Smiley..........
Heahe,
I am making a deal on this tomorrow....
WOOT!!
It will get my axles and tires and EJ and trans/4.7 t-case, So, it will basically be the same size.
Cheers:brow::drunk:
  • Replies 373
  • Views 80k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Well, things are evolving again..
  • Yeah. I am building it to drive to the extreme. I have been doing extreme sports my whole life. There is one thing I learned. Wear the proper gear for the job, and you are able to do it again.
  • Thanks guys, It has been/is fun learning how to build stuff.   I have been on hiatus from this for long enough. I went and watcheedd some racing on Saturday and have the itch again.SO during this t
Posted Images
Me too.....
Holy ************in ************ mang....
I am ABOUT TO HAVE A GODDAMN yOTA!!!!!!!!
wOOT..CHEERS :drunk:
I always wanted to drop an Xtra cab on a regular cab frame and bob the bed like that.
It will get my...EJ
Like!!! I really want to see a subaru boxer in a yota truck engine bay (my preference would be EG33.....but EJ would do just fine)
Yes:clap:
SHe got rrolled in and we took off his tires and wheels.I will be getting her together as fast as I can.
cheers
Edited by monstaru
Welcome to the dark side. Wheelin' will never be the same AGAIN!
I wheeled for years before i got into Subaru's B..:)
It will be nice to get back to live axles:)FOR SURE LOL
cheers
so, your yotaru is a hermaphrodite? lady baja?
UMM, It;s gonna be a Subota...
And ?Hermaphrodites have both male and female parts.I only drive girls:drunk:....LOL
cheers
Yes:clap:
SHe got rrolled in and we took off his tires and wheels.I will be getting her together as fast as I can. /\
cheers
mmhhmmm, do explain Brian...
Easy to explain.
She will get a Subaru heart.:brow:
cheers:D
Feel free to give me grief about this, but....
I hafta ask why? 'yota engines are pretty good. And if it needed a motor, a chevy 4.3 is a fairly common swap. Oodles of torque, especially in a light truck.
Or is this a case of being different, and using the parts you already have layin around?
He knows that if it doesn't have a subaru motor in it I won't let him play with it in the mudpit at next years WCSS. :drunk:
Let me?:burnout:
That sounds like a challenge :Flame:
LOL
SPAZO, A chevy 4.3 brings more problems.More power equals more breakage.
I am pushing it with the Subie motor as it is.
AND , I have the engine, bellhousing, and desire to use a setup that I already know.
AND , I have always been , well, different...
The truck was not attainable for me with the engine in it.
I really did not even want one with cage work done already, because I wanted to do it.However, it is kinda working out to be way easier in the long run with attaining this truck.
Hi, My name is Monstaru(IE:a derivative of Subaru and different partsmaking up the sum or whole of a vehicle),and I am a wheeler. LOL
Besides,how ************ing cool is it that I can put a Subaru engine into a badass Toyota truck?:clap::cool:
Cheers
Also, I really would like to talk to you about some sticks for this....when you get this hit me up with your info sos I can get ahold of you again.
cheers
  • 2 weeks later...
Finally got around to welding these centers in.
moar weld porn
The shop at work afterhours..
1/4 inch pressed ceenters from trailwortyfab.com, into HMMWV double beadlocks with rubber runflats.
Thats my wheels.
Hopefully this will go smoothly,I am gonna have to try an retrofit a Subie hydro clutch to the Toyota system.Mr.Hinchers best...
I have the ************in shifter rail in backwards!!DOH
Otherwise theses would be tight together by now.....
More to come i guess.
I shall now lay it out for you:
85 Toyota shortbed frame with Ext cab, double bobbed bed
Ej frankenmotor
W56 5 spd
4.7:1 t-case
4.88 axles with lockright in front , v6 third out back (probably gonna weld it)
trussed,built to ************ front housing.Rear needs some love, but I think I'll wait until I put my v6 rearend in there.
From Stella besides the motor
02 WRX seats, cb, lights, etc....
So far so good.
Need hysteer, ARP knuckle studs, add 5th stud, and possibly a new ring and pinion for the front.
Otherr than that , Wire up the engine to the Yota harness, and make some engine mounts.
Hopefully I have an engine to use as a mock up within a week.Then hopefully after the holidays I'll have some dough to finish throwing at her.
Cheers
Edited by monstaru
Have you done any measuring of the engine bay? I've long wondered if a Subaru engine would fit between the frame rails of a Toyota.
That is what I am tackling now.I am the point I need an engine to lay up in there.I am working on it.trust me , damnit :)
It IS going down.
This is kinda my dream.
I will make room if there is not
:D
SOON.SOOOOONNNN!!!!!!!!!!
cheers
Ya this is gonna be good... I think (read: am not sure) that the heads will actually be close to being above the frame rails based on the elevation of the trans etc.....
On another note alltogether, I think my FJ80 needs a 3.3 and a manual tranny, I am SURE they would fit under the hood of that thing. Realistically it will have a diesel in it before I put a boxer in it though.....
Yeah, a bigger motor just brings bigger probems:horse:.Ima be pushin it with a frankenmotor.
But hopefully it won't turn out to be an issue.
I would LOVE to do a diesel conversion next....:D
cheers
So, the distance between the 82 Toyota framerails(which is the same up to 85) is 22 ish inches.
The width of the EJ is about 29 inches.Hopefully my luck is with me and I can keep it high enough to stay intside of my shock mounts.Or I might have to take the ford towers out and make some Tube mounts.
We'll see.I may just have to flatbelly the whole shebang.Just so the engine is high enough. :)
cheers
Edited by monstaru
