30
Everything posted by Turbone
Replace it.
This is what I made for my 6's. Still have room for knees and can open the glove box enough to get things in & out. Both holders are adjustable. Should work on other consoles as well.
How many have you meet and greeted.
Turbone replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Miles, I actually met you after WCSS5 at Zaps place. You were passed out on his lawn in the backyard:lol: I left before you woke up. -
Automatic tranny problems 1984 turbo wagon
Turbone replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you take it out to clean, and the gear is "apple-cored", even a replacement will be temp. The problem is in the front diff with the gear that drives the gov. You will be looking for another tranny for a permanent fix. -
He needs to limit his transportation to the 2 wheel pedal variety:rolleyes: Less moving parts.
EA81 Digi Dash Help Needed
Turbone replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok, try this one. http://home.earthlink.net/~spioworks/sitebuildercontent/sitebuilderpictures/dash.jpg -
I think after 5mo, he might have got it figured out:horse: But then again............
ea82 runs then dies and has no spark
Turbone replied to slidewaysuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its a common problem. The common fix is a new Coil. -
How long have you owned your EA81 / EA82?
Turbone replied to GLCraig's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dont keep very good track of these things, I would have to look at the registrations to verify. But I'm going to guess:rolleyes: 86 GL-10 Turbo Wagon - 4.5yrs? 86 EA81 Hatch - 9mo? 89 RX - 2.5yrs? 89 XT6 - 2.3yrs? 89 XT6 - 1.5yrs? -
did some minor work to the front of the Brat
Turbone replied to Skip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey that deflector looks like it would work on my Harley. You can see better with bigger lights, thats my philosophy. -
West Coast Subaru Show #8 Hat thread
Turbone replied to Turbone's topic in Meet n' Greet. Your USMB Welcome Center
Got something else in mind. Were'nt you the one that said you wont pay for a hat if its over $20?:-p -
Nothing fancy or anything, just straight up and simple. -
Headlights on, Digi Temp Gauge RED!!!!
Turbone replied to NuclearBacon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most likely bad grounds. My 86 turbo wagon does it also, but not to that extent. The more accessories you turn on the higher it goes. Oh, and its not a good idea to turn your engine off at high temps. You need toleave it running and hose down the rad to help it cool before turning it off. You could easily crack/blow something. -
My GL-10 Needs a Roll-Cage *nods*
Cutting away certain areas of the dash might be needed to fit the tube in tight. But that just removes more weight:burnout: -
The time off. The willingness to drive several hundred miles to get there. Not be afraid to mingle with other fanatics (and not make too big an arse out of yourself). But seeing how your not afraid to ask a question like this, I dont see any of these requirements being a problem for you:grin: And maybe in your case, a chaperone:eek:
Not sure on how you would go about gapping the wires in the cap and coil:confused: Your problems could be the timing, the cat converter, or whats plagued older Subaru owners for years. A gutless car.
Let's see your USMB People Group photos
Here you go. Theres many more of us in the PNW, maybe we can try and get a group shot at WCSS8. -
Looking good. But wrong font:-\ Keep trying, I think we are getting close. -
Help needed on 3AT to DR swap
Turbone replied to Dylan86GL10's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Man I tell you, getting old SUCKS. I forgot the EA82 is a 2 peice driveline:rolleyes: CRS X 10:-p -
Try moving both of the S's up and putting a eight on the right side? Hood River above and Washington below. -
Yes, there is a difference in lengths. Use the 5spd driveline for the swap. If you need proof, just put the 2 together when your doing the swap and compare. Just make sure you label them so you dont mix them up. -
Strange encounter in Bellingham
Turbone replied to mortimc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did it look like this one? http://seattle.craigslist.org/car/134863962.html
