Turbone
Administrator
Everything posted by Turbone
  1. Do you have a Tach in it? Shift at 3K RPM, this will give you optimal rpm's for drivibility.
  2. Operose, your right - my bad. Thats what happens when you post early AM
  3. After some more thought on this I dont think its a freeze plug. The pop you heard was the rad cap coming off, and the water running out was what was coming out of the rad too. The engine was producing back pressure in the cooling system, or maybe the cap wasnt on tight? Maybe a bad thermostat that wouldnt open caused it? But then the temp gauge would go up if that was the case. What kind of HG's did you use on the rebuild? How old is the Rad? Yeah, I know. Just more questions....
  4. Well in most circumstances our definitions are the same. But when it comes to slang, we are totally different. A long block is the entire engine. Block, heads, intake and all the other accessories. A short block is just the block, with none of the heads or other parts mentioned above. Rice. This is what we call a car thats had alot of bling bling put on it that does nothing for the drivebility, handling or performance of the car. Honda's? They generally deserve the Rice label We like to stomp them in racing with our "Old Gen" Soobs against their big $$ cars. Altho there are some really hot performance Honda's (VTEC), most the time they just try and look fast. Here are a few more abbr: TPS - Throttle Position Sensor DP - Down Pipe for a Turbo'd Soob WS - Wind Shield (or screen) PB - Push Button (for 5spd single range)
  5. You DOG! Did you get any pics? I saw some of the show on Speed, but they just showed all the name brand stuff. Some pretty cool stuff there, thats for sure.
  6. Jeez Tex, I want to scream as much as you do(or did). The first thing that comes to my mind is a freeze plug. Might be wrong tho, but I cant think of anything else right now.
  7. This would be Patrick, the only US direct dealer of the BYB lift. His web site is Ozified
  8. I sent Tex an email on how he wants them sent to him. I have few, but they may need to be zipped or compressed to email.
  9. You might want to read the first post And view the pics in the Gallery too.
  10. Thats a pertty 3dr Even if it is red (I'm superstitous). Garner, these WS are glued in. I will be getting a quote for a replacement on my wagon this week, I'll post it when I get it. Dan, you pay for my gas and I'll get that tranny(if its in PDX)
  11. Actualy its not an alingment. Its the toe in. I replaced the front air on my XT6 also and noticed that the bracket on the struts had to be massaged to fit the hub. This certainly changes the toe in and may need to be adjusted. Hopefully they can do it right at a shop for you.
  12. How about a better explanation on how you shortened the springs? Others may want to know how you did it(or is it a trade secret)
  13. Well, I congradulate you You are one of the few that have actually done the conversion, and made it work. I second the request for USRM placement.
  14. I see the person that outbid you has bid on another Subaru also. This guy trying to corner the market on old Soobs, or what?
  15. Check this site out, they may have an answer for you. I have the same tranny, but havent had the car long enough to know all the problems with it. XT6.net
  16. I assume all pics need to be of HP members and thier outings? I have a few pics that might look good on the site. I will have to go thru them and seperate the best and send them to Tex.
  17. Maybe the XT6 TB TPS is acting up. Is it wired the same as the spider? Picking your brain a little, might be doing the same upgrade.
  18. Sounds like fuel starvation. But you say it was like this before the spider intake and XT6 TB, so now my thinking that theres to much air being forced in doesnt hold much now. Might need to find some bigger injectors or bigger fuel pump maybe?
  19. LMAOAROF I just looked at the message under his screen name Its ok, I know he will fix it. But, DOH!
  20. Hey, Qman may have some pics a little later of his escapades after the earleir X-Mas tree scouting run today. He brought the Brat by on the trailer, in the dark, and I could barely see it(you all know its silver). A local farm decided to let the crazies around here take a run thru the pumpkin patch. $100 if they could make it thru. I'll let him finish the story, with pics hopefully. Oh, and nice body work there Zap
  21. It looks alot like the Dodge Rampage from the mid 80's.
  22. If you dont have anything to contribute, then dont visit This is whats been needed for a while now. When folks have questions about mods and stuff, they dont have to flood the Main board weekly with the same questions.
  23. I dont know about you guys, but check out that engine bay some more. Thats a nightmare! I think it needs a updated EA81T in it.
  24. Heres a link to previous discussions. GM one wire conversion
  25. The temp sending unit on a EA81T is on the gooseneck below the T-Stat, and it only has one wire from it. This goes to the gauge. There is a seperate sensor on top of the T-Stat that might be sending readings to the ECU. If the person that was selling the manuals a yearago had sent me the elec manual I bought from him, I would be able to tell you more about it
