105
if there are bubbles after all that turning back and forth , you still have a suction-side leak. could be from a bum rebuilt pump. if you have juddering but no bubbles, you got a bum pump.
- 10 replies
- 1
- powersteering
- steering
(and 2 more)
Tagged with:
^^^ def check for leaks. Oil filter adapters, oil pressure sensor, cam/crank seals, etc. if the plugs aren't carbon-ing up and the car runs well - $3000 will buy a lot of oil. but, I can understand wanting to ameliorate the problem. Some folks have used marvel mystery oil or other treatments to free-up the oil control rings. Or, experiment with a high mileage oil or heavier viscosity oil? but, option 2 could get you an engine with half the miles of the present one. LKQ and car-part.com might have some good prices. maybe even try a different shop for the swap?
nah, I get it. I have had an unlocked car rifled-thru once, they didn't find anything but a made a mess and the battery ran down.(guess they didn't want the noise of closing the door?) And some prescription sunglasses stolen from a top-down convertible, but I usually don't have anything expensive in the car - I like having the option of parking and locking that car if we're making multiple shopping stops or traveling - but it really doesn't happen that often. the valet mode may be a good fit for you - you could always re-enable the security function if you did park the car with something attractive in it or in a skecthy area. Maybe leave a fob in the car and one at home?
It isn't just about whether a cop is passing by, most burglars aren't gonna want any level of attention - even a passing glance from bystanders. if some hooligans are hanging around the car, you can set-off the 'panic' alarm as you approach it. It's a deterrent, not a guarantee. Even if it went off, then timed out, when you return to the car, it will beep an xtra time and you'd know 'something' set-off the alarm. You could at least check that your lugnuts weren't loosened in an aborted attempt to steal rims or the cat converter hasn't been removed (that happened to a coworker on his SUV !) ((does it have a shock sensor? my car does))
some aftermarkets may be OK, there is a specific Stant part number that many folks have used. but, typical t'stats are a known problem.
- 16 replies
- 1
