105
have it scanned for pending codes. maybe you have a sticking valve. seems unlikely to be a TB issue since it's intermettent. might be good to put a vacuum gauge on it and start moving pushing pulling on hoses and harness bundles. If you can make it stumble, then investigaet for cracked vacuum lines. If vacuum is steady and it stumbles, look for loose connectors, bad wires, etc. has the car generally been well cared for? plugs and fluids changed per schedule, etc. ?
when diesel boxer come-out?
1 Lucky Texan replied to Suba_GL_87's topic in Meet n' Greet. Your USMB Welcome Center
this is a thread posted by a guy putting the EE20 in boats; http://www.ultimatesubaru.org/forum/showthread.php?t=125146&highlight=boxeer -
oh yeah, I thoght he meant as an option in a vehicle. check here; www.boxeer.com there's also a coupla vids on youtube of one swapped into a *OOPS!* - yeah, I thinks it's a Vanagon. -
I think fairtax has a great post. but cnydauve raise the question - somewhere there is a pressure sensor that must tell the pump to shut off. maybe it's 'on' and shuts the pump off too soon or at too low pressure. Might be worth pulling some plugs to see if an injector is leaking/stuck open. where's mccracken, he needs to come back until we ...................... . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RELEASE MCCRACKEN !!!!
I don't keep up with Subaru News & Rumors but, due to diesel emissions regulations and maybe other reasons, I doubt there are plans to bring it to the US. They sell fairly well I think overseas. maybe 20% of sales in Australia. -
pull the plugs and compare - if a cylinder has that much coolant going through it, that plug should look a lot different.
I have no solid feeling about what's wrong. Given the time the car sat with low or no fuel in the tank, I'd say it's possible there's some buildup of varnish or something keeping the fuel level gadgets from working right. Have you confirmed fuel gets through the fuel filter? And maybe something is gumming up the IACV?(seems like it shoiuld run with the pedal off idle????) I'd also suggest there could be an electrical ground problem - seems unlikely, but it might explain the weird gauge behavior. odd
If you get your nose next to that spot on the hose - is that the smell? I dunno, it just doesn't seem like that could be the problem. possible I suppose. Our 03 OBW had to have the a/c discharge and intake hoses replace back in , uh, 06 i think, anyway, just barely in warranty. The dealer said the hoses were leaking. I assume he meant the hose itself or they would have replaced the o-rings I guess.
rad cap?
Your Advice in Buying a Subaru...
1 Lucky Texan replied to cbr99f4's topic in Meet n' Greet. Your USMB Welcome Center
I have some very general advice; the year range you are considering is generally filled with reliable cars. Yes, there are some specific quirks and known problems, but nothing unmanageable. A car brand's reliability becomes less and less important with age. The individual vehicle's past maintenance and present condition are most important and it will pay most people in the long run to take their time to find a good vehicle and have it checked out by the best authority available. If you will have the entire family plus 'gear' in the car, frequently fighting highway traffic - consider searching for a 6 cylinder Outback. someone here may be able to recommend a mechanic's shop that would inspect any car you were interested in near Detroit. you might like to visit www.cars101.com to get an idea of different model's standard equipment and accessories thru the years. -
Today I used the vacuum line on the BPV to introduce about 1/3 can of seafoam into my idling car. I stalled it twice. Restarted and kept 'sipping' the solvent. At the ned, i was able to make it stumble, then it revved up a little at which point I plunged the small line I was using fully into the SF and stalled the car. Now, I'm going to let it sit for a while. I'll start it and drive a round a little later. threw the remaining 2/3 can into the wife's Outback. Um, I suppose, if the entire episode I experienced WAS/IS due to sticking TG valves, the causative substance must be oil since the injectors are below/downstream from them. That seems to only leave oil as the suspect substance, from where?, the PCV or turbo? Is rust a possibility?
The Awesome Vehicle Picture Thread
1 Lucky Texan replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
Citroen U55 Cityrama Currus: Parisian spaceship from the 1950s! When we are considering which bus design could be called "the strangest ever built in history", then this hyperfuturistic double-decker bus certainly comes right on top. People at the time wondered if this thing came from outer space, escaped from a Flash Gordon movie, or was some sort of a mirage... but in reality this was a very comfortable tour bus built by Citroen on U55 truck chassis for a Paris tour operator Groupe Cityrama. The fantastic shape was designed by the French coachbuilder Currus - and unleashed upon excited visitors to Paris in 1950:
