13" Justy wheels ?
Justy's have a 4x100mm bolt pattern, I think it's the same as the old civics. I'm pretty sure there are a bunch of options.
I think the old hondas, vw, toyotas, and fiats (and possibly others) all have that same small four bolt pattern, though not sure if the offset is the same on all of them.
Be careful if you have an 87 or 88 Justy. My wife got one, and I put 13 inch Honda wheels on it. (4 x 100mm) But the rear wheel well area on the 87 and 88 is smaller than the 89+ years. I had to remove about 1/2 to 1 inch of body material from the front outer portion of the lowermost part of the well area to avoid tire rubbing when the suspension was compressed (bumps). Also had to cut some of the plastic from where the rear bumper fits on the aft outer part of the well.
As this is strictly a driver I wasn't too concerned with cosmetics. The front tires posed no problems. I could have repaired the areas I did surgery on to look stock however wasn't worth the effort.
The 13 inch wheels/tires perform much bettter in snow than the 12 inch.
Of course a lower profile tire might have helped but my main reason for doing this was to get a longer circumference overall for snow.
Good Luck!
I tried a honda and a toyota rim both have the right pattern but the center hole is to small hits on the front but not the back hub
I'll go out and measure one of my steelies for center hole dimensions and back spacing.
For winter duty I run Nokian NSW's in front and old Hakkapelettia NC 10's in the rear. I simply don't get stuck with these tires.
Matthew
  • 2 weeks later...
how much too small?? if it's just a little then it should be okay to enlarge it.
also try a saturn/GM 4X100 wheel. it has a larger hub center.
Fiat's use 4x98, same as Alfa's.. And won't fit 4x100.
Pretty much every old and new small jap car with 4 studs uses 4x100. Very popular size. But don't just go on that, try and measure it.
Hey Scott,
This copied and pasted:
"The justy takes PCD 4x100, Offset 35-38, Centre bore 59.0."
"The wheels from any of the following cars will fit a pre '94 Justy. I had 185/60R13s on my '90 2WD."
"ACURA ·Integra 86-ON
DODGE/CHRYSLER ·Neon 4 Lug 94-ON ·Eagle Summit 86-ON
DAEWOO ·Lanos 98-ON ·Nubira 00-ON
FORD/MERCURY ·Escort 91-ON ·Tracer 91-ON
GEO ·Prizm 89-ON ·Storm 90-94
HONDA ·CRX All ·Del Sol 93-ON ·Civic 80-ON ·Prelude 82-91 ·Accord 80-89
ISUZU ·Stylus 91-92 ·Impulse 91-92
KIA ·Sephia 94-ON
MAZDA ·Miata 90-ON ·MX3,GS 92-ON ·Protege 90-ON
MITSUBISHI ·Mirage 93-ON ·Precise 87-94
NISSAN ·Sentra 86-ON ·Pulsar 87-90
SATURN ·SC-Coupe 91-ON ·SW-Wagon 93-ON ·SL-4 Door 91-ON
SUBARU ·Justy 90-94
SUZUKI ·Esteem 95-ON
TOYOTA ·Corolla 89-ON ·Tercel 89-ON ·Paseo 92-ON ·MR2 89-90
VOLKSWAGON ·Golf II & III 85-ON ·4 Lug Jetta 81-ON ·Cabriolet 92-ON ·Rabbit 76-91 ·Fox 87-93 ·Corrado G60 89-92 ·Scirrocco 79-89"
How's it going with the search for wheels for your Justy?
For next summer, I'm going with a 195 45 15 tire. The car has 165 65 13 on it now. After looking over the wheels available, I'll probably go aftermarket with a 40 mm offset. As this car is so light to begin with, I want the lightest wheel I can get, for the money I'm going to spend. 10 to 12 pound each range.
Bigger tires and wheels, more weight, more diameter, will kill off some performance of your Justy. Throttle response takes a hit and the car won't handle as well over all.
One carbureted Justy I put 70,000 miles on. The stock size is 145 12", when I put 155 12"s on it, I could tell they weren't as good as stock, overall.
Tal
never thought of a neon I happen to have a old set of those
Hey Scott,
Here's some of the choices we have in diameter:
145/80-12>21.13 Stock on any carb Justy, probably.
165/65-13>21.44 Stock on any FI Justy, probably. Not much selection and the Bridgestones in this size are expensive.
155/80-12>21.76 I had a set of these on a carb Justy and hated them.
195/45-15>21.90 My choice for the pimped Justy. Lots of choices here in price.
185/55-14>22.01 Not sure what's available with these.
165/70-13>22.09 The tire I see most on FI Justys. Readily available and cheap, compared to the 165/65-13. Fits the wheelwell with no mods.
175/70-13>22.64 These are too big and will require modifications to fit them to the wheelwell.
HTH
