105
even 04 soobs have them in the tank, maybe not all models though. Used to have to drop the pan on auto transmissions to change the filter - changing a filter on an assembly pulled from the gas tank doesn't seem much different. S11 Forester, part number 34; http://opposedforces.com/parts/forester/us_s11/type_17/intake_and_supply_system_turbocharger/fuel_tank/illustration_2/
supposedly, there is a 'clear flood' mode triggered in the ECU at full throttle during start only. The ECU will cut the injectors off/way down so a flooded engine has a chance to start. Some people run into this in cold weather when they start the car, move it 20 feet, turn it off, get out to close a gate or garage door (for example), then try to restart. The cylinders can have too much fuel sitting in them.
In the US, all cars were required to be OBDII in 96 so, those counter jockeys need a lesson. Some 95s and maybe a 94 Nissan were even OBDII earlier than required.
throttle cable may need some attention/lube. possible throttle position sensor problem i guess. can you read the codes(s) ? AutoGroan and places like that will read CEL codes at no charge. most people report good luck with inexpensive knock sensors as from ebay, rockauto, etc. Clean the block where it goes on, point the cable the same direction as the old one, don't over torque the bolt. maybe someone else will chime in with advice.
I think the best approach would be to swap in a WRX or possibly an STI engine. check over at NASIOC for lots of info on stuff like that. But, even as is, some suspension and brake and tire upgrades could make the car a lot of fun to throw around the corners. Anything can be made faster with enough $$$ ,but, 'the Man' doesn't let you go too fast on his roads, he doesn't really care how flat you can turn corners though!
very odd symptoms, maybe you have a wheel that is dragging and the small extra brake pressure is locking it up, engaging the ABS? I dunno what the symptoms would be like if there was air in the ABS lines but, perhaps you need a very extensive bleed of the entire system, or a vacuum bleed or ??? do all the wheels turn freely with no odd sounds?
after a brief search, I did see a coupla posted ECUs that ship worldwide on ebay, did you try there? a dealership may be able to at least confirm if the ECU is damaged, or just needs reprogramming. also, I THINK there may be a couple availble thru this German site - do a search using the number 22611AJ220 http://www.autoteileplus.de/
seems like a good chance that's a bad ECU, also, wiring, connector or general electrical problems I guess (did the car ever suffer a severe issue with battery connections?, jump starting?, bad alternator? and flooding in the car? rodents damaging wires?) check; http://www.datsc.com/tabid/122/OBD-Error-Code/P0604/Diagnostics/subaru/Default.aspx http://engine-codes.com/p0604_subaru.html http://www.rs25.com/forums/f72/119103-p0604-i-have-cel-can-t-find-info-anywhere-2.html
