All Activity
- Past hour
- Today
el_freddo started following 1990 EA82 bearing noise on cold start up
el_freddo replied to montermahan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like that you found the issue but I don’t like the potential cost of sorting out the issue unless it’s the oil trick that Bushytails mentioned above. -
Rich Mixture, Misfire, Stalling
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All good mate! Like I said (somewhere), we didn’t get the SPFI over here in Australia. Any that are here are kits that were sent over from the states. I did think it odd that they didn’t run an O2 sensor but not knowing the system myself I could only go by what I was told by others. Thanks for the correction though. I hope having the O2 hooked up properly will sort out your fuel usage! -
700 started following Norwich CT offering 1978 4WD wagon lots of parts but NOT complete
Womens In Your Town - No Verify - Anonymous Adult Dating https://SecreLocal.com [url=https://SecreLocal.com] Womens In Your Town [/url] - Anonymous Casual Dating - No Verify New Girls [url=https://secrelocal.com/girl/sofa-14.html]Sofa[/url] [url=https://secrelocal.com/girl/kate-blush-132.html]Kate Blush[/url] [url=https://secrelocal.com/girl/dovia-129.html]Dovia[/url] [url=https://secrelocal.com/girl/christina-hammo-kira-133.html]Christina Hammo Kira[/url] [url=https://secrelocal.com/girl/busty-anastasia-52.html]Busty Anastasia[/url] [url=https://secrelocal.com/girl/taylor-78.html]Taylor[/url] [url=https://secrelocal.com/girl/taylor-78.html]Taylor[/url]
- Yesterday
Daskuppler started following Stuck Front Differential Fill Bolt '14 Forester
Hello Everyone, A while ago, I did a drain and fill on the front differential, everything went smooth. Going to do it now, the fill plug seems to be seized in place. The allen head stripped out, so I hammered in an extractor. The extractor stripped, so I drilled out a slightly larger hole and really hammered in a larger extractor. This extractor stuck, but I couldn't turn it. I put an impact on it, and it wouldn't turn. I heated the differential case and it wouldn't move. Sprayed some PB Blaster on it and let it soak, reheated, and it still won't move. I tried some of that bolt freeze stuff, and it still won't move. It's not the end of the world as you can shove a hose through the drain port and fill it until it runs out of the "full plug", but it's annoying at the least. Anyone have any suggestions?
bushytails replied to montermahan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had an EA81 for a while where every couple months I had to add a bit of oil to the dist to keep it quiet... -
montermahan replied to montermahan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It was distributor -
Thanks. It's also solving the issue when I feather the gas pedal. I have a TPS, I'm going to change it. I hate throwing parts. Google AI: Subaru Loss of Power That Returns When Gas Pedal Is Feathered When a Subaru suddenly loses power and then recovers when you lightly press the gas pedal, it often points to an engine or fuel delivery issue that the ECU can detect and manage under certain conditions. Common causes and explanations: Fuel delivery or sensor issues: Even if the fuel pump and tank are new, problems with the fuel pressure regulator, injectors, or oxygen sensors can cause the ECU to limit power. If the pedal is feathered, the ECU may interpret it as a low-load condition and allow more fuel or throttle response Subaru Outback Forums+1. Oxygen sensor or exhaust system problems: A failing O2 sensor or a partially blocked catalytic converter can cause the ECU to enter a “limp” mode. Feathering the pedal can sometimes bypass or reduce the severity of the restriction, allowing partial power recovery Reddit. Vacuum or intake leaks: Unmetered air entering the intake can confuse the ECU’s load calculation, leading to sudden power loss. Feathering the pedal can temporarily mask the effect Reddit. Ignition system faults: Worn spark plugs, coil packs, or plug wires can cause misfires that the ECU compensates for by limiting power. Feathering the pedal may reduce the load enough for the ECU to allow more throttle Subaru Forester Owners Forum+1. Timing or mechanical issues: A timing belt jump, valve lift sensor fault, or internal engine problem can cause intermittent power loss. Feathering the pedal may allow the engine to run at a lower load where the fault is less critica
- Last week
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
@el_freddo I regret to say that I gave you some misinformation. O2 sensors WERE standard equipment on SPFI models. The Cali-spec used a 3-pin connector and the federal emissions (all the other states) used a 1-pin connector. I got confused since I bought my GL with an exhaust system without an O2 sensor bung. My guess is that at some point someone put a carb exhaust on the car as these didn't always have O2 sensors. Now I need to get an O2 sensor on my car. Which means welding up a new cat and splicing the wiring in that was removed. Hopefully now the car will get out of open-loop and I'll actually see above 22mpg. -
I haven't done a voltage drop yet. thanks for the tip! Probably would have saved some time if I'm understanding the idea correctly as it doesn't seem like the switch is corroded. Need to find the ground for the turn signal switch I guess. I did get down to the turn signal switch and manually bridging (on a clean surface) the little circuit gaps that the slide mechanism closes when flipping the turn signal stalk does nothing. However, grounding the horn peg to the steering bolt does sound the horn. The stop lamp bulb is still on. Here are a few wiring diagrams I found. I'm not good at reading these things :-( . I am using a test light btw. the green/red, green and green/yellow wires with the little gaps between are what I'm talking about bridging. I'm really hoping that wiring diagram might lead to a solution. Looking at it as someone who doesn't really know what they're looking at.. it seems important that the stop lamp warning light is on but the brake lights all work perfectly fine and only the hazards/turn signals are a problem. I'm just guessing though. I welcome any advice!
- 4 replies
- electrical
- wiring diagram
(and 2 more)
Tagged with:
Have you done a voltage drop yet? If you already know this then feel free to ignore Find the ground for these switches and put one lead on the battery ground and one at whatever point these are grounded. Meter should read zero or close to it. If it is higher than .5 V (rule of thumb) than your problem is in the ground termination. If it is zero, than do the same thing but from the ground side of the switch to the ground termination. Repeat on the positive side as well. If you suspect the switch is corroded as you say, than a voltage drop across the switch with the switch closed will tell you for sure. A non corroded switch should have zero voltage (potential difference) across the switch when it is closed, and ~12 when it is open.
- 4 replies
- electrical
- wiring diagram
(and 2 more)
Tagged with:
EA 81 Oil Feed Line (82 Brat GL)
natalie42x replied to natalie42x's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Awesome thanks! -
A wiring diagram would be extremely helpful. You tested the fuses and fusible links, not just by looking at them correct? You used a meter or test light?
- 4 replies
- electrical
- wiring diagram
(and 2 more)
Tagged with:
Make an appointment with Google for repairs? Seriously, do the same search "Subaru loss of power, switch to neutral back to drive and resolves" for a deeper dive. AI Overview: A Subaru losing power while driving but recovering when shifted to neutral and back to drive (N-D reset) usually indicates a transmission control module (TCM) glitch, a faulty inhibitor/neutral safety switch, or a torque converter solenoid issue. This action effectively resets the transmission's active gear command.
I suspect there's corrosion in the turn signal switch.. from what I understand, the horn goes through that same switch and when I peek into it from the left side of the column it looks pretty nasty. Will update tomorrow after pulling the wheel and attempting to clean it up. edit: turns out the actual electrical switch for the turn signals is located on the opposite side of steering wheel from the turn signal stalk. The nastiness I referred to on the stalk side was just a bunch of lithium grease and doesn't have any effect on the actual electric turn signal switch from what I can tell.
- 4 replies
- electrical
- wiring diagram
(and 2 more)
Tagged with:
bushytails replied to natalie42x's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's plugged on GLs, and has a switch on DLs, as the text says. Note the thread is 1/8 BSPT, not 1/8 NPT, but they're similar enough it usually fits. Also note if you swap in a DL engine into a GL, and then plug the wire into the switch, where the wire is exactly the length and position and connector to plug onto the switch, you cook the dash gauge. Seen that done twice now... -
Poor idle after rapid deceleration
There's been a new development. My ECU threw a code 32 for the O2 sensor. Best I can tell the car never came with one. I have swapped the ECU that came in the car for a different one. Perhaps the donor car came with an O2 sensor. But I've been driving with this ECU for months and it only now popped up the code. I'll swap back to my old ECU and see if that makes a difference. If not I'll swap in my Cali-spec cat I have and throw in an O2 sensor. It'd help my gas mileage - plus save the planet and all that. :] -
natalie42x started following EA 81 Oil Feed Line (82 Brat GL)
Hello all! I bought a Brat a couple years back and she has been really good to me, except one of the previous owners installed an aftermarket turbo with a sidedraft Carter YH carb off an old corvair (it was a pretty cool setup). I however, live in California, and am trying to get it to pass smog. I am bringing it back to stock, and have it running with the Carter-Weber. The line marked in the first picture was originally running as a feed line for the turbo. I am planning on removing it and just installing a plug, but I am not sure what the stock condition was. The factory service manual is not immediately clear, Picture 3 shows a pressure switch installed on the non-GL models. However, Picture 4 seems to imply that the pressure switch is installed where the relief valve plug would be located (the line is coming from the block though and the relief valve plug is on the oil pump housing cover). My best guess is that on the GL models with the pressure gauge instead of switch, this port is plugged. TLDR: Can someone with a EA 81,1800cc, GL model; Send me a picture to see if that is plugged or if there is an oil line there that feeds elsewhere? Thanks!
I've searched the forum extensively but haven't found anyone with this particular issue. This '91 Loyale has been sitting for about two years. It was running fine prior to its long rest but now that the battery has been replaced and its up and running again, the following issues have cropped up: Turn signals don't turn on Hazards don't turn on Dash turn arrow indicators do not illuminate when flashers ought to be on The flasher relay is not clicking The 'Stop Lamp' dash light is lit (but brake lights and headlights are fine) Horn doesn't work Here is what I've done to try to solve the problem: replaced flasher relay (no change, no power getting to the line per the test light) replaced all hazard/blinker bulbs (no change, still no blinkers, 'stop lamp' still lit on dash) tested all fuses in box and the four fusible links under hood (all were fine, the hazard/horn/clock fuse is fine, clock works) I'm at a loss as to what to do next other than dig further into the dash and to trace the flasher wire back further (not fun). Prodemand is not helpful. Please ultimatesubaru, you're my only hope!
- 4 replies
- electrical
- wiring diagram
(and 2 more)
Tagged with:
VVT will flag codes ending up in limp mode. The mechanism is kind of cool if you end up diving into the valve cover. Yes the oil pressure sensors leak and make a mess on top of the engine, but not expensive or hard to replace. the 3.0 h6 is a great engine presume the 3.0r is the same. we're running a jdm h6 replaced at 300k now into 400k miles on the 02 h6 outback. lots of hex bolts on the timing cover. had fuel leaks on the rails/injectors just replaced orings/seals/lines/dampeners dang expensive. had a hard steering line oring fail on the rack but what do you expect after 25 years.
Troubleshooting my rough running 93 Loyale
azdave replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Glad you got it fixed! A very interesting thread and timely too. I was just about ready to post up my own appeal for help with my 87 DL SPFI 5-speed that has nearly the same symptoms. It starts as easily as it ever has, over and over but will not idle or run at a steady throttle position. It runs great if under acceleration but I have to keep blipping the throttle to keep it running. I'll review the info here first and make sure I haven't missed anything before I start my own thread. -
SuspiciousPizza replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For any of those interested Rockauto has 4 NEW SPFI injectors in stock under an '86 GL. They're $400 USD. That's a very low price compared to some eBay sellers. -
DaveT replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Checked the filter in the injector, it is clean. -
ok, Ill look at the old one. -
The spring clips need to be pushed in so they go in the notch in the pad, not sticking out on top.
