All Activity
This stream auto-updates
  1. Past hour
  2. First thing you need to know is why was the car parked, sitting for 20 years. Second, distributor cap off and try starting, to if the rotor is turning. If it isn’t, then you have a broken timing belt.
  3. Today
  4. Any SPFI throttle body for a DL/GL/GL-10/Loyale would work. Just visually inspect yours and if it looks the same, you're golden.
  5. You can replace them with 2WD or 4WD ones. Only different is a slight height change (2WD sit lower) so replace both of them. Your springs will still work on either. Grab some new bump stops and bellows for the struts if you have the scratch. I think there was some TRW struts out there very recently. Good luck :]
  6. I can find the rear struts easy on places like rockauto, o'reilly's and other sites. But I can not find any front ones. My friend says it's possible I have DL front suspension or are they the same? If anyone has 2 spare shocks for sale or knows where to find a front left and right struts please let me know I need to replace them ASAP.
  7. What about the belt-tensioner? Is it behaving itself? And another possible suspect: the belt guide-shoe, above one of the pulleys? (only installed on manuals, I think)
  8. Got pics to show the wear? Something must me misaligned - an idler pulley that’s worn, the water pump shaft worn out but this usually results in a leaking water pump.
  9. Yesterday
  10. Would the replacement throttle body need to have come from the same vehicle, an 87 GL-10 wagon with the EA82 SPFI engine? Or could it come from other years/models?
  11. I'm working on my grandfathers car that has been sitting for almost 20 years and my dad was trying to help me get it working. There was no distributor in it when we popped the hood and we managed to find a 87 GL distributor. We cut the connectors and we matched the cars wire color to the distributors and cranking it over it won't spark. My dad found something online saying swap the green and white wire but we don't have a white wire and we don't want to fry it. Any ideas?
  12. I'm only running this way for testing purposes, it's temporary. I DO NOT NEED RECOMMENDATIONS or discussion about how bad of an idea this is. I've driven a few hundred miles and the top smooth surface of the Subaru belt is showing odd grooving and uneven wear. It's never touched any fluids and belt and pulleys are all OEM and only 5 years old with maybe 50,000 miles. I checked them just in case although there's really no way for a pulley to cause such uneven wear. All of the pulleys and water pump seem fine - so I'm wondering what's causing this - could it be the heat from the exhaust coming up from those 2005+ odd exhuast systems that run forward under the timing belts? That seems really unlikely but I've also never seen a timing belt do this before. I'm going to install new pulleys and water pump and timing cover, but I'd also like to know for sure what's causing this.
  13. Yes my 2005 Impreza has to bulbs the H1 Low beam and a separate Hight Beam bulb.
  14. Found this in a 2011 NASIOC forum: So it looks like the following Subarus use H1 low beam bulbs: 2004-2005 Impreza 2003-2004 Baja 2000 - 2003 Legacy
  15. Big hammer on the front and rear of the lower arm. Hit it hard and the taper will release. I never used a fork, cause I don't have one.
  16. I’d be working out what fried the ECU first! No use spending good coin on a replacement ECU only to have the same thing happen again!
  17. I have seen throttle bodies for sale on eBay. Granted, they really aren't cheap. Enough to make me wince ($350-$400). HOWEVER - with the throttle body you get a TPS, an injector, a fuel pressure regulator, and an IAC valve. You'd spend over $400 if you bought the parts separately (if you can find them *cough* injector & OEM regulator). It's not the cheap route, but the parts would be genuine and you'd have spares. You may get lucky if you spend a few hours on the eBay rabbit hole. I saw someone list a throttle body as a carb a few months back for a crazy low price. I'd just check all the electrical hoopla going to the TPS before plugging it in. Just my 2¢. :]
  18. I suspect the reason people say they might "leak for no reason" are the bolts being previously overtightened which creates a pinhole/crack behind said bolt for the coolant to come out of. As a result, someone might suspect a gasket leak. I had this problem, and I fixed it with the Permatex coolant specific RTV. A light smear on the gasket and bolts worked. That said, you really shouldn't have to do this, as the paper gasket should be fine, but these cars are older with many hands that have been on them at this point.
  19. Last week
  20. And Car-part.com: 1999 Engine Computer Subaru Impreza 22611AE510 X AA0682 $125 Avalanche Auto Parts USA-CO(Denver) E-mail 1-303-722-3151
  21. P.s.s this age they should be PlugnPlay - remove the battery cables 1st if you're not familiar w/the process. Also, check the EGI (?) fuse under the hood- the big one. Might have gotten blown, too. GL
  22. This shows '99 only but AT and MT use the same: https://parts.subaru.com/p/Subaru__/Engine-Control-Module-ECM-Engine-Crankshaft-Position-Sensor-Bracket/49232072/22611AE510.html I'm not sure about the '99 being MAF or MAP based? If it has the MAF by the airbox then it's likley a one year only ECU, since I believe the '00-'01 EJ22 were MAP. Here's one on Ebay: 22611ae510
  23. Well, no luck finding anyone parting out a SPFI 1987 GL-10. Also came up empty on wrecking yards. I was about to order another Hitachi SERA484-2 from PartsGeek, but fortunately checked their return policy. It is very strict when it comes to electrical parts. I chatted with a rep and asked about the return policy on this part. From that conversation: "If your part fails, we will issue you an RMA number to return the product. Faulty parts and improperly installed parts return decisions are left up to the manufacturers’ rules and regulations . We process the return for you by accepting the part and then forward the part directly to the manufacturer for final approval. In this case, this part is returnable as long as it is due to an error whereby the incorrect part was delivered, or similar cases. Returns are not accepted in cases involving warranties or returns due to electrical failure of the part, or because it burned out due to an electrical failure in the vehicle, or similar cases." Ugh! So back to the drawing board...
  24. The tapers should be easy. Your fork looks a bit big, it might rip the old rubber but it should work. The pinch bolt on the knuckle that sometimes get so corroded it snaps in two. Inspect and be careful. Unlink the antiroll bar to make it easier to push down on the lower control arm.
  25. If you are getting the "beep of imminent death" from your ECU, when driving around, or even on startup, then your timing has issues. Various issues include, 1. rotor screw dropped out, 2. timing belts have never been tightened which should be done every 5000 to 8000 miles, 3. one side has skipped a tooth due to loose timing belts. Other symptoms include, engine power fluctuating, idles at a lower rpm than usual, less than normal power, runs rough on startup, heavy valve lifter noise. All of these indicate a timing issue.
  26. My 05 forester started doing clicks and clacks in the front suspension over low speed bumps, seems like its time for suspension ball joints. no fee play in the steering ones. Received already my skf joints, but before trying to install and getting stuck, some questions: 1. does my fork tool look like the right size and shape? 2.how bad is freeing the tapers on these? Car has no rust but the joints where never changed in 20 years.. 3.any other tips in terms of work steps? tnxs!
  27. that much i know.... but how do the us headlights work? separate bulbs for low and high?
  1. Load more activity
