. http://seattle.craigslist.org/sno/car/725530130.html - Bad coolant leak (And my screwup?)
