Everything posted by bheinen74
Lets see your before and after photos
bheinen74 replied to Mr. Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
after after -
Meet Spiffy
bheinen74 replied to 1982gl4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hi Spiffy, nice. make spiffy happy and polish up those turd headlights. -
headliner and sunroof
bheinen74 replied to veronicas71's topic in Old Gen.: 80's GL/DL/XT/Loyales...
First off, check and clean out the drip drains for the sunroof the like to clog with crap over the years and so that could be all you need. if you have a factory sunroof, you would be BEST off by FAR, to source some new seals for it, from a Subaru dealer, i like to call jason at Mike Scharff, he can get you new seals.- thats if you got a factory one. There is no way you going to a custom shop is gonna work well, and be cost effective. those new seals might cost less than 50 bucks, worth the check, and should be easy to install. on your own on the headliner. -
Forester Diff has been dissected, guts are out. since nobody has posted, I figured i will ask again. -Do i keep the carrier bearings on the vlsd chunk when i install it in my 3.9 94SS diff case? Or do i need swap carrier bearings to maintain the 3.9 carrier? going to junkyard tomorrow to get the axles, then I can pull the 3.9 from the car and put that ring gear on the vlsd chunk, then grind the 3.9 innard to fit the chunk. I found my grinder tool from when I did the lsd on my BRAT to grind the inside of the pumpkin, so I should be good to go. Next question, the vlsd is a sealed unit, meaning i just dump the normal gear oil in, no additives, that sound right. Need some answers, got 2 days of 65 degree days to get this done, before it goes to highs of 40. last warm enough weather to work in a non heated garage this week, then i am done til srping march/april thaw. brent
walnuts:? "Kedge Grip: Our own unique blend of crushed (recycled) glass and crushed walnut shell particle blended into our full grade truck rubber. Kedge Grip acts in a twofold way; first the walnut shell is designed to come out leaving small (approximately 1 mm) size pits in the tread surface that will act as additional siping and create more traction edges to grip the road. The second is the crushed glass which is designed to stay in longer and create a gritty surface to help anchor you to the road. Does it really work? Don’t take our word for it, read some of the testimonials. Also, check out the 4Wheeler magazine (though under a different name that we are not allowed to use any longer due to trademark issues) in the August 2009 issue. They consistently had excellent results with our Kedge Grip." thats a first i would have never imagined.. price is right on sale now too. 142
as far as i concerned all those 4eat to the svx were busted status from the factory, mine never made it past 40k and none of the other of 92 made it much further....why would anyone recommend him to use a original trans-they are garbagex10xea82x ej25 worst setup for a subaru EVER was the eg33 torque monster witha 4eat. subaru was way wrong.... back then needs a 6mt from sti and then good forever. that motor is non-interference, good for many million miles (helicopter/airplane/etc) and it is a torque monster, N/A, yeah turbo guys have to have psi to beat this sucker. love mine, 7.5 qt oil change is a bit much, but oh well.
<--- nice avatar wut happend
congrats, its looks stock keep it that way if you can, production number7 will be an investment over time as in will hold its value more than the others. Then, someday (if you keep it stock) it will go up in value. How many of these in 20 years will still be stock, or still around, and not wrecked?: none but this one is my hope will still be the same as today. good find. trade offerered for my BRAT, SVX, , and my brothers outback and dads forester, along with a pretty big sheepdog
as above, last week switched to snow tires, but what i didnt say was that i saw cords on the old summer tire, inner left front, all others were looking good. So, went over to see if dad could get out his alignment rack. first off, toe looked about .4 negative or so right tire had -.8 camber left tire had -1.8 camber spec says 0 to -.75 give or take .o2 decided to only adjust front left got it to about 0 decided to leave the right side as it was, since the tire on the side had shown normal wear. back over the toe machine. perfect dead on to 0 going to check tires soon and often for any wear -need to go get tires balanced, or re-attempt the bubble balancer. oh, changed oil in the SS also.
Flat Towing & My clicking Axle
bheinen74 replied to Responsible Jon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
replacing the axle would cost alot less than renting a tow dolly... regardless, towing a brat in neutral is not really putting a lot of stress on any axles but you dont want it grenading on you going down the road at 70mph. -
Spare tire jack for lifted car.
bheinen74 replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the most recent " u pull it" junkyard i went to, EVERY single car had been turned jackless by the management of the yard. Too many previous idiots who used a jack, followed by a weight shift and falling over.....not good to just use a jack on any car. Suggest to use a jackstand.
