Official 6-Lug Re-drill Thread: Now in the USRM!
260 replies to this topic
#51 obk25xt
obk25xt
    Subaru Fanatic!
  • 502 posts
  • La Center, WA
Posted 07 April 2012 - 10:00 AM
Here's what that looks like.
http://www.ultimates...&pictureid=3107
WIRES!?!?!? Really???? :confused:
I'd like to see a pic of these mounted on a subaru... Hopefully with fully reversed offset, stretched tires, and Ice-T in the driver seat...... :rolleyes:
:Flame:
#52 Quidam
Quidam
    1000+ Super USER!
  • 1,416 posts
  • USA
Posted 07 April 2012 - 10:51 PM
Really, lmao:) Got them off a Nissan pickup.
http://www.ultimates...&pictureid=3110
#53 987687
987687
    Rally Suby!
  • Gold Subscribers
  • 3,244 posts
  • Midcoast Maine
Posted 08 April 2012 - 04:05 PM
I wouldn't try to weld up the extra holes. There's too much of a chance you're going to warp the rim doing that. To get it hot enough for decent penetration, it's going to warp.
#54 O.C.D.
O.C.D.
    Subaru Fanatic!
  • 533 posts
  • Colorado Springs
Posted 09 April 2012 - 05:05 PM
I was thinking some steel rod to use as a plug. Have a bevelled edge on the plug and use the bevel holes on the wheel. Use enough to get a tack or two going and you won't need to sit there and try and fill the hole with weld?
Anyone think that would work?
#55 987687
987687
    Rally Suby!
  • Gold Subscribers
  • 3,244 posts
  • Midcoast Maine
Posted 09 April 2012 - 05:10 PM
I wouldn't try to fill the holes with welding wire or rod anyway, I'd weld a patch in. But why? If you weld enough to get good penetration you're going to warp the rim. If you just tack it in place really quick, it's merely cosmetic. I guess if that floats your boat, go for it. Or just get hubcaps.
#56 shortysayhi
shortysayhi
    Subaru Fanatic!
  • 409 posts
  • Conifer (outside denver)
Posted 09 April 2012 - 05:11 PM
I have found 2 sets of 4. Of these wheels in co. They are asking 100-130. And the wheels are Chevy wheels as well as trailer wheels. (the width might be slightly different tho)
#57 TheLoyale
TheLoyale
    Safariwagon: The Legend
  • 6,522 posts
  • Waukesha, WI
Posted 09 April 2012 - 05:22 PM
Chevy wheels have a very incorrect offset and will stick out of the wheel well, and will result in cutting the fenders drastically, fyi.
As for filling holes, good thought on possible warpage of the rim.
#58 FlatFourFrenchy
FlatFourFrenchy
    USMB Regular
  • PipPipPip
  • 60 posts
  • Central Missouri
Posted 09 April 2012 - 08:21 PM
I found some Chevy Colorado 2WD wheels. 15 x 6 and offset to inside. They fit right up to the larger truck six hole hubs. I am still trying to talk the sales manager out of them for a decent price since I am not sure if they will work. I will keep you posted.
#59 TheLoyale
TheLoyale
  • 6,522 posts
  • Waukesha, WI
Posted 09 April 2012 - 08:53 PM
The Colorado wheels probably have a closer offset to the Subarus, mainly its the old 70s/80s GM wheels which stick out a lot :)
#60 kanurys
kanurys
    High Altitude GL
  • 673 posts
  • Durango, CO
Posted 10 April 2012 - 12:36 AM
I thought the Chevy 2wd wheels had too small of a center hole ...
#61 FlatFourFrenchy
FlatFourFrenchy
    USMB Regular
  • PipPipPip
  • 60 posts
  • Central Missouri
Posted 10 April 2012 - 05:21 AM
I will measure them. They have a rather large hole to fit the trapped rotor style hub on the Colorado. The center hiole is 3 and 7/8".
Edited by FlatFourFrenchy, 10 April 2012 - 07:16 AM.
updated
#62 TheLoyale
TheLoyale
  • 6,522 posts
  • Waukesha, WI
Posted 10 April 2012 - 06:16 PM
3-7/8" should be just fine, Stock Subaru caps might even clip in the hole.
#63 TheLoyale
TheLoyale
  • 6,522 posts
  • Waukesha, WI
Posted 10 April 2012 - 07:02 PM
I am now debating on either drilling the Wheel, or the hub... Hmm. Does anyone have a picture of a redrilled hub? The front/disc style would be more helpful.
#64 Idasho
Idasho
    Garage Junky
  • 864 posts
  • North ID
Posted 10 April 2012 - 07:30 PM
If you are not set on any particular 4-lug wheel, go for the 6-lug swap.
I would have, if I had not already spent $1200 on two sets of new tires (winter and summer) on 4-lug 13" wheels. :horse:
#65 TheLoyale
TheLoyale
  • 6,522 posts
  • Waukesha, WI
Posted 10 April 2012 - 08:18 PM
6 lug swap? I want to say I remember this, but not sure. Have a link?
#66 Idasho
Idasho
    Garage Junky
  • 864 posts
  • North ID
Posted 10 April 2012 - 08:49 PM
When i say 6-lug swap, I mean hubs drilled for 6-lug.
:drunk:
#67 TheLoyale
TheLoyale
  • 6,522 posts
  • Waukesha, WI
Posted 10 April 2012 - 08:52 PM
:drunk:
Gaatcha!
Is there even enough surface to do this on the front wheel spindles? I know drums have more then enough room. Picture of a redrilled wheel spindle would be tits!
Here is a thread from Canada, these look like a mess omg. I don't think these hosers know what der doing there eh.
http://montrealracin...drilling-wheels
#68 Idasho
Idasho
    Garage Junky
  • 864 posts
  • North ID
Posted 10 April 2012 - 08:55 PM
check this link out
http://www.subarubrat.com/6lugconv.htm
:drunk:
#69 Numbchux
Numbchux
    EJ conversion addict
  • 5,921 posts
  • Duluth, MN
Posted 10 April 2012 - 08:56 PM
few pics of the 6-lug conversion on my brat
Posted Image
rear disc hubs
Posted Image
#70 TheLoyale
TheLoyale
  • 6,522 posts
  • Waukesha, WI
Posted 10 April 2012 - 08:57 PM
Both are good posts, Good detailed pictures and a good link on "How To"
Thank you.
WTF is with those (Lift?) blocks? Looks rather scary.. :drunk:
Edited by TheLoyale, 10 April 2012 - 09:08 PM.
#71 czny
czny
    USMB is life!
  • 183 posts
  • S. California
Posted 10 April 2012 - 10:11 PM
I opted for the 14x6 Mazda truck wheels which have a smaller center hole(hub centric). Mounted the hubs on outer axle stubs & turned down the 4 nubs to fit on my bench lathe. Drilled starter pilots with a 9/16" bit from the wheel lug holes then drilled 3/8" pilots thru. Machined flats from the other side with a 7/8" counterbore & 3/8" pilot(enco.com). Then increased the hole to 35/64" in steps. Built up 3 short beads of weld around the hole with a MIG then cleaned up with angle grinder & die grinder. The hubs are steel & weld easily(Just not too much heat to warp them.) Used 610-322 Dorman wheelstuds(rockauto). Pressed studs almost to bottom of knurl & let torqued lugnuts square the studs to the hub.
87 GL wagon with 4" SJR lift, 27x8.5x14 Grabbers on Mazda PU whls.
  • Attached File  122.jpg   40.36K   38 downloads
  • Attached File  124.jpg   28.81K   38 downloads
  • Attached File  133.jpg   50.77K   45 downloads
  • Attached File  140.jpg   52.13K   40 downloads
  • Attached File  145.jpg   22.76K   40 downloads
Edited by czny, 10 April 2012 - 10:17 PM.
#72 Numbchux
Numbchux
  • 5,921 posts
  • Duluth, MN
Posted 10 April 2012 - 10:49 PM
Strut extensions. IMO the best way to do it. I helped design them, and a friend machined them. They're turned down from solid steel....probably the strongest thing on the rig.
#73 wentz912
wentz912
    Subaru Fanatic!
  • 376 posts
  • Kelso, WA
Posted 11 April 2012 - 12:22 AM
MOST chevy wheels you find from 2wd's will be 5 lug, not the appropriate 6 anyhow. Only a small amount of the newer, smaller 2wds use the right 6x5.5 you need for the swap. Other 6x5.5 rigs are Nissan, Mitsubishi, Dodge Mighty Max/D50, 4wd Chevy's (careful with this one) early steels often don't have enough backspace/too much offset, and later alloys dont have large enough center holes, recent model 4x4 Fords...i'm sure i'm forgetting some.
What size is the center hole on the back of these wheels? Reconsidering the six lug option for my car now that i have access to a lathe.
#74 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 4,835 posts
  • Roatán, Honduras.
Posted 11 April 2012 - 12:53 AM
This Really Looks Good!
Posted Image
rear disc hubs
Posted Image
I Did something Similar but 4 Lugs... Just Moved 'em to a More "Standard" (Popular) Pattern, as you can see ~► Here.
Kind Regards.
#75 987687
987687
    Rally Suby!
  • Gold Subscribers
  • 3,244 posts
  • Midcoast Maine
Posted 11 April 2012 - 07:41 AM
Say you're in a junk yard or whatever looking for a set of wheels. What's the proper way to measure backspacing?
Is it the distance from the inside of the mounting flange to the inner lip of the wheel?
