Everything posted by Turbone
yes another new rim picture thread (ENKEI'S inside) :)
Wow, those wheels look new. Did you have to clean the heck out of them, or where they like that to begin with?
So...yeah...My engine is screwed!!!
A 3yr/36K warranty is worth it to me.
I've got a 1990 XT6!!!!!! (and- i'm a moron)
Oh, now theres a sticky wicket
idot test on my part
Where does the other end go? To a silver cylindrical thing? If so, I think it goes to ground. Its a noise suppressor.
Some Tuenup ???'s for you
Do you run it year round? I can see using it cold, sub freezing temps. But when it gets warmer out I think a thicker viscosity lube would be better.
Black to the + terminal and yellow to the - terminal. Not sure where the red one goes:confused:
Well, Spring is here. I dont suggest running that in your gearbox for long. You will be looking for another one shortly.
new bike
Sweet. Be careful riding out there.
30 inch tire question
Dont expect to get anywhere fast
Installing a rear swaybar.
I know I struggled to get my XT6 swaybar on my RX. I had it up on jackstands and used my floor jack to lift each hub. It was still a bear.
Not to many choices on cap and rotor, altho I've never heard of the YEC brand. If its from Japan, it cant be all bad (?). I found a set of NGK plug wires on Ebay, look around there. Mine are 7mm and seem to be working fine. Theres a concoction out there called "Scotties Cocktail". http://forums.nasioc.com/forums/showthread.php?t=920674&highlight=scotties+cocktail I have it in my 89 RX and its working better now.
Better off getting ahold of Emily at CCR and getting a rebuilt short block.
EA82-t help needed
You need to re-set the ECU. Either disconnect the battery for about a hour or go thru the re-set procedure here - http://www.ultimatesubaru.org/forum/showthread.php?t=49918
Need more info. What car and what sway bar?
Po446
Sorry, not going to be much help here. This needs to be posted in the New Gen forum.
Tooters for my RX
They are only canted out a little tiny bit. And I will drive my SVX when the weather gets hot enough. Which is about 1 week out of the year Oh, I just rememberd....my Imp has A/C :-p
Tooters for my RX
I was able to mount them in that location because I dont have a AC condensor. Thats why Russ hasnt got a grill to cover his yet. You may have to mount yours insdie the engine compartment, but theres lots of room in there and thier loud enough it wont be a problem. Might want to be sure everything is tight in there tho, it might rattle it loose :-p
Tooters for my RX
Got tired of the weak horns and my air horns wouldnt work 100% of the time. So a while ago I forked out the $ for some Hella Supertones. Installed the yesterday. Man, those suckers are LOUD!
Summer tire rec's?
Turbone replied to hop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to be price conscious, look at the Potenza 960AS Pole Positions. They are a all season tire, but here in the PNW, I think its needed. I just put a set on my 89 RX after a bunch of research and for the money they are hard to beat. And so far I'm really liking them. http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE960AS+Pole+Position
HELP with axles PLEASE!! :)
My mind is really in the gutter this morning. I ROFLMAO reading this. Thanks GD.....and sorry :-p
Clay Bar and Old Paint more coupe drooliness added
Why? The tabs are still good :-p Remy has a nice ring to it. Whats the significance?
Yike's another Birthday
Why? Are you feeling older than that? Happy B-Day bud
New To Me '91 XT6
Lookin good! I like the black out lenses, might do that to mine How's it running? You neglected to mention that :-p
wHAT KIND OF MUFFLER ON MY 88 TURBO WAGON
Its restricted from the turbo back. If you want it to breath better, get a 2.5in system from the DownPipe back. Put just about any muffler you want on, but if you put a big fart can on, dont post pics here of it. The next recommendation I have for you, is to learn the search function
need some help before carlisle
Isnt Gary Gross somewhat close to you? He seems to know alot about everything.....
