2
Everything posted by somick
AC not working l series 1990
somick replied to ea81turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is also a sensor on top of the AC pulley that is held by one 10 mm bolt (14 mm head) and one 6mm bolt (10 mm head). Make sure the sensor is as close to the pulley as possible. Good luck, Sam -
Fuel pump replacement options
somick replied to KevinP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No regulators or anything. The inlet hose had to be rerouted. I bought an extra hose and routed it as a letter "S". I also bought a 2 and 1/4 inch U-bolt and drilled two extra holes in the original bracket. Shoved a cork under the pump to cushion it. That was it. My main concern was the lack of barbs on the pump's tubes. I was afraid that the hose may slide off. Checked it yesterday. Everything looks fine. -
https://www.amazon.com/gp/product/B07FZ5YKXT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 It is slightly bigger than the OEM and you will have to modify a bracket. I installed this pump about a month ago. It works fine. Good luck, Sam -
For the wires I would just repair them. You mentioned that you have a new distributor. Are you sure you installed it correctly? Good luck, Sam
EA82 CTS / Coolant Temperature Sensor readings
somick replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you Dave! -
Pictures will help.
I searched Amazon for 2001 Corolla clock and got nothing. Where did you buy them?
Post this question in New Generation forum and you get more views/replies. Good luck, Sam
My electric fan is also shot. If you search Amazon's automotive section for 12 inch fan you will get plenty of results. They are around 20 bucks or so. Good luck, Sam
On my 92 Loyale the driver side fan is controlled by the engine temperature: the hotter the engine the faster the fan spins. The driver side fan is an electric fan. When you turn the AC on it suppose to come on. It will come on also if the engine's temperature is too high and this will help the main fan to cool the engine off. Sam
84 hatch, rear wheel bearings ...
somick replied to old sub freak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use a steel punch and go around little by little. Good luck, Sam -
I was thinking the same way but did not get to it yet.
- 5 replies
- ej253
- tensioner rod
(and 3 more)
Tagged with:
The vehicle is 2010 Forester with 106000 miles. The YouTuber brianmobil1 mentioned that the top of the tensioner rod must be smooth. Mine is warn out. It is not leaking oil and I was going to reuse it. Should I replace it? Thanks for looking, Sam
- 5 replies
- ej253
- tensioner rod
(and 3 more)
Tagged with:
Thanks, Sam
