Subarian
Everything posted by Subarian
Actually, he just bought an 86 Brat and he's thinking about motor options. As far as a legacy motor, it costs whatever you pay for it. I just found a complete running car (90 legacy) with 162,000 miles for $250, but I've been looking patiently for 6 months. The advantage of a complete car is that you know it's running and you can pull all the accesories off it.
Or it's grounded out. Check for a break in the wire touching metal.
OK, so now we want to know, who's Rusty Jones?
Are you trying to remove the entire wiper arm or replace the blade? The arm is held on by a nut on the stud. Remove the nut and wiggle the arm a little and it comes loose. The wiper blade is replaced by removing it from the pivot at the end of the arm. The end of the arm is U-shaped. If you lift the arm and rotate the blade part way, you'll see a tab on the underside of the pivot. Press down on the tab and slide the blade toward the open end of the U.
Anyone ever have knocking with synthetic oil.
Subarian replied to Gl-boost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most sythetics are completely compatible with petroleum oils. -
How hot is hot? If it's in the middle of the normal range, I wouldn't worry about it.
Really Stoopid Things We Have Done
Subarian replied to subbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Many years ago, when I rebuilt my first engine (a small block in a Chevy van) I misplaced one of the carb mounting nuts. After I searched for a while, I gave up and decided to start the engine. I immediately figured out where the nut was. Fortunately, it had only made a dent in the top of the piston and I was able to get it to run. -
Depending on who you bought the carb from, you may or may not need to tune it. If you bought it specifically for your application from a supplier, like redline weber, it should be jetted correctly. You would need to set up the idle mixture and idle speed, both of which are pretty simple and can be found on redline weber's website: http://www.redlineweber.com/html/Tech/carburetor_set_up_and_lean_best_.htm If you bought the carb secondhand and it was originally jetted for a different vehicle, or if you live at high altitude (like I do) you may need to rejet the carb.
I've removed EA82 engines and transmissions separately and together. It's not all that difficult to remove the trans, especially since you're going to have to remove all the pieces anyway. I'd leave the engine in place and drop the trans.
Professionals use a compound called cerium oxide. It's an abrasive powder that's mixed with water and used on a felt buffing wheel. It's really important to keep it wet while you're working it. I don't know where you can buy it commercially, but you could probably get your local glass shop to order it for you. If they say they don't know about it, have them check their CR Laurence catalog.
I have a similar problem running synthetic in my Isuzu Rodeo. The only thing I can figure is that the oil pump is too worn and the synthetic is too slick for me to get good oil pressure. There's a significant difference in oil pressure between the same grades of dino oil and synthetic. -
Intro to forum, CV question
Subarian replied to subrookie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree with Gary. I'd replace that one. -
I've had the same quality issues with new rotors recently. You can pull the wheel and use a point on the backing plate as a reference point. It doesn't take a lot of out-of-round to make you feel it when you're braking.
reinstalling clutch cable after engine swap
Subarian replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You're very welcome. I'm glad the motor didn't have to come out again. -
quick knocking noise question
Subarian replied to misledxcracker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Which engine do you have? My carbed 86 doesn't have a knock sensor, but the turbo 86 does. Anyway, the original response wasn't to say anything is wrong with your knock sensor; it was to illustrate how timing can affect detonation (pinging or knock). -
URGENT! Damper/accessory pulley question
Subarian replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No spacer. There's a large washer that goes under the head of the bolt. -
Check with your city or county. They usually have a waste disposal program for things like old paint and antifreeze. I've got about 6 gallons in my garage waiting for me to get to the dropoff point on the one day a year they accept hazardous waste from the public.
No, the cable length should be the same. Try pushing on the clutch fork. If you push it (or pull it) and it springs back, that's the pressure plate. If that happens, look at your cable linkage.
