Everything posted by mattocs
Are there more Brats in your area, Skip? It seems that north of Pittsburgh they are rare. I've only seen one here...but i've seen it multiple times.
The 2.2l engines are very reliable...I'm not sure about the 2.0l ones. Those place the oil leaks from are the common places. The seals can go over 200,000 miles without a leak...but not always. You might not have to redo the seals again as long as you own the car. The engine in that car tends to have head gasket leaks. That is a bit costly to fix...but once its done the car will be fine for a long while. Gotta weigh the pros and cons. The Legacy GT is a beautiful car...but headgaskets cost a little over $1000 from the dealer. Then again, you might get lucky and never have a problem with them.
Haha...i'm waiting for the Fourpeat and possible Fivepeat.
Yeah...i'd like to put one in the empty slot above my cd player... Right now I have a handheld Cobra that hardly works unless someone is withing a few hundred feet of you
PCV Valve
mattocs replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That must have been the easiest thing to replace ever. -
PCV Valve
Thanks for the quick reply. -
It would make more sence to have the 2.2 and then use the 3.3l from the SVX instead of making the 2.5l. Both the 2.2 and 3.3 are decent engines when it comes to reliability. I guess the minor power upgrade in the 2.5l is why they replaced 2.2l with it. A bigger gas efficiant 4 cyl is what they were thinking.
Awesome. I'd be happy with a 3 inch lift and bigger tires on my Outback.
80,000 miles isn't that long of an exhaust life. My 95 Legacy went 210,000 miles or so before anything went wrong...and it was just a small hole or something...that a local shop welded and all is well now. Look for a nice cat back exhaust system...if I had the funds, that is what I would do. It dosnt have to be overly loud, and you may get some minor raise in power.
You said it! She is sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo hot
