My '83 GL: The Ski Wagon
I got the blocks off. I did break one bolt. Its flush with the head (Boo) But I can use the other two holes for the flange. Wish I didn't break that one bolt, last one too.
Now I will definitely need an EA82 header for now.
  • Replies 1.8k
  • Views 282.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • AdventureSubaru
    AdventureSubaru
    Part one of the journey was completed just over a week ago. My brother and I took the car to it's "drop point" where it will be picked up by the new owner soon enough.   I hadn't seen the car in jus
  • Mechanical_misfit
    Mechanical_misfit
    sorry for the delay!
  • I swapped the DS front fender last night. The original was totally rotted off on the bottom and something was misaligned. It caught on the door every time I tried to get in or out.     It's sti
Posted Images
broken flush isn't an issue as long as it's truly flush :)
the other two holes are the ones you would use anyway :)
You know, you're right. I wasn't thinking about it, but yes they are. Yeah, it is flush.
I was thinking about getting a transfer punch, smack it dab in the center, and keep stepping up drill bits until the bolt is very thin/hollow, then it might just break on or the hole. Maybe I shouldn't bother? Leave well enough alone. :-p
yeah. just hit it with a dremel if there's anything not flush and call it good... the flange area of the head can only take so much beating before it will crack the aluminum :)
I have to get the y pipe to the shipping place to get a quote for you! What's your zip again?
That's quite the shiny brand new looking y-pipe jason has...
Too bad it has the long section sticking off it, unlike the EJ ones which are nice and compact. It's gonna be a pretty big box.
Thanks for the info on those blocks. Seems like Ill have to swap them over when I do my engine swap. Motor Ive got ready to go in doesnt have them... :burnout:
Actually, I'm probably just going to buy the 1-7/8" 90s and 45s I need, and will start building my UEL header. Its gonna cost enough to ship the EA82 header anyway ($60ish) via USPS.
So, no worries Jason. :drunk:
Ok no problem!
So, I started grinding and painting the engine bay. I like how the semi-gloss engine enamel looks, I need to buy a can or two more to finish it. The Engine enamel is good stuff, has Ceramic in it, so it lays down very thick, smooth and dries quick!
Quick question, I removed the cable from the clutch fork to the Hill Holder valve body. Is this gonna be an issue? I do not use the holder, don't even really understand how to use it. I kinda wanted to remove the whole unit and reroute the brake lines, but that sounds like a PITA. Am I gonna have any repercussions from not using the cable?
If so, I can put it back on.
It acts as a clutch return spring as I recall. You may want to rig a return spring of your own at the clutch fork if you pull the cable. Other than that you shouldn't notice anything.
Ah ok. Yeah I have noticed some return springs on others, and wondered why. Good call!
Ordered a Fel-Pro EA82 oil pan gasket. O'reillys didn't have a listing for the EA81 gasket, but both oil pans are the same throughout Engine models.
The Oil Pan is the Same between EA81 and EA82? ... That's New info for me, I have never noticed that.
Thank you for Sharing.
... I like how the semi-gloss engine enamel looks...
Photos Please! ... :) ...
i got a set of ea81 headgaskets somewhat by mistake, ill put em in your box. that said i pray you dont have to use em. must suck to be all rusty, we just dismantled a 89 glw in under 8 hrs, mostly with my craftsman 19.2v cordless impact. car was straight too, you should be pissed:brow:
The motor comes apart just fine, like everything on this car despite the rust. Outstanding, really.
You got my goodies? :cool:
I was incorrect about the EA81 and EA82 Oil pans being the same. From under the car, they look identical, but the EA81 pan is larger in diameter. So the Fel-Pro gasket I bought is too small a square. At least I'll have one for the EA82 if I ever pull the motor :)
So, I will order an EA81 Fel-Pro gasket else were since O'Reillys did not list one. Parts Hut or NAPA should have it.
I will take a picture of the difference later in the day.
I was incorrect about the EA81 and EA82 Oil pans being the same. ...
Thank you for clarifying...
Kind Regards.
Dont bother with an oil pan gasket. Youll never get it to seal properly.
Red Fuji bond or Toyota oil-pan gasket maker.
I'm using the gasket to take up the gap and give the pan something to press against. I'm gonna seal both sides of the gasket with RTV Black. Kinda like what I do with Oil pumps and Water pumps. Double the protection!! (Sadly not so many teens follow this rule) ;)
Use up what gap?
All the sealant won't help when the gasket rots out and starts leaking. It'll just be more mess to clean up when you reseal it next year.
Use up what gap?
I'll remember this post a year from now, when my pan is still dry and clean. :-p
Ill be waiting.
Seriously, dont use a gasket. Even the dealer lead mechanic here in town recommends not using a gasket.
If your Subaru isn't leaking oil, its probably out.
