105
See, I agree with something I heard once on a car talk radio show. I want a system that UNlocks the car above 30-40 mph and locks it at lower speeds. Reduce car-jacking attempts at stop lights, but, if you're in a wreck at freeway speeds - they might be able to get you out without waiting for jaws-of-life to cut the car apart because the doors are locked.
doesn't Jeep have a straight 6? man, I remember a coupla vehicles I drove, the 51 Chevy had HUGE amounts of room on either side of the straight 6 motor. But those vacuum wipers - ugh, horrible. The 64 Rambler I had was extremely reliable and fairly easy to work on. Older cars were not quite as binary in their failures, they would gradually let you know when things needed attention (but they needed attention almost all the time). Seems like many times nowadays, a car just stops. At least there's a computer on board that might tell you why!
I'm gonna just throw out a coupla points. These are just thought experiments but might have a small amount of validity. Subarus have 2-3 odd design features which, in addition the their overall longevity, contribute to the likelihood of someone experiencing HG failure. They have decent utility and quality, that, eventually, someone may own the car that doesn't understand the need for 'burping'/special attention to coolant refilling. Also, the cars do not behave well with aftermarket thermostats. These increase the likelihood of overheating at some point in their life. Their utility also means they may get driven in road/environmental conditions that are more harsh than other vehicles. And, obviously, they have 2 headgaskets. In a 'raw' sense, that doubles the likelihood of experiencing a failure. This does not excuse the poor performance of the HGs in the mid-late 90s, nor the external leakers in the period just after that. But, some of the above may contribute to a notion that, eventually, any/all Soobs are gonna need HGs. It may even statistically be true - but just because the Fiats, Suzukis and Kias of this world are long in the junkyard for other reasons BEFORE they have a chance to blow their gaskets, is not the fault of Subaru. And before you think I'm just an apologist, I'm very upset at the failure of the secondary air valves in my WRX. Fortunately, I found a workaround out of the Subaru 'tuner' community. I COULD just replace the valves, but I have found no indication they have been redesigned/improved and I fear they will just fail again in 4 years. Anything that can happen to any other car can happen to a Soob. In a general sense, I think they're well made. better than several cars I've owned and as good as the best cars I've owned. But not flawless.
doesn't matter to the center diff as long as the rolling circumference is very close (1/4" or so) If the weight of the wheels is much different, you may 'feel' some subtle difference in acceleration or handling - but I doubt it, still OK on the AWD system. Have you tried that 'green slime' stuff or a can of FIX-A-FLAT?
someone may know for certain - but they may have switched from the style with the spring pin holding the axle on sometime around 2005(maybe started with the STI on 04 ?). I dunno about 'older generations'. The axles on the bottom of this pic seem to be 'new' style if you look at the far end - with the splines built on. The top ones are like my wife's 03 Outback. A spring pin holds them onto stub axles that stay inside the diff. I guess they've been built that way for decades. No fluid loss when changing axles. Dunno why they changed.
Yeah, sry, my wife drives an 03 H6 Outback wagon. I recently did some work on it and one repair was an axle replacement due to split inner boot. My car is an 06 WRX wagon. If the smell comes and goes, it might mean that sometimes the seal on the front diff is leaking and sometimes not. If possible, lift he front of the car, secure on jacks, and turn the wheel all the way left, then check the left inner axle joint. the (probably green) 'cup' part should stay in the same position and not shift in-out more than , maybe, a 2-3 mm. maybe someone else here can confirm that. Then, check the right side after turning the wheel all the way to the right. I should also mention that, it's possible grease could be pushed out either end of a rubber boot. Particularly on a rebuilt axle. If it was over-greased or the bands are not tight, etc. That also might happen during or after extreme turning of the wheels when the boots are stretched/compressed a lot. They wouldn't have to be split to deposit some grease onto the exhaust. The 'split boot problem' just happens frequently because the inner boots are exposed to so much heat from the exhaust pipe.
the wife's 03 H6 OBW has had an intermittent noise. I never heard it, but from reading about common problems, I changed the bearings in the serp belt idler ans tenioner pulleys. The old bearings felt rough, but the pulleys were running true. Anyway, she said the noise was still coming back. Worse on cold mornings. More reading led me to suspect the power steering. It did seem a little noisy to me on one test so, I found info online about the system possibly sucking in air at the top connection on the pump that comes from the reservoir. Today I pulled that off, slapped some dielectric grease on the o-ring and around the circumference of the hose-end and reinstalled. Then i lift the front wheels and exercised the wheels lock-to-lock many times. Then, I started the car (carefully, in park with the e-brake well-set) and exercised the wheels l-to-l again. The system did seem to change, very subtle but maybe it's better than before. I then went and showered, letting it sit for a while, went back, did the l-to-l business again. hope she doesn't hear the sound again. dunno what to do now!
^^^^ I'm guessing this is what happened. And, if the diff was still warm from driving, getting the vent under water is even worse cause, the water will start cooling the diff creating a little suction - so even more water gets inside. But, did the driveshaft rotate at all? Need to try in neutral with both rear whhels off the ground as said.
