1 Lucky Texan
  1. I borrowed them from Autozone. they look like the pics I posted here; http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/36263-2003-w-h6-baja-springs-kyb-struts-done.html#post366727
  2. it's been decades since I had a car with that symptom - needed master cylinder rebuild.
  3. torque seems very flat! my WRX is 'peaky' feeling and I don't like that.
  4. maybe pull all the fuses, replace the link and sbfs, then start putting fuses back in until the magic smoke comes out again?
  5. I've never done it, but they have buckets and shims. Supposedly the seats wear, the valve gets 'tighter'/doesn't seat well, gets burned. Dunno if running regular vs premium might accelerate the wear.
  6. I don't think it explains the whole problem, but shouldn't the rad cap have allowed the system to equalize and prevented a collapsed hose?
  7. I know you already replaced the diff bushings, but, I've read that there are 'helper' pieces and maybe full aftermarket poly units that go in there. maybe Whiteline or prothane, etc. Also, I believe cardoc over on the outback forum used 3M windo-weld to create some bushings. just mentioning in case someone else reads the thread with diff bushing problems.
  8. try pulling fuses and relays until the sound stops, see what circuit is involved.
  9. was fuel still being pumped in from the injectors? or id that injector stuck open w;ever? could be cylinder wash-down from too much fuel. Of course, could be some other/worse things - just suggesting something kinda hopeful.
  10. in addition to the back of the socket itself being fused, I think there's a fuse in the fuse box too.
  11. evidently, I've been diligent about topping off the washer fluid in my wife's 03 OBW and recently learned that, wisely, Subaru has arranged the rear window's pump to have an inlet at a higher level in the tank, than the front windshield's motor and the rear will stop spraying while the front still sprays. So, instead of troubleshooting a blockage, I just needed to add fluid. On my WRX, I replaced both the drive belts. Took the opportunity to put some anti-seize on the adjusting screws. figure it might help reduce corrosion down the line.
  12. does it change turning/sweeping left vs right? sometimes the change in load while turning will make the intensity of the sound vary in a bearing. do you have a remote infrared thermometer? sometimes (not always) a bad wheel bearing will be 10-20 degrees warmer than it's companion on the other side. Try to measure immediately after stopping. (dragging brakes could warm up a wheel too.)
  13. first suspect would be the dust shield rubbing on the rotor. I suppose the parking brake could need some adjustment.
  14. cutting the trace is good technique. It's reversible. scrape the solder mask off the trace on both sides of the cut and bridge over with solder - or a strand of wire (like 28 gauge wire-wrap wire) and solder over the gap.
  15. just seems to me, the magnet would be more loaded than he reported. sweeping a magnet through some of the fluid should tell him if it's steel.
  16. yeah, I didn't mean the column, but that piece you indicated. (although I don't think it's like the pic in the link) I've read the module is behind the radio in 2000 or maybe 2001 so, hope it IS behind that kick panel. rather have a module in my hand before I take my wife's car apart though since it isn't 'critical' to driving the car. Since I can vary the lighting from 'incredibly dim' to 'extremely dim' , I know the stalk control is working at least.
  17. seems to me, the 'sparklies' must be aluminum. Otherwise, seems like they'd be on the magnet. so, would this mean something is out of position and rubbing on the case? what's the most likely scenario for that?
  18. do you mean pull the plastic trim under the column? Looks like a screw on the right and maybe a couple of push-clips on the door side. Is that it? it certainly is a mess up under there and just looking from the floor, I couldn't see anything that made sense. Oh, I know the green connectors should be disconnected except for certain test purposes, but there was a disconnected white conn. as well. Couldn't see where it might go, it is near the green conns. and has very little 'slack'. anyway, if anyone knows of a drawing or good diagram/photo of what that area looks like and where this module is, i would forever be in your debt if you could point me to it. I don't WANT it to be behind the radio, but it seems it is on earlier year models. PLUS, I'm told by Fred Beans that this module is discontinued and no one has any. maybe I can disassemble and troubleshoot it?
  19. I think I got only about 1/4 to 1/2 teaspoon fo sludge off my diff plugs so, maybe things aren't too bad yet? used diff is probably best. From what I've read, the viscous LS function might be worn-out by 60K miles anyway so, that may not be a factor. Outbacks with the All Weather package got the VLSD, if the ratio is the same, it opens up more cars to look for.
  20. the SSRs and the Enkeis I've had were both made 'for' soobs and had no adapters or xtra holes. But i have seen aftermarkets like you describe. (does Enkei make the OEM rims for subaru?)
  21. if a rim is positioned/centered by close fitment around the hub - it's considered hub-centric. If some rim from a different car is fitted, the hole for the hub might be smaller or larger. larger 'might' be OK - but an adapter could be required - otherwise you are relying on the lugnust to center the rim (lug centric) and take all the load. Might be OK - but not advisable. The offset is basically how the wheel is positioned to place the load directly under the bearing. If the offset is wrong, the rim will be pushed-in or pushed-out and, in addition to possibly rubbing on the strut/spring , or the fender, it puts an offset load on the wheel bearing which might lead to early failure. much of this info applies; http://en.wikipedia.org/wiki/Wheel_sizing most people would opt to +1 the rim size for new summer rims. so, look at 17 or stay with 16.
  22. well, the new rims 'should' be hub-centric (or corrected with an adapter) and have the correct offset (within a few millimeters anyway). And they must clear the caliper. Going down in size might mean caliper interference. a shop like Tirerack or Discount Tire would likely only recommend correctly sized rims. shopping the used market, you will need to confirm fitment. you might wanna read some of the 'sticky'/FAQ threads here; http://forums.nasioc.com/forums/forumdisplay.php?f=88 no wiggle room on the 5x100 unless you somehow change your hubs. I THINK the 100 is the diameter of the circle on which the center of the 5 lug holes are positioned. basically, it's the spacing of the lugs. Some newer Soobs have larger spacing so, be careful.
