update: pb blaster didnt work :( Best penetrating oil for rusted screws?
27 replies to this topic
#1 starkiller
starkiller
    1000+ Super USER!
  • 1,153 posts
  • dupont
Posted 21 February 2005 - 07:46 PM
trying to change out my gas filler trim ring as its all rusted to he**, got new trim ring in excellent shape from yard, went to remove mine and none of the 3 screws will budge...what shall i use? wd40? pb blaster? torch? :D
thanx!
#2 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 21 February 2005 - 07:48 PM
PB blaster seems to work best. WD40 has been detuned massively in the last 2 years.
#3 85Sub4WD
85Sub4WD
    EA82 Junkie
  • 1,244 posts
  • Raleigh NC/Charlotte NC
Posted 21 February 2005 - 07:49 PM
I use good - old 3-in-one for moderately seized, and a combination of that and soaking in liquid wrench for very seized.
#4 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 21 February 2005 - 08:00 PM
Just used PB Blaster on my O2 sensor - it came right out. But for really stubborn problems, I use Yield. That's some really good stuff.
#5 phishy75
phishy75
    USMB is life!
  • 169 posts
  • victoria, bc, canada
Posted 21 February 2005 - 08:03 PM
Fluid Film works pretty well too. Costs a mint, but it works great plus its a really good rust inhibitor that doesn't wash away.
#6 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 21 February 2005 - 08:05 PM
Kroil is the best I've ever used, works great in conjunction with heating/cooling cycles, but the smell of it smoking off hot parts is NASTY.
Web site: http://www.kanolabs.com/
Gary
#7 swervey87gl
swervey87gl
    USMB Regular
  • PipPipPip
  • 82 posts
  • Mill Creek
Posted 21 February 2005 - 08:30 PM
I prefer the "breaking the bolt head, drilling, easy out" meathod. :headbang:
#8 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 21 February 2005 - 08:32 PM
its all crap, never works.
heat and force!
#9 4WDFrenzy
4WDFrenzy
    Certified Subaru Nut
  • 857 posts
Posted 21 February 2005 - 08:35 PM
One word, PB BLASTER(okay it's two, so what?!) This is the best stuff that I have been able to find. The stuff is just awesome! Don't know how else to explain it.
#10 starkiller
starkiller
    1000+ Super USER!
  • 1,153 posts
  • dupont
not sure if i want to heat and force the screws holding a gas trim ring in :D
#11 swervey87gl
swervey87gl
    USMB Regular
  • PipPipPip
  • 82 posts
  • Mill Creek
Posted 21 February 2005 - 08:37 PM
heat and force!
Hell yea, especialy on gas tank filler screws.
#12 Roundeye
Roundeye
    Eat, Live, Breath Subaru
  • 276 posts
  • LA (Lower Alabama)
Posted 21 February 2005 - 09:30 PM
MOUSE MILK!!!
#13 scubasteveo45
scubasteveo45
    USMB Regular
  • PipPipPip
  • 54 posts
  • Corvallis
Posted 21 February 2005 - 10:05 PM
Kroil is really good. We use it at the aircraft repair hangar I work at. The stuff is able to break apart 20 year old landing gear fixtures that get 3800 pounds of aircaft slammed down on them at 100 mph thousands of times over. We just let the parts soak in a big trough of the stuff.
#14 starkiller
starkiller
    1000+ Super USER!
  • 1,153 posts
  • dupont
Posted 21 February 2005 - 10:28 PM
well, got some pb blaster, still nothing...have sprayed them twice now w/about a 30minute wait time and they wont budge....shall i spray again and let it sit over night before trying again?
#15 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 21 February 2005 - 11:07 PM
Sitting overnight is good.
As someone else said, 'yield' is the stuff.. Good luck getting it though.
#16 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,184 posts
  • Central Iowa
Posted 22 February 2005 - 12:01 AM
those particular screws on the filler trim are a pain, even on a rust free one from TX... I ended up cutting/drilling them out....
I'd spray on the PB Blaster every day for a week, on the top side, and the bottom side after cleaning the snot out of it.....
#17 85Sub4WD
85Sub4WD
    EA82 Junkie
  • 1,244 posts
Posted 22 February 2005 - 12:09 AM
MOUSE MILK!!!
Ya know, I think that is what it all boils down to in the end ....
I would not want to try to get that stuff - I bet milking the mouse would be harder than yanking the bolt out with your teeth :D
My suggestion would be to drill them out given their location, or get a REALLY good pair of vise-grips, cinch them down REALLY tight, and crank them out.
When you can't use heat, use force. :banana:
#18 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 22 February 2005 - 12:17 AM
Get ahold of Edrach. He has some yield and I am sure he would come spray some on there for you. He probably won't give up his can though. As stated earlier, it is expensive and hard to get without a business license.
This the stuff that cardboard corragaters use to clean the stream presses and remove stubborn bolts from the equipment. It works better than anything else I have used in 28yrs of wrenching.
#19 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 22 February 2005 - 11:28 AM
If PB blaster dont work then I crank the impact wrench upto max PSI on my air compressor and let her rip. If that dont work its time for the torch with the impact wrench. Usually the darn bolt breaks before I get to the torch :(
#20 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 22 February 2005 - 01:20 PM
Come by my place and I soak it with Yield.
thanx!
#21 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 22 February 2005 - 01:40 PM
whast the full name of the Yield stuff and who makes it? I can use my business license from work to get a few cans if they sell it in Alaska..
Sounds like great stuff.
One idea, take a cold chisel and break the heads off.. take a drill, drill the holes out and just put bigger screws in it. Since its on the fuel system DO NOT HEAT WITH A TORCH (unless you like 3rd degree burns all over your body)
#22 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 22 February 2005 - 02:49 PM
But I thought you were only 30:confused:
That Yield stuff comes from down here in the land of steers and .. uhh stuff right?
hmm.. maybe time to bust out the business license and get busy:D
#23 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 22 February 2005 - 06:32 PM
Seafoam is some good stuff we all seem to agree
they also make "Creep"
if they put theur name on it...............
I'd also get out the impact driver.
The kind you hit with a hammer.
Best idea...
Go see Ed,. he'll set you up.
My bet is he has quite a few tricks up his sleeve.
#24 beauregaardhooligan
beauregaardhooligan
    Subaru Fanatic!
  • 424 posts
  • Greenville, SC
Posted 22 February 2005 - 09:03 PM
Sometimes trying to tighten the screw helps loosen the crud so you can back it out.
#25 Nug
Nug
    Lurker/off-topic poster
  • 1,968 posts
  • West Point, VA
Posted 22 February 2005 - 09:16 PM
Impact driver much?
Posted Image
